Author Topic: pro tools le 5.1 installer cd for digi 001 + AudioMediaIII  (Read 2372 times)
Online chrisNova777
« on: April 25, 2015, 10:21:54 PM »
http://www.mediafire.com/download/d69eif1r30c1mdk/ptLE5.1.toast
should work for windows 98/ME aswell as mac os 9.x
***do not install this on windows XP (u need "le 5.3.x" or "le 6.x.x")
***do not install this on mac os 8.6 (u need 5.0.1)
require a serial beginning with "DIGI 0510"
5.1.1 update is here --> http://archive.digidesign.com/download/511/
if neccessary
Pro Tools LE version 5.1.1 will not work with any hardware other than the Digi 001 or the Audiomedia III card, and will not work in "standalone" mode without the Digidesign hardware installed.
http://archive.digidesign.com/compato/os9/001/
http://archive.digidesign.com/download/511macle/
Online chrisNova777
Re: pro tools le 5.1 installer cd for digi 001 + AudioMediaIII
« Reply #1 on: May 13, 2019, 12:07:39 AM »
dont forget to install Protools LE 5.2.1cs1
to get up to 32 tracks on os9 with the digi 001 + others
Pro Tools LE 32T Beta For Macintosh Digi 001 & ToolBox Systems
July 2002
Free Download for Pro Tools LE 5.1 & 5.1.1 Owners With the Following Systems Only:
Digi 001 for Macintosh Systems
ToolBox, ToolBox CD, & ToolBox XP for Macintosh Systems
Audiomedia III with Pro Tools LE for Macintosh Systems
What is Pro Tools LE 32T Beta for Macintosh?
Increases number of simultaneous audio tracks to 32 on Mac-based Digi 001 & Toolbox/Audiomedia III systems
Pro Tools LE 32T Beta comprises two Macintosh-only components: Pro Tools LE 5.2.1cs1 and DAE 5.1.1cs11. Using these two components with either Digi 001 or Digi Toolbox on Macintosh will increase the number of simultaneous audio tracks from 24 to 32.
Who Should Use this Update?
This update should only be used by Macintosh-based Digi 001 or Digi Toolbox owners using Pro Tools LE v5.1.1 or v5.2.1, who wish to increase their track count to 32 tracks. Please note that:
Digi 001 or Digi Toolbox system owners using Pro Tools LE 5.1 Mac or older will need to install Pro Tools LE 5.1.1 in order to use the Pro Tools LE 32 T Beta components. Pro Tools 5.1 owners can Download the Pro Tools 5.1.1 Update Here
Pro Tools LE 32T Beta will not work with Mbox systems.
Pro Tools LE 32T Beta is for Macintosh users only. Digi 001 and Digi Toolbox Windows customers should use Pro Tools LE 5.3.1 for Windows XP to enable 32-track support (and other features) on their systems. Please see the Windows Pro Tools 5.3.1 Updates Page for details on how to obtain this update.
Important: We recommend that only the Pro Tools LE users specified above use this update. Pro Tools LE 32T Beta is provided as an interim "customer support (CS)" release to add the functionality described. While our testing has not shown this change introduces other problems to the supported systems, this version has not been fully qualified by Digidesign.
Updating Pro Tools LE and DAE
To enable 32-track support, you'll need to replace your existing version of the Pro Tools LE application (either v5.1.1 or 5.2.1) and DAE 5.1.1.
To replace Pro Tools:
Drag the new Pro Tools application into the Pro Tools Folder within your Digidesign Folder.
Click OK to replace the older version. (Should you need to revert to the "older" version, replace Pro Tools 5.2.1cs1 with the previous version you wish to run).
Note that if you have changed the memory allocation assigned to Pro Tools LE 5.1.1 or 5.2.1 from the default setting, you will need to repeat the process and change the memory allocation for Pro Tools LE 5.2.1cs1.
To replace DAE:
Drag the new DAE into the DAE Folder within your System Folder.
Restart your Macintosh.
Note that if you have changed the memory allocation assigned to DAE 5.1.1 from the default setting, you will need to repeat the process and change the memory allocation for DAE 5.1.1cs11.
Please Note
Going forward, newer "customer support" versions of Pro Tools LE components may be made available. When available, these versions will be located in the Support/Downloads section of Digidesign's web site.
Compatibility Information & System Requirements
Available from the Support/Compatibility section in the Digidesign Compatibility Documents
Pro Tools LE 32T Beta can only be used with with a previously installed Pro Tools LE version 5.1.1 or version 5.2.1 Digi 001 or ToolBox system.
What's Included In This Download
Pro Tools® LE 5.2.1 (version 5.2.1cs1) application
DAE™ (version 5.1.1cs11) application
PT LE 32T Beta Read Me.pdf (Acrobat PDF with installation instructions)
