Author Topic: ableton live v4.14/v4.15 rewire issue with cubase sx3  (Read 1784 times)
« on: July 22, 2015, 11:28:36 AM »
"The ReWire master application has detected a different version of Live than the one last used. Please quit both the current ReWire master application and Live, and then launch Live once as a standalone application so that it can install its ReWire engine."
https://www.logicprohelp.com/forum/viewtopic.php?f=1&t=104697
http://duc.avid.com/showthread.php?t=362136
The cause of this error was on XP from a faulty installation of live, which installed the rewire components in relation to a v4.15 install,if the executable version doesnt match the rest of the install, then ReWire will not work correctly with cubase..
it did however work fine with reason..strangely enough.
this is a problem i caused by packaging a 4.14 patch with a 4.15 install
this file will fix: https://www.mediafire.com/?h89qv5lo7vnarp0
