Author Topic: Alesis Ai3 (2000)  (Read 3181 times)
Alesis Ai3 (2000)
« on: November 02, 2015, 04:11:32 AM »
http://www.soundonsound.com/sos/jul00/articles/alesis_news.htm
Alesis have introduced the AI3 audio interface. When connected to the ADAT Edit via the ADAT 8-channel optical interface, the 1U-rackmounting AI3 adds eight 24-bit balanced analogue ins and outs to software using the PCI card for audio I/O. Priced at £449 including VAT, the AI3 will also obviously work with any device supporting the widespread ADAT interfacing standard -- other PCI cards, samplers, digital mixing desks, and so on. Inputs and outputs are on TRS jacks, and the A-D and D-A converters are 128x oversampling. The front panel of the unit features signal/clip input indicators, a +4dB/-10dB operating-level switch, an internal power supply and a source switch to select whether the eight analogue inputs or the ADAT optical input will be sent to the ADAT optical output.
http://www.alesis.com/contentmgr/showdetails.php/id/9169
http://www.alesis.com/contentmgr/showdetails.php/id/1469
http://www.alesis.com/print/print.php/1415
