Hardware > synths - 1990s
expansion DATA cards for JV880 (1992)
oldschoolamp:
--- Quote from: Romans on June 28, 2018, 02:36:18 AM ---Hi Chucky!
Download from here: http://www.synthzone.com/midi/roland/jv80/jvsyxzip.zip
You'll find PN-JV80-01, 02, 03, 04, 05 (.syx files) in this zip file. There's some other soundbanks - Arabia.syx, Bass.syx, US_JV880.syx (Internal), EXP_001.syx etc.
P.S. I'm also still looking for PN-JV80-07.syx file. No luck so far :(
I think it would be great if anyone, who has PN-JV-06, 07 soundbanks, would share these in .syx format here for free. Thanks!
--- End quote ---
Thank you for the link. I have PN-JV80-06, which requires the SR-JV80-02 Orchestral ROM expansion. After downloading SysEx Librarian for OS X, I was able to load the other syx info from your link to my JV2080. I was then able to figure out how to record a SysEx dump of the PN-JV80-06 card to upload it in this post. It has the 64 patches, 16 performances, and 1 rhythm set. Hope it helps those looking. When I find the PN-JV80-07 card on eBay or Reverb I will upload that as well. This forum group has helped me beyond words. Much appreciated!
Romans:
I'd like to remind, that .syx files for JV-1080, JV-2080 can't be loaded into JV-880.
To know if .syx can be transfered to JV-880, there's SysEx File Verification Utility:
http://llamamusic.com/super-jx/SysEx_Verify_Beta_v1a.html
Patches from PN-JV80-05 and PN-JV80-07 data cards are from JV-1000.
I only have JV-880, so I can't be sure about .syx files below (see attachment):
patches from JV-1000 (preset banks + user bank) for JV-1080, JV-2080.
I hope that these pathes will work with your JV-1080, JV-2080.
P.S. Compare JV-1000 & JV-880 PDF manual to see which patches are the same with both modules, which are different.
Romans:
These are banks from PN-JV80-01, PN-JV80-02, PN-JV80-03, PN-JV80-04, PN-JV80-05 in .mid file format.
Also JV-880 Internal (User) bank included.
Use your hardware sequencer for sending to JV-880. Also any DAW can be used - import .mid. Cable from PC's soundcard MIDI OUT should go to JV-880 MIDI IN. You know already :) Click play on DAW - .mid file is beeing sent.
capacitance:
Did anybody find, or can upload, a SysEx dump of the "Rich Sound Collection 4" card (PN-JV80-07)?
Ideally, the dump should be created with a JV-80/880, so as to be as compatible as possible with the entire JV line of synths. (e.g., if the dump of the card is a created on a JV-1010, it won't be loadable by a JV-80, it will only work with JV-1010's or later compatible models)
Mr_Mojo_Risin:
"Posted by: capacitance
on: November 06, 2021, 09:17:16 PM ยป Insert Quote
Ideally, the dump should be created with a JV-80/880, so as to be as compatible as possible with the entire JV line of synths. (e.g., if the dump of the card is a created on a JV-1010, it won't be loadable by a JV-80, it will only work with JV-1010's or later compatible models)"
@capacitance - This attachment is PN-JV80-07 Rich Sound Collection #4 for Roland JV-80 / JV-90 / JV-880 / JV-1000 Synthesizers Only
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
