Author Topic: Speedsoft Vsampler (2000?)  (Read 23578 times)
« on: August 23, 2014, 03:42:33 AM »
http://www.kvraudio.com/product/vsampler_by_speedsoft
VSampler provides all of the classic sampler features, and also offers you a multitude of new opportunities. Extensive signal processing possibilities, with Drag&drop and context menus allow quick access to all functions and provide for a smooth workflow.
Features:
    255 voice polyphonic.
    16 part multi-timbral (16 MIDI Channels).
    16 Stereo outputs.
    Supports all usual output formats from 16 bits/44 kHz up to 32 bits/192 kHz.
    Sample-Editor.
    Auto-Looper.
    Beat-Slicer.
    Synth.
    Built in Effects (Reverb, Delay, Phaser, Distortion, EQ, etc.).
    Modulation matrix.
    Soundbank Manager.
    Autoload Preview.
    Can also host VST plugins.
    AKAI CDs 1:1 on hard disk (Can build a 1:1 copy of the AKAI CD as a disc image file on your local hard drive or network drive).
Loads the following sample formats:
    AKAI (S1000/3000 CD and S5000/6000.AKP).
    SoundFont (.SF2) - Can also save as SF2.
    HALion (.FXB,.FXP).
    Gigastudio (.GIG).
    LM4 drumkits.
    WAV.
    AIFF.
Reverend Recode
Re: Speedsoft Vsampler (2000?)
« Reply #2 on: October 11, 2019, 08:29:57 PM »
Just sent you an email on this Chris
« Last Edit: October 11, 2019, 08:52:03 PM by Hardwood »
« Reply #3 on: November 10, 2019, 12:16:24 PM »
http://web.archive.org/web/20160307150346fw_/http://maz-sound.com/index.php?id=2&show=product
Overview
VSampler transforms your PC into a 255 voice polyphonic software sampler that is able to use any recorded sound as a musical instrument. It provides all of the classical sampler features in excellent sound quality, and also offers you a multitude of unique new opportunities. VSampler plays XXL instruments without being limited to the RAM size. In cooperation with the users of its award-winning predecessor an intelligent softwaresampler has been created, which beneath a truly transparent surface combines extensive editing abilities with simplest handling. Drag&drop; actions and context menus (right mousekey) allow quick access to all functions and provide for a smooth workflow.
VSampler can operate either as a plug-in (VSTi, DXi) in your sequencer or as an independent program (ReWire, MIDI), it uses up to 32 separate audio outputs (ASIO, DirectSound). The included “virtual MIDI-cable” also connects VSampler to any MIDI-file player (check the GM soundset offer!) or classical MIDI sequencer.
VSampler loads instruments in the popular sampler formats SF2™, Gigastudio™, HALion™ 1 + 2, Kontakt™ 1.x, DLS, AKAI™ (S1000/S3000 CD and S5000/S6000 .AKP files) and E-MU™ III / IV CD. Furthermore VSampler loads LM4™ and Battery™ drumkits plus ReCycle™ (RCY, REX, RX2) and ACID™ drumloops. Your own Instruments are quickly created by dragging WAV or AIF Samples onto the on-screen keyboard.
VSamplers unique instrument preview allows you to test different sounds with a single mouse-click even during playback. Owners of an SB Live!™ / Audigy™ / X-Fi™ soundcard will be pleased that VSampler can also save files in the popular SF2 format.
VSampler's various tempo-synchronizable envelope types and LFO's, and its velocity sensitive filters ranging from subtle to aggressive are all inducive to sound editing. Instruments can be further refined using either the included effects (Reverb, Delay, Phaser, Distortion, EQ …) or any VST-plugin. The animation of all effect-, envelope- and filter-parameters in a mutual modulation matrix, creates instruments with extraordinary dynamics and impressive, realistic playability. The included presets for effects, envelopes and modulation will get you off to a good start.
Whether quick playback module for everyday use or creative tool with synthesizer qualities - VSampler fuses both in a versatile instrument.
interesting that it supported ReWire??
im assuming this is the exact same product with a new skin? extended functionality?
http://web.archive.org/web/20061018171401fw_/http://www.maz-sound.com/index.php?show=news&id=5
v3 originally released in (2003)
« Last Edit: November 11, 2019, 02:50:55 PM by chrisNova777 »
