Author Topic: Cubase Audio XT v3.05 (1996/1997) for windows 3.1 + win 95  (Read 20669 times)
« on: August 24, 2014, 03:27:14 AM »
Confirmed working with windows 3.11 | confirmed working with win95
includes custom support for AWE32/64 cards under win3.1/win95
LINK **UPDATED** : CubaseXT.zip
the installer is also downloadable from ftp.steinberg.net (if u have a green steinberg parallel dongle key)
will only install on legacy windows systems such as windows 3.x or windows 95
the installer will have you select one of the following options of supported recording hardware during setup :
Windows Sound Card (pick this if u dont have any of the options below)
Digidesign Session 8
http://archive.digidesign.com/download/legacy/s8pc/
http://www.oldschooldaw.com/forums/index.php/topic,586
Digidesign Audio Media III
http://www.oldschooldaw.com/forums/index.php/topic,354
Yamaha CBXD3 / CBXD5
http://www.oldschooldaw.com/forums/index.php?topic=592
http://www.oldschooldaw.com/forums/index.php/topic,4135
http://www.oldschooldaw.com/forums/index.php/topic,592
Akai DR8 http://www.soundonsound.com/sos/1995_articles/aug95/akaidr8.html
Akai DR16 http://www.oldschooldaw.com/forums/index.php/topic,4451
Creamware Master Port
http://www.soundonsound.com/sos/1997_articles/oct97/creamware.html
http://www.oldschooldaw.com/forums/index.php/topic,4452
http://translate.google.com/translate?hl=en&sl=ru&u=http://www.muzoborudovanie.ru/equip/studio/seq/cubase305/cubase305.php&prev=search
readme ftp://ftp.steinberg.net/Archives/Cubase_preVSTversions/PC/Cubase30/cubas305.readme
http://www.datasheetarchive.com/files/intel/drg/pentiu~1/tools/cubase~1.htm
Tool: Cubase Audio XT/VST
Category: Digital Content Creation: Audio Editing/Mixing
Cubase Audio XT/VST* builds on the same sequencing, scoring and audio features from Cubase and Cubase Score* with VST native audio with Windows* 95 and supported soundcards. An XT version is also included for use with other hardware devices such as Digidesign's 882 interface, Yamaha CBX D3*, D5*, Akai* HDR-8, 16 and Creamware Masterport*. Custom Mixer* maps are included for total audio automation of levels, pans and EQ's on the specific hardware.
http://www.soundonsound.com/sos/1996_articles/jul96/steinbergcubase3.html
http://www.soundonsound.com/sos/1997_articles/nov97/cubasevst.html
the attached file is directly from the steinberg ftp and requires a cubase dongle (Serial or parallel) that will authorize the app.. any 3.x dongle should work aswell as this package was bundled with cubase 3.x
« Last Edit: February 16, 2023, 06:05:11 PM by chrisNova777 »
Re: Cubase Audio XT v3.05 (1996/1997) for win 3.1 + win 95
« Reply #1 on: November 19, 2016, 01:22:33 PM »
Important note!!!!!!
version by another program愀 installer. In case you experience difficulties with
Enjoy!
The Steinberg Team.
Bug fixes and more
AWE32 or AWE64 card).
following copies was missing.
Fixed.
for Chord track instead of
'c'):
   1 = MIDI track
   2 = Drum track
   3 = Mix track
   4 = Audio track
   5 = Group track
   6 = Tape track
   7 = Chord track
simultaneously. Both fixed.
Fixed.
device.
Sound card audio
record any audio material.
Cubase 3.05
manual.
on the disk.
Yamaha CBX-D3/D5
Monitor Window look changed.
Directory names and file names containing country dependant characters (e.g. �...�) are now
recognized by Cubase.
deletion, or keeping.
Sound card audio
Session 8 and AudioMedia III
bar 36...)
a GPF. Fixed.
Audio Media III
Interface=AudioMedia PCI
Mros: Mr_mmwin.dll
Version 2.02
Version 2.03
problem.
Mros: Mr_mmc.dll
Version 2.00
This is how to do it:
  your PC BIOS.
  defaults.
Installation disc set 1.01
PCL driver version G 1.20
being:
Acoustics.
a big way.
noise.
suffer from this problem.
cut it.
you!
[mga.drv]
PCIChipset=1
ta da... problem fixed.
pro audio equipment supported by cubase audio XT (1997)
« Reply #2 on: November 19, 2016, 03:58:02 PM »
list of equipment mentioned in the cubase setup files
akai mpc60 http://www.oldschooldaw.com/forums/index.php?topic=3144
akai dr8 http://www.oldschooldaw.com/forums/index.php?topic=867.0
akai dr16 http://www.oldschooldaw.com/forums/index.php?topic=4451.0
akai s612 http://www.oldschooldaw.com/forums/index.php?topic=2646
alesis d4 http://www.oldschooldaw.com/forums/index.php?topic=1429
alesis midiverb http://www.oldschooldaw.com/forums/index.php?topic=3431.0
alesis quadraverb http://www.oldschooldaw.com/forums/index.php?topic=1451
casio cz-3000 http://www.oldschooldaw.com/forums/index.php?topic=2379
creative labs AWE32 http://www.oldschooldaw.com/forums/index.php?topic=624.0
digidesign 882 http://www.oldschooldaw.com/forums/index.php?topic=355
digidesign audiomedia III http://www.oldschooldaw.com/forums/index.php?topic=154.0
digitech dsp128 http://www.oldschooldaw.com/forums/index.php?topic=1453
digitech dsp256 http://www.oldschooldaw.com/forums/index.php?topic=1514
dmc mx8 http://www.oldschooldaw.com/forums/index.php?topic=2374
emu morpheus http://www.oldschooldaw.com/forums/index.php?topic=2139
emu procussion http://www.oldschooldaw.com/forums/index.php?topic=1908
emu proformance 1 http://www.oldschooldaw.com/forums/index.php?topic=2558
emu proteus fx http://www.oldschooldaw.com/forums/index.php?topic=2483
emu proteus 1 http://www.oldschooldaw.com/forums/index.php?topic=1921
emu proteus 2 http://www.oldschooldaw.com/forums/index.php?topic=4429.0
emu proteus 3 http://www.oldschooldaw.com/forums/index.php?topic=4430.0
emu vintage keys http://www.oldschooldaw.com/forums/index.php?topic=1909
emu vintage keys pro http://www.oldschooldaw.com/forums/index.php?topic=1909
emu emax http://www.oldschooldaw.com/forums/index.php?topic=3139
ensoniq sq80 http://www.oldschooldaw.com/forums/index.php?topic=2183
ensoniq VFX http://www.oldschooldaw.com/forums/index.php?topic=1476
ensoniq esq1 http://www.oldschooldaw.com/forums/index.php?topic=2303
ensoniq sd1 http://www.oldschooldaw.com/forums/index.php?topic=1903
fostex dcm100 http://www.oldschooldaw.com/forums/index.php?topic=4254
fostex fos280 http://www.oldschooldaw.com/forums/index.php?topic=4001.0
kawai k1 http://www.oldschooldaw.com/forums/index.php?topic=2247
kawai k3 http://www.oldschooldaw.com/forums/index.php?topic=2850
kawai k4 http://www.oldschooldaw.com/forums/index.php?topic=2361.0
kawai k5 http://www.oldschooldaw.com/forums/index.php?topic=2563.
kawai gmega http://www.oldschooldaw.com/forums/index.php?topic=2551
kawai xd5 http://www.oldschooldaw.com/forums/index.php?topic=2587
kmx 8x8 http://www.oldschooldaw.com/forums/index.php?topic=2388
kmx 15x16 http://www.oldschooldaw.com/forums/index.php?topic=2389
korg 01w http://www.oldschooldaw.com/forums/index.php?topic=1468.0
korg 03rw http://www.oldschooldaw.com/forums/index.php?topic=2857.0
korg 05/rw http://www.oldschooldaw.com/forums/index.php?topic=2315
korg sdd3300 http://www.oldschooldaw.com/forums/index.php?topic=4151
korg X5 http://www.oldschooldaw.com/forums/index.php?topic=2978
korg drv2000 http://www.oldschooldaw.com/forums/index.php?topic=1460
korg dw6000 http://www.oldschooldaw.com/forums/index.php?topic=2570.0
korg dw8000 http://www.oldschooldaw.com/forums/index.php?topic=2723.0
korg EX800 http://www.oldschooldaw.com/forums/index.php?topic=4131
korg wavestation http://www.oldschooldaw.com/forums/index.php?topic=1471
korg wavestation AD http://www.oldschooldaw.com/forums/index.php?topic=4015
korg wavestation SR http://www.oldschooldaw.com/forums/index.php?topic=2360.0
korg m1 http://www.oldschooldaw.com/forums/index.php?topic=2178.0
korg t1 http://www.oldschooldaw.com/forums/index.php?topic=3170.
korg t2
korg t3 http://www.oldschooldaw.com/forums/index.php?topic=2192.0
korg m3r http://www.oldschooldaw.com/forums/index.php?topic=2819
kurzweil k1000 http://www.oldschooldaw.com/forums/index.php?topic=1922
kurzweil k2000 http://www.oldschooldaw.com/forums/index.php?topic=4096
lexicon lxp5 http://www.oldschooldaw.com/forums/index.php?topic=3172.0
lexicon lxp15 http://www.oldschooldaw.com/forums/index.php?topic=1365.0
lexicon lxp5II http://www.oldschooldaw.com/forums/index.php?topic=1366
lexicon lxp1 http://www.oldschooldaw.com/forums/index.php?topic=1507
lexicon pcm 70 http://www.oldschooldaw.com/forums/index.php?topic=1436
motu midi mixer 7s http://www.oldschooldaw.com/forums/index.php?topic=2365
oberheim matrix 6 http://www.oldschooldaw.com/forums/index.php?topic=1581
oberheim matrix 1000 http://www.oldschooldaw.com/forums/index.php?topic=1919
oberheim ob8 http://www.oldschooldaw.com/forums/index.php?topic=4432.0
oberheim xpander http://www.oldschooldaw.com/forums/index.php?topic=4235
peavey dpm3 http://www.oldschooldaw.com/forums/index.php?topic=3448
quasimidi quasar
roland soundcanvas
roland spd8 percussion pad http://www.oldschooldaw.com/forums/index.php?topic=4398.0
roland sc55 http://www.oldschooldaw.com/forums/index.php?topic=2109
roland d5 http://www.oldschooldaw.com/forums/index.php?topic=3163
roland d10 http://www.oldschooldaw.com/forums/index.php?topic=2063
roland d20 http://www.oldschooldaw.com/forums/index.php?topic=2177
roland d50 http://www.oldschooldaw.com/forums/index.php?topic=1518
roland d70 http://www.oldschooldaw.com/forums/index.php?topic=2102
roland d110 http://www.oldschooldaw.com/forums/index.php?topic=1426.
roland d550 http://www.oldschooldaw.com/forums/index.php?topic=2475
roland mt32 http://www.oldschooldaw.com/forums/index.php?topic=2398
roland juno1/2 http://www.oldschooldaw.com/forums/index.php?topic=1536
roland juno106 http://www.oldschooldaw.com/forums/index.php?topic=1421
roland jx8p http://www.oldschooldaw.com/forums/index.php?topic=1390
roland mks20 http://www.oldschooldaw.com/forums/index.php?topic=2554
roland mks50 http://www.oldschooldaw.com/forums/index.php?topic=1536
roland mks80 http://www.oldschooldaw.com/forums/index.php?topic=2040
roland mks70 http://www.oldschooldaw.com/forums/index.php?topic=4133
roland r8 http://www.oldschooldaw.com/forums/index.php?topic=2279
roland r8m http://www.oldschooldaw.com/forums/index.php?topic=2101
roland u110 http://www.oldschooldaw.com/forums/index.php?topic=3152
roland u220 http://www.oldschooldaw.com/forums/index.php?topic=2856.0
roland jv30 (1991) http://www.oldschooldaw.com/forums/index.php?topic=2845
roland jv80 http://www.oldschooldaw.com/forums/index.php/topic,6027
roland jv90 http://www.oldschooldaw.com/forums/index.php?topic=2300.0
roland jv880 http://www.oldschooldaw.com/forums/index.php?topic=1415
roland jv1000 http://www.oldschooldaw.com/forums/index.php?topic=5159.0
roland jv1080 http://www.oldschooldaw.com/forums/index.php?topic=2837
roland jd800 http://www.oldschooldaw.com/forums/index.php?topic=1420
roland jd990 http://www.oldschooldaw.com/forums/index.php?topic=1416
roland RAP10 sound card http://www.oldschooldaw.com/forums/index.php?topic=652
roland rd1000 http://www.oldschooldaw.com/forums/index.php?topic=4257.0
roland sbx 80 (sync box) www.oldschooldaw.com/forums/index.php?topic=2272
sequential cirtcuits sixtrak http://www.oldschooldaw.com/forums/index.php?topic=2024.0
sequential circuits prophet http://www.oldschooldaw.com/forums/index.php?topic=1843.0
tascam mm1 http://www.oldschooldaw.com/forums/index.php?topic=902
tc electronic tc2290 http://www.oldschooldaw.com/forums/index.php?topic=4152
yamaha dmp7 http://www.oldschooldaw.com/forums/index.php?topic=2505
yamaha dx7ii http://www.oldschooldaw.com/forums/index.php?topic=1546.0
yamaha sy77 http://www.oldschooldaw.com/forums/index.php?topic=1427
yamaha tx802 http://www.oldschooldaw.com/forums/index.php?topic=2827
yamaha tx7 http://www.oldschooldaw.com/forums/index.php?topic=2334
yamaha tx81z http://www.oldschooldaw.com/forums/index.php?topic=2242.0
yamaha v50 http://www.oldschooldaw.com/forums/index.php?topic=2565
yamaha rx7 http://www.oldschooldaw.com/forums/index.php?topic=2470
yamaha rx8 http://www.oldschooldaw.com/forums/index.php?topic=3162
yamaha rx5 http://www.oldschooldaw.com/forums/index.php?topic=2562.0
yamaha tg55 http://www.oldschooldaw.com/forums/index.php?topic=2408.0
yamaha sy55 http://www.oldschooldaw.com/forums/index.php?topic=2408.0
yamaha sy22 http://www.oldschooldaw.com/forums/index.php?topic=1907
waldorf microwave http://www.oldschooldaw.com/forums/index.php?topic=1918
yamaha tg55, yamaha tx81z, alesis d4, akai s612,  AWE32 card, e-mu procussion, proteus1, alesis midiverb, juno 1, juno 2, juno 106, roland u110, roland jv880, roland r8,
« Last Edit: February 14, 2019, 09:29:57 AM by chrisNova777 »
Offline Mixermap
Re: Cubase Audio XT v3.05 (1996/1997) for win 3.1 + win 95 [DL]
« Reply #3 on: August 09, 2017, 05:44:33 AM »
If you want to try it out but don't have a PC with Windows 3.1 handy
Here is a full DosBox installation of Win 3.11 AND Cubase Audio XT 3.05
It is set up to work with DosBox's SoundBlaster emulation and it's ready to go.
MIDI data can be entered in the Key and Drum editors and played back by the emulated SB.
Have not tested yet how to connect a MIDI keyboard or how to get audio into the emulator as I have only used DosBox for games so far...
Your help would be much appreciated :)
Unzip the CBAXT305 folder and all its contents onto your hard drive (possibly root of C:).
Run the file "00-Start.bat"
Follow the on-screen instructions.
NOTE: I AM NOT RESPONSIBLE FOR ANY DAMAGE CAUSED BY USING THIS.
IT WORKS PERFECTLY ON MY SYSTEM: Core i5 / 8GB Ram / Windows 10 64bit.
PS.: I did not create the DosBox/Win3.11 setup, I downloaded it already made.
What I did is to make the whole installation portable (you don't need DosBox installed on your system), install CBAXT and optimise it, create the splash screen and the batch file to start the whole emulation to make it easy for people who have never used Dosbox.
« Last Edit: February 14, 2019, 09:32:09 AM by chrisNova777 »
« Reply #4 on: February 12, 2019, 04:41:16 PM »
28th of April 1995
================== Studio module drivers ====================
The current versions of the Studio module, at this date, are:
PC: 1.00 r5
Atari: 1.06c
Some of the drivers need the lastest Studio version.
The list is sorted alphabetically. It contains drivers made by Steinberg and
others made by some users (made on the Atari, but PC compatible).
360 Systems (folder 360_SYST)
   8x8 Midi patch bay (8_8PATCH.DEV)
   Audiomat (AUDIOMAT.DEV)
Akai (folder AKAI)
   Mb 76 (MB_76.DEV)
   PEQ 6 (PEQ_6.DEV)
   S-612 (S_612.DEV)
Alesis (folder ALESIS)
   D4 version 1.01 (D_4_101.DEV)
   D4 version 1.02 and above (D_4_102.DEV)
   MidiVerb 3 (MIDIVRB3.DEV)
   Quadraverb (QUADVERB.DEV)
   QuadraSynth (QUASYNTH.DEV)
Art (folder ART)
   DR 1 (DR1.DEV)
   Multiverb (MULTIVRB.DEV)
Bit (folder BIT)
   Master Keyboard (BIT_MAST.DEV)
Casion (folder CASIO)
   CZ-3000 (folder CZ_3000.DEV)
DMC (folder DMC)
   MX-8 (recent version) (MX_8.DEV)
   MX-8 (old version) (MX_8_MAN.DEV)
Emu (folder EMU)
   MPS (MPS.DEV)
   MPS+ (MPSPLUS.DEV)
   Procussion (PROCUSS.DEV)
   Proformance (PROFORMP.DEV)
   Proteus 1 XR Classic (PROT1XRC.DEV)
   Proteus 1 XR Pop (PROT1XRP.DEV)
   Proteus 1 Classic (PROT1_C.DEV)
   Proteus 1 Pop (PROT1_P.DEV)
   Proteus 2 (PROT2.DEV)
   Proteus 2 XR (PROT2XR.DEV)
   Proteus World (PROT3.DEV)
   Proteus World XR (PROT3XR.DEV)
   Protologic (PROTOLOG.DEV)
   Protologic XR (PROTOLXR.DEV)
   Proteus FX (PROT_FX.DEV)
   Vintage Keys (VINTAGE.DEV)
   Vintage Keys+ (VINTAGEP.DEV)
   Morpheus (MORPHEUS.DEV)
   Ultra Proteus (PROT_ULT.DEV)
Ensoniq (folder ENSONIQ)
   ESQ-1 (ESQ_1.DEV)
   ESQ SPM (ESQ_SPM.DEV)
   SD-1 (SD1.DEV)
   SQ-1 & SQr (SQ1.DEV)
   SQ-1+, SQr+, SQ-2 (SQ1_PLUS.DEV)
   SQ-80 (SQ_80.DEV)
   VFX (VFX.DEV)
Generic drivers (folder GENERIC)
   Universal download/upload (ANY_DUMP.DEV)
   Universal download/upload with bank display (GENERIC.DEV)
   General MIDI (GEN_MIDI.DEV)
Ibanez (folder IBANEZ)
   Reverb SDR-1000 (SDR_1000.DEV)
JL-Cooper (folder JLCOOPER)
   Patch bay MSB 16/20 (MSB16_20.DEV)
Kawai (folder KAWAI)
   K1, K1-r (K_1.DEV)
   K-3 (K_3.DEV)
   K-4 (K_4.DEV)
   K-5 (K_5.DEV)
   K-5 with old ROM version (K_5_SLOW.DEV)
   G-Mega (G_MEGA.DEV)
KMX (folder KMX)
   Patchbay 15x16 (KMX15X16.DEV)
   Patchbay 8x8 (KMX_8X8.DEV)
Korg (folder KORG)
   01-W, 01-Wr (01_W.DEV)
   01-W for use in sequencer mode (01_W_S.DEV)
   03-W (03_W.DEV)
   05-W (05_W.DEV)
   DRV-2000 (DRV_2000.DEV)
   DVP-1 (DVP_1.DEV)
   DW-6000 (DW_6000.DEV)
   DW-8000 (DW_8000.DEV)
   EX-800 (EX_800.DEV)
   I3 (I3.DEV)
   M1, M1r, M1ex (M_1.DEV)
   M3 (M_3R.DEV)
   SDD-3300 (SDD_3300.DEV)
   T1, T2, T3 (T1_T2_T3.DEV)
   WS (WS.DEV)
   WS-AD (WS_AD.DEV)
   WS-SR (WS_SR.DEV)
   X-5 (X_5.DEV)
Kurzweil (folder KURZWEIL)
   K-1000 (K_1000.DEV)
   K-2000 (K_2000.DEV)
   K-2000 that have a problem with bank-select messages (K_2000B.DEV)
   Micro Piano (MICROPIA.DEV)
   PX-1000 (PX_1000.DEV)
   Utility to retrieve K-2000 names: K2000NAM
Lexicon (folder LEXICON)
   LXP-1 (LXP_1.DEV)
   LXP-15 (LXP_15.DEV)
   LXP-15 version 2 (LXP_15V2.DEV)
   LXP-5 (LXP_5.DEV)
   PCM-70 (PCM_70.DEV)
Lists (folder LISTS)
   10 banks of 128 programs with MIDI bank select (L10_128.DEV)
   16 banks of 128 programs with MIDI bank select (L16_128.DEV)
   4 banks of 128 programs with MIDI bank select (L4_128.DEV)
   8 banks of 64 programs with MIDI bank select (L8_64.DEV)
   2 banks of 32 programs, program changes only (LIST2_32.DEV)
   2 banks of 64 programs, program changes only (LIST2_64.DEV)
   4 banks of 32 programs, program changes only (LIST4_32.DEV)
   1 bank of 100 programs, program changes only (LIST_100.DEV)
   1 bank of 128 programs, program changes only (LIST_128.DEV)
   1 bank of 32 programs, program changes only (LIST_32.DEV)
   1 bank of 50 programs, program changes only (LIST_50.DEV)
   1 bank of 64 programs, program changes only (LIST_64.DEV)
   folder MAKELIST : utility to create a "list" driver according to certain
   specifications. The created driver handles MIDI bank-select messages.
Miditemp (folder MIDITEMP)
   Patchbay PMM-88 (PMM_88.DEV)
Oberheim (folder OBERHEIM)
   Matrix 6 (MATRIX_6.DEV)
   Matrix 1000 (MAT_1000.DEV)
   OB-8 (OB_8.DEV)
   XPander (XPANDER.DEV)
Peavey (folder PEAVEY)
   DPM-3 (DPM_3.DEV)
   Multifex (MULTIFEX.DEV)
Roland (folder ROLAND)
   A-50 & A-80 (A_50_80.DEV)
   D-10, D-20 (D10_D20.DEV)
   D-10, D-20, D-110 with a sysex/tone approach (D10_TONE.DEV)
   D-110 (D_110.DEV)
   D-5 (D_5.DEV)
   D-50 (D_50.DEV)
   D-50 EX (D_50_EX.DEV)
   D-550 (D_550.DEV)
   D-70 (D_70.DEV)
   GP-8 (GP_8.DEV)
   GR-1 (GR_1.DEV)
   GR-50 (GR_50.DEV)
   JD-800 (JD_800.DEV)
   JD-990 (JD_990.DEV)
   Juno 1 & 2 (JUNO_1_2.DEV)
   JV-1000 (JV_1000.DEV)
   JV-1080 (JV_1080.DEV)
   JV-30 (JV_30.DEV)
   JV-80 (JV_80.DEV)
   JV-880 (JV_880.DEV)
   JV-90 (JV_90.DEV)
   JX-8 P (JX8_P.DEV)
   MKS-20 (MKS_20.DEV)
   MKS-50 (MKS_50.DEV)
   MKS-70 (MKS_70.DEV)
   MKS-80 (MKS_80.DEV)
   MT-32 (MT_32.DEV)
   PM-16 (PM_16.DEV)
   RD-1000 (RD_1000.DEV)
   R-8 (R_8.DEV)
   R-8M (R_8M.DEV)
   SBX-80 (SBX_80.DEV)
   SC-55 (SC_55.DEV)
   SC-88 (folder SC_88.DEV)
   SE-50 (SE_50.DEV)
   SPD-8 (SPD_8.DEV)
   U-110 (U_110.DEV)
   U-20 (U_20.DEV)
   U-220 (U_220.DEV)
   VP-70 (VP_70.DEV)
Sequencial Circuit (folder SEQUENTI)
   6 Tracks version 9 (6TRACK.DEV)
   6 Tracks version 4 (6TRACK_4.DEV)
   Multitrack (MULTITRK.DEV)
   Prophet-600 (PROPH600.DEV)
   Prophet-5 40 prog. (PROPH_5X.DEV)
   Prophet-5 120 prog. (PROPH_5.DEV)
   Prophet-8 (PROPHTT8.DEV)
   Prophet-10 (PROPHT10.DEV)
   Prophet VS (PROPH_VS.DEV)
Voyetra (folder VOYETRA)
   V-8 (V_8.DEV)
Waldorf (folder WALDORF)
   Microwave (MCROWAVE.DEV)
Yamaha (folder YAMAHA)
   DEQ-7 (DEQ_7.DEV)
   DMP-11 (DMP_11.DEV)
   DMP-7 (DMP_7.DEV)
   DX-11 (DX_11.DEV)
   DX-7 (DX_7.DEV)
   DX-7 II (DX_7_II.DEV)
   KX-88 latest ROM (KX88.DEV)
   ProMix 1 (PROMX1.DEV)
   QY-10 (QY_10.DEV)
   REV-5 (REV_5.DEV)
   REV-7 (REV_7.DEV)
   RX-7 (RX_7.DEV)
   SPX-1000 (SPX_1000.DEV)
   SPX-90 (SPX_90.DEV)
   SPX-90 II (SPX_90II.DEV)
   SY-22 (SY_22.DEV)
   SY-55 (SY_55.DEV)
   SY-77 (SY_77.DEV)
   SY-99 (SY_99.DEV)
   TG-33 (TG_33.DEV)
   TG-500 (TG_500.DEV)
   TG-500 other ROM type (TG_500_0.DEV)
   TG_77.DEV (TG-77)
   TX_7.DEV (TX-7)
   TX_802.DEV (TX-802)
   TX_816.DEV (TX-816)
   TX_81Z.DEV (TX-81Z)
Zoom (folder ZOOM)
   Zoom 9010 (ZOOM9010.DEV)
Offline foksadure
  • Stuck in 1997
« Reply #5 on: September 03, 2022, 04:38:54 AM »
does cubase audio 3 xt for windows work without a dongle?
It does if you use the cr*cked "cubase.386" file from the DOSBox version or the zip from Chris posted above, and put it in the C:\Windows\System\ folder.
No point in buying a full box without the dongle though, unless you're after the hardback manuals.
« Last Edit: September 03, 2022, 05:54:46 PM by foksadure »
Offline foksadure
  • Stuck in 1997
« Reply #6 on: September 03, 2022, 09:37:39 AM »
  • Seems there's an empty slot in the box where the dongle was
  • The installation files are already available in this thread or elsewhere
Ergo the floppies are useless to install and run Cubase 16bit.
Offline foksadure
  • Stuck in 1997
« Reply #7 on: September 03, 2022, 03:23:53 PM »
I'm sorry but you're being cryptic about what you're really after.
You can install Cubase XT, from the files posted here and there.
If you have the dongle, you can run it legit, like I am.
If you don't, there's the Cubase.386 cr*ck.
What's the point asking about floppies anyway?
« U.R. Card » means the serial (113000444) is on the User Registration Card, which one can see in the fourth picture your posted.  ;D
« Last Edit: September 03, 2022, 05:53:21 PM by foksadure »
Offline foksadure
  • Stuck in 1997
« Reply #8 on: September 04, 2022, 07:25:10 AM »
I get it know.  :)
--- Off-topic ---
Despite the ubiquitous Gotek USB adapters, floppies aren't dead yet.
https://www.theguardian.com/world/2022/sep/01/japan-digital-minister-declares-war-on-floppy-discs
Can't beat an old process that just works as expected. Everytime.
Offline foksadure
  • Stuck in 1997
« Reply #9 on: October 26, 2022, 02:42:21 AM »
Another source for the OG Cubase last 16bit version full installation CD-Rom:
https://archive.org/details/cubas305.r2
Steinberg Cubase 3.05r2 Installation-Disk
Steinberg Cubase 3.05 R2
Installations Disk original CD-Rom for Windows
Cubase 3.05
Cubase Score 3.05
Dongle required
