Author Topic: e-mu sp1200 (1987) sampling percussion  (Read 18196 times)
« on: November 19, 2015, 09:26:47 AM »
WHAT IS IT?
http://web.archive.org/web/19980213052016/http://www.emu.com/sp-1200.htm
http://web.archive.org/web/19981203055201if_/http://www.emu.com/sp-spec.htm
messages.
Re: e-mu sp1200 (1987) sampling percussion
« Reply #1 on: March 03, 2017, 07:52:33 PM »
E-MU SP1200 SPECIFICATIONS
Sampling rate:   26kHz
Word length:   12 bits
Inputs:   1 for sampling
Number of segments:   100
Number of songs:   100
Display:   backlit LCD
« Reply #2 on: March 03, 2017, 07:55:01 PM »
E-mu Systems SP1200
Sampling Percussion
Limitations
Verdict
« Reply #3 on: July 17, 2017, 06:49:15 AM »
« Reply #5 on: December 10, 2019, 06:54:07 AM »
« Reply #6 on: December 23, 2019, 09:20:45 AM »
Controls
Master Control
Tempo, Increment value, Decrement value, Enter data, Mix volume, Metronome volume, Keypad (select segment, select song, enter data)
Performance
Play buttons (8), Sound bank select, Sliders 1-8, Slider function select, Tempo tap/Auto repeat, Run/Stop, Record/Edit
Programming
Segment/Song select: Segment mode: Metronome rate, Swing factor, Copy/Append segment, Time signature, Segmetn length/Truncate segment, Ease note/sound/segment, Autocorrect resolution, Step program mode; Song mode: Program trigger, Define repeats, Call subsong, End (loop or Link), Insert song step, Delete song step, Program tempo change (accellerando or deaccellerando), Program mix change
Setup
Select multi pitch mode; Select multi level mode; Exit multi mode; Enable dynamic buttons; Define mix; Select mix; Reassign output channel; Decay/Tune select; Loop/Truncate; Delete sound; Set first song step; Set MIDI parameters; Select special functions: Clear all memory, Memory remaining, Write SMPTE, Clear sound memory, Clear sequence memory, Copy sound, Swap sounds, Default decay, Decay/Tune range, Name sound, Dynamic allocation, Transmit MIDI sound dump, Recieve MIDI sound dump, reverse sound
Disk
Save sequence, Save sounds, Load sequences, Load segment #, Load Sounds, Load Sound #, Catalog sequences, Catalog sounds, Format/Copy software, Load sequences and sounds
Sync
Select internal clock, Select MIDI claock, Select SMPTE code, Select external clock
Sample
Input gain, VU display, Assign voice, Preamp level, Threshold level, Sample length, Re-sample, Arm sample, Force sample
Specifications
Data Format
Twelve bit linear
Sounds
120 sounds standard (stored on 5 diskettes)
Segments
100
Songs
100
Sequence Capacity
5000 notes minimum (depending on density of parts)
Sample Memory
10 seconds, in four 2.5 seconds blocks
8th. note, 8th. tripet, 16th. note, 16th tripet, 32nd. note, 32nd. tripet, high resolution
Tempo range
40-240 BPM
Outputs
Mono mix, Individual channels, (eight, programmable, tip = unfiltered, ring = filtered), MIDI out, MIDI thru, SMPTE, Metronome/Clock
Inputs
Sample, MIDI, SMPTE/Sync, footswitches (3)
Interface
MIDI, SMPTE, 24qpn clock
Data and Sound Storage
3.5"floppy diskette
Optional accessories
Additional sound library diskettes, footswitches
