Author Topic: roland mc-303 (1996) groovebox - 8 track sequencer (7+1)  (Read 10383 times)
« on: November 20, 2015, 12:22:34 PM »
https://static.roland.com/assets/media/pdf/MC303FX.PDF
https://ia802609.us.archive.org/13/items/RolandMc-303GrooveboxServiceNotes/MC-303_groovebox_SM.pdf
ts 16 parts (main 8 + RPS 8)
Tones 448 Tones
Drum Sets 12 sets
Maximum Polyphony 28 voices
Effects Reverb/Delay, Chorus/Flanger
Sequencer
Tracks 8
Songs 10
Patterns Preset: 120, RPS: 200
Variation Patterns 300
User Patterns 50 (maximum)/ approx. 14,000 notes
RPS Sets 30
Pattern Sets 20
Tempo Quarter note = 20 to 250 bpm
Resolution 96 ticks per quarter note
Recording Method Realtime, Step 1, Step 2
Control Knobs
Realtime Modify Cutoff, Resonance, LFO(Modulation,
Rate), Envelope Attack, Decay, Release,
Panpot, Level, Portamento Time
Effects Time/Rate, EFX Level
Play Quantize Timing, Velocity (Grid,Groove,Shuffle)
Arpeggio Accent Rate, Octave Range (33 styles)
Others Low Boost, Master Volume
Keyboard pad 16 keys (also Octave Up/Down)
Display 7 segments, 6 characters (LED)
Connectors Output jacks (Umono, R), Headphone
jack, MIDI connectors (In, Out), Foot
control jack, AC adaptor jack
Power Supply AC adaptor (DC 9V) (center negative i think)
Current Draw 5OOmA
Dimensions 378 (W) x 244 (D) x 91 (H) mm
14-14/16 x 9-10/1 6 x 3-9/1 6 inches
Weight 3.0 kg / 6 lbs 10 oz
(excluding AC adaptor)
Accessories AC adaptor
Options DP-2 Pedal Switch
BOSS FS-5U Foot Switch
• Specifications and appearance subject to change without notice.
S
The Roland MC-303 Groove Box is a self-contained, retro-styled sequencer and integrated sound module with some very high-tech features. Techno, rap, jungle, hip-hop, acid and other dance styles can now be approached easily and creatively by dance music producers and other groove enthusiasts with little or no musical training. Just lay down some cool beats and fat bass lines from the MC-303's huge selection of sounds and rhythms and let there be groove!
See a shockwave demo of the MC-303 Groove Box
Features:
448 dedicated dance sounds, 40 synth basses (TB-303, etc.), 35 synth leads, 33 synth pads
12 rhythm kits, including TR-808, TR-909, techno, jungle and house sets
Built-in vintage synth sounds and arpeggios; preset and user dance patterns with 300 variations
16-part multitimbral with an 8-track sequencer containing multiple quantize functions: Grid, Shuffle and Groove
Resonant filter, LFO, envelope control and built-in effects: delay, reverb, flanger and chorus
Realtime Phrase Sequencer (RPS) for instant recall of musical phrases
Low Boost feature
http://web.archive.org/web/19961106185956/http://www.rolandus.com:80/products/MI/MIprod_SS_MC.html#MC-303
http://www.vintagesynth.com/roland/mc303.php
http://web.archive.org/web/20090215175331/http://geocities.com/wjdegraaf_geo/mc303/planet.html
http://web.archive.org/web/20090215214131/http://geocities.com/wjdegraaf_geo/mc303/info.html
http://web.archive.org/web/20090215214146/http://geocities.com/wjdegraaf_geo/mc303/specs.html
http://web.archive.org/web/20090215214151/http://geocities.com/wjdegraaf_geo/mc303/topical.html
The Roland MC-303 is the first of a series of musical instruments known as a Groovebox. It combines a simple sound module with a sequencer to record and store notation, along with controls aimed at encouraging the musician to improvise the music while it is playing. Despite the number in its name and the hype it received at its launch, the MC-303 has more in common with other MC prefixed synthesizers (such as the Roland MC-202), which contain built-in sequencers, than it does with the famous Roland TB-303. As the first Groovebox, the MC-303 was the first in a line of inexpensive products specifically targeted towards house DJs and amateur home musicians rather than professional producers.
Features[edit]
The key features of the MC-303 are:
• Sound generator with 24 note - voice polyphony
• 8-track sequencer (7 pitched instruments and 1 drum kit)
• 8 part timbrality
• 448 preset sounds and 12 drum kits (includes the Roland CR-78, TR-808, TR-606 & TR-909)
• Reverb/delay and chorus/flanger effects
• 300 onboard dance music variation patterns such as drumbeats and basslines
• Recording length of up to 32 bars per pattern
• Instant storage of up to 50 user patterns, 300 pattern variations and 10 songs
• Storage space for up to approximately 14,000 notes
• MIDI in and out connections (but no MIDI thru)
Synthesizer/Sound Module
The synthesizer built into the Roland MC-303 is a rompler which contains sounds largely drawn from classic Roland synths and drum machines such as the TB-303, TR-808 and TR-909 along with the Juno series and various other dance themed sounds such as pads, pianos, strings and vinyl scratches. The sounds can be manipulated with a low-pass filter, various modulation capabilities and some simple DSP effects.
Sequencer
The most important part of the MC-303 is its built-in pattern based 8 track sequencer. Each pattern can contain up to 32 bars. It can record and send MIDI data via the MIDI jacks on the rear panel, enabling its internal sequencer to control other sound modules, or its internal sound module to be controlled by an external sequencer. Although communication with other devices is possible, the main advantage to the MC-303 with its small form factor and all-in-one design is the ability to use it as a self-contained studio, albeit an amateur one. Featuring a micro-keyboard that can also be used as a drum sequencer, the MC-303 imitates the handling as well as the look and feel of other famous Roland synthesizers and drum machines such as the MC-202, TB-303, TR-808 and TR-909.
8 part timbrality
Re: roland mc-303 (1996) groovebox
« Reply #1 on: August 10, 2016, 04:07:03 PM »
Offline iRelevant
Re: roland mc-303 (1996) groovebox - 8 track sequencer (7+1)
« Reply #4 on: March 02, 2018, 07:27:27 AM »
I recently got one of these secondhand for a fair price. Like it a lot. Still in explorative modus and will update with more info when I gotten deeper into the machine. As it is I'm still having trouble mastering the management of it in SOUND QUEST ... some communication trouble. One thing to be aware of is that there are different OS/Firmware versions, luckily mine came with the latest ... which is v1.03 (I think). It's supposed so solve some issues.
It's nice standalone, and can be used in connection with a DAW ... the downside is that, at least how it looks sofare, there is no transmission of CC data for the dials ... only the keypads ... it's also a bit quirky to use as a sound module ... you need to put it in some special modus and all frontpanel buttons loose functionality.
Overall still I'm happy with it ... paid around €80 for it second hand. Good quality, metal enclosure.
Somewhat limited storage ... only 50 user patterns and 8 user songs ... more than enough sofare.
If anybody knows how to manage it most conveniently, I'll be happy to hear tips. Particularly setup in SoundQuest, where I'm having some trouble ... uncertain as to what is the correct SysEx channel to use.
« Reply #5 on: March 02, 2018, 11:19:52 AM »
congrats ! i actually had a classified ad placed lookng for one of these at a good price.. i was hoping to get my hands on one, i remember i really wanted this back in 1997 but i bought turntables instead (money was tight working for blockbuster video! lol!)
Offline iRelevant
« Reply #6 on: March 09, 2018, 12:23:46 PM »
Thanks :) I'm quite happy with it. There are a few major limitations I discovered so fare ... main problem is that there is no transmission of controller data out (as I'm aware of), so it's not possible to record a performance. Other thing is the Effects section is a bit "computerish" ... changes in delay settings for instance is not instantaneous ... but need noticeable re-calculation time ... so you can't really perform with it. It transmits note data though ... and I consider it more as an instrument in itself ... or a standalone sequencer ... I'm planning on hooking it up to external midi modules and a sampler + external effects through a mixer. Will be interesting to see what can come out of it.
« Reply #7 on: March 29, 2018, 04:12:55 PM »
« Reply #8 on: January 18, 2019, 07:11:53 PM »
« Reply #9 on: March 17, 2019, 12:27:44 PM »
