Author Topic: roland d-70 (1990?) super LA synthesizer  (Read 19739 times)
« on: December 02, 2015, 10:47:38 PM »
Roland D70
http://www.vintagesynth.com/roland/d70.php
http://www.synthmania.com/d-70.htm
http://www.muzines.co.uk/articles/roland-d70/383
https://www.sweetwater.com/sweetcare/articles/roland-d-70-compatible-sound-cards/
The following sound cards were made specifically for the D-70. They are no longer available:
PN-D70-01 – The Global Collection which uses only internal D-70 waveforms
PN-D70-02 – This card is a parameter card designed to be used with the SN-SPLA-01
SN-SPLA-01 – This is a dedicated PCM card with many sampled synthesizer waveforms.
SL-D70-01 – This is a two card set including both a PCM Waveform card and a Parameter Data card.
NOTE: The SN-U110 series and SN-MV30 series cards were also compatible. The D-70 will only read the 1st Partial of any Tone on these cards so Dual, Detuned, Velo Mixed and Velo Switched Tones will only play back as Single Tones.
NOTE: The following cards, or individual card Tones, are not compatible with the D-70. SN-U110-10 Rock Drums is not compatible. The Rhythm Kits on SN-U110-02 Latin Percussion do not work but the individual Tones do. Finally the SN-U110-08 Synthesizer card has Tones that are already found in the D-70’s internal ROM.
NOTE: The D-70 does not work with D-50 parameter cards. The D-70 uses RS-PCM sample playback as its synth engine while the D-50 uses LA synthesis technology.
« Last Edit: January 10, 2019, 01:26:21 AM by chrisNova777 »
Re: roland d70 (1990?)
« Reply #1 on: June 23, 2017, 08:30:34 PM »
Re: roland d-70 (1990?)
« Reply #2 on: December 12, 2018, 08:39:46 AM »
