Author Topic: 19" akai s612 (1985) 12 bit MIDI digital sampler  (Read 38664 times)
article, december 1985
« Reply #1 on: June 20, 2017, 12:02:09 AM »
THE NEED
THE SET-UP
EASY DOES IT
LOOPY TUNES
Re: akai s612 (1985) 12 bit MIDI digital sampler
« Reply #2 on: January 07, 2019, 11:08:13 PM »
« Reply #3 on: January 18, 2019, 08:17:59 AM »
akai s612 sampler
The S612 captures sound.
FITTING IN
FRONT
THE SLIDER
BACK
CONCLUSION
« Reply #4 on: January 20, 2019, 07:04:56 AM »
« Reply #5 on: January 30, 2019, 04:41:26 PM »
« Reply #6 on: March 03, 2019, 07:23:31 AM »
« Reply #7 on: July 09, 2020, 08:28:51 PM »
