Author Topic: UAD-1 "StudioPak"  (Read 8650 times)
UAD-1 "StudioPak"
« on: July 27, 2016, 08:31:10 PM »
http://www.sweetwater.com/store/detail/UAD1StudioPak/
DSP Power And So Many Plug-Ins, It's Scary!
The UAD-1 DSP Card Studio Pak gives you 20 Universal Audio plug-ins, PLUS the power to run them at maximum strength on your PC! When you buy the UAD-1 card, you're buying a collection of some of the most powerful processing plug-ins you've ever worked with.
Take a Load Off of Your CPU
The UAD-1 card features a floating point processor, which means there's no drain on your CPU. It gives you plenty of power to run the plug-ins to their fullest! Tons of ultra-fast memory (4 Megabytes of 1200 Megabytes/second) means smoother reverbs and delay lines. The UAD-1 has the excess bandwidth to manage the DMA controller without hitting the host processor.
UAD-1 Studio Pak Features:
Bus mastering DMA for zero host load and maximum transfer rate
Fully PCI 2.1 Compliant, supports 66MHz and fast bus timing
7" form factor (PCI short card)
Single Unpartitioned Super-computer DSP Chip
More DSP Headroom-per-Plug-In than other Multi-Chip DSP Cards
Supported Sampling Rates from 32 kHz - 192 kHz
The plug-ins? A comprehensive, four star menu that any artist creating music on computer would drool over!
UAD-1 Studio Pak Plug-ins Include:
RealVerb Pro: The world's most coveted reverb plug-in (developed by Kind of Loud)
Dreamverb: Universal Audio's flagship reverb
1176LN and 1176SE: Analog classic limiting amplifiers!
LA-2A: Vintage compression, rich in heritage!
CS-1 Channel Strip: Made up of plug-ins developed specifically for the UAD-1, including EQ, compression, delay modulation, and reflection engine modules.
Nigel: Delivers a complete pallet of guitar tones with 7 modules that provide most every effect a guitar player might need.
Pultec Program EQ: The Pultec EQ has long been a choice of recording and mastering engineers for its ability to bring out individual frequency ranges without significantly altering other frequencies.
Fairchild 670 and 670M Compressors: Another recreation of an analog classic!
Cambridge EQ: Five bands of parametric or shelving eq, plus two comprehensive
Tech Specs
Manufacturer Part Number   UAD-1STUDIOPAK
Re: UAD-1 "StudioPak"
« Reply #1 on: April 15, 2017, 07:35:52 AM »
Can multiple UAD-1 devices be used?
Yes, the UAD software (v6.1 or lower) allows multicard use under Windows and Macintosh.
Up to four UAD-1/1e cards plus four UAD-2 cards can be used, for a total of 8 UAD cards, within one system
.[/quote
https://help.uaudio.com/hc/en-us/articles/206024206-UAD-1
