Author Topic: tascam pci-822 (1999?)  (Read 4033 times)
« on: August 19, 2016, 01:19:47 AM »
http://tascam.com/product/pci-822/downloads/
http://www.sweetwater.com/insync/tascam-pci-822/
http://tascam.com/product/pci-822/specifications/
compatible with windows 95 thru to XP, mac os 9
http://web.archive.org/web/20031208112154/http://www.tascam.com:80/product_info.php?pid=239&nav=computer_recording
The PCI-822 is a PCI-based interface card that includes everything you need to send digital audio and MIDI signals to your computer for recording and sequencing. It includes a TASCAM 8-channel TDIF interface for DTRS recorders and compatible equipment, a stereo S/PDIF interface for DAT recorders and CD players, and 32 channels of MIDI I/O for keyboards, synth modules and mixer automation. The PCI-822 supports 16-, 20- and 24-bit audio as well as 44.1 and 48kHz sampling rates. Plus, it includes Nemesys' GigaSampler LE so you can take advantage of powerful software-based digital sampling. The PCI-822 is also compatible with most digital audio and sequencing software applications, and can be installed to both Mac and PC computers. If you're using a TASCAM modular digital multitrack and want to get into the power of nonlinear hard disk recording and editing, the PCI-822 is the affordable, easy-to-use solution.
PCI-822
Interface Card
8-channel TDIF digital input & output
Stereo S/PDIF digital input & output
2x2 MIDI Interface (32 MIDI channels in/out)
Word Clock connector for sample rate syncronization
Macintosh and Windows compatible
The PCI-822 is a PCI-based interface card that includes everything you need to send digital audio and MIDI signals to your computer for recording and sequencing. It includes a TASCAM 8-channel TDIF interface for DTRS recorders and compatible equipment, a stereo S/PDIF interface for DAT recorders and CD players, and 32 channels of MIDI I/O for keyboards, synth modules and mixer automation.The PCI-822 supports 16-, 20- and 24-bit audio as well as 44.1 and 48kHz sampling rates.Plus, it includes TASCAM's GigaStudio 32 so you can take advantage of powerful software-based digital sampling. The PCI-822 is also compatible with most digital audio and sequencing software applications, and can be installed to both Mac and PC computers. If you're using a TASCAM modular digital multitrack or GigaStudio and want to get into the power of nonlinear hard disk recording and editing, the PCI-822 is the affordable, easy-to-use solution.
Re: tascam pci-822 (1999?)
« Reply #1 on: February 16, 2019, 11:22:05 AM »
apparently ive seen a listing saying that this pci-822 card was made specifically for a mixer known as the Tascam TM-D1000, so im guessing its probably frm the late 1990s aswell?
