Author Topic: Roland DJ-99  (Read 2090 times)
Roland DJ-99
« on: March 18, 2017, 05:36:35 PM »
https://www.roland.com/us/products/dj-99/
2-CHANNEL DJ MIXER
2-Channel 909 Special Edition Mixer
SPECIFICATIONSNominal Input Level (OUTPUT MASTER 0 dBu)CH1, CH2 CD (L, R): -13 dBu
CH1, CH2 LN (L, R): -17 dBu
CH1, CH2 PH (L, R): -61 dBu
CH1, CH2 DVS RETURN (L, R): -13 dBu
MIC IN: -40 dBuMaximum Input LevelCH1, CH2 CD (L, R): 6 Vrms
CH1, CH2 LN (L, R): 6 Vrms
CH1, CH2 PH (L, R): 0.04 Vrms
CH1, CH2 DVS RETURN (L, R): 6 Vrms
MIC IN: 0.6 VrmsMaximum Output Level (1 kHz, typ.)OUTPUT MASTER (L, R): +15 dBu
OUTPUT BOOTH (L, R): +15 dBu
PHONES: 31 mWRecommended Load ImpedancePHONES: 32 ohmsFrequency ResponseCH1, CH2 CD, LN, DVS RETURN: 20 Hz–20 kHz (+1/-2 dB)
MIC IN: 20 Hz–20 kHz (+1/-3 dB)Noise LevelCH1, CH2 LN (L, R)–>OUTPUT MASTER: 0.6 mVrms or less
CH1, CH2 PH (L, R)–>OUTPUT MASTER: 6 mVrms or less
* TRIM level: center, 1 k ohms terminated, MASTER level: max, IHF-A, typ.DistortionCH1, CH2 CD (L, R): 0.2 % or less
CH1, CH2 LN (L, R): 0.2 % or lessChannel EQ (typ.)HI: 10 kHz +12 dB– -12 dB
MID: 980 Hz +12 dB– -28 dB
LOW: 100 Hz +12 dB– -28 dBControllerCH1, CH2 Input selectors
CH1, CH2 MIC level knobs
CH1, CH2 TRIM level knobs
CH1, CH2 Channel EQ knobs HI
CH1, CH2 Channel EQ knobs MID
CH1, CH2 Channel EQ knobs LOW
CH1, CH2 Channel Fader curve adjustment knobs
CH1, CH2 Channel Fader reverse switches
CH1, CH2 CUE buttons
CH1, CH2 Channel Faders
CH1, CH2 LN/PH selectors
Crossfader
PFL/MASTER selector
PHONES level knob
MASTER level knob
BOOTH level knob
Crossfader curve adjustment knob
Crossfader reverse switch
Headphones Monitoring selectoIndicatorPOWER indicator
PFL/MASTER level meter
CH1, CH2 Channel Fader reverse indicators
CH1, CH2 CUE indicators
Crossfader reverse indicatorConnectorsMIC input jack: 1/4-inch phone type
PHONES output jacks: Stereo 1/4-inch phone type, Stereo miniature phone type
CH1, CH2 CD input jacks (L, R): RCA phono type
CH1, CH2 LN/PH input jacks (L, R): RCA phono type
CH1, CH2 DVS SEND jacks (L, R): RCA phono type
CH1, CH2 DVS RETURN jacks (L, R): RCA phono type
CH1, CH2 GND terminals
MASTER output jacks (L, R): 1/4-inch phone type
BOOTH output jacks (L, R): RCA phono type
POWER switch POWER connector Fuse holderPower Consumption22 WFuse RatingT315mAL250V (5 ⌀ x 20 mm)
