Author Topic: Kontakt 1.5.3 / Kompakt 1.0.8 / Intakt 1.0.3  (Read 2622 times)
Offline VMS
« on: November 07, 2016, 11:47:49 PM »
https://drive.google.com/file/d/0BwbJMWoSOroQd2o2TzZNQlJVcW8/view?usp=sharing
pw: company name in lowercase
they are all the latest version
(um...except Intakt, some people said there was a more updated version in Komplete 3
but as a legal product owner
i am sure 1.0.3 is the latest version that NI ever released for normal Intakt
it is a pity that Komplete 3 is nowhere to be found....)
kontakt 1 can save the patches in Kompakt/Intakt format automatically
unless you trick the save patches in Kontakt format in option
Intakt may pops out "Physical Memory is Getting Low!" warning if you have many RAM (>4GB ?)
(again, rumor has it that Intakt in Komplete 3 doesnt have this problem)
(some year 2005-2006 Intakt libraries from Zero G were released in v1.0.6 are problem-free)
Kompakt 1.0.8 update fixes  "Physical Memory is Getting Low!" problem
they dont support multi-core proccessing
kontakt 1 is 16 part multi-timbral
Kompakt is 8 part multi-timbral
Intakt is NOT multi-timbral
all Kompakt & Intakt libraries from Best Service, East West, Zero G
can be loaded by the original NI Kompakt / Intakt
provided that the libraries are registered.
(IMO, this is the best way to use those libraries
as you have a file browser for quickly switching patches)
they will catch host hotkey
pretty annoying IMO
someone posted on NI forum that using autohotkey to get rid of this
Import and Compatibility:
all of them are able to read AKAI CDs & GIGA directly
(non DFD, read into RAM)
such feature is gone since Kontakt 2
AKAI S-1000/S-3000
(make sure SCSI is used for virtual CD-ROM)
Battery 1
EXS (MK1 & MK2)
(even those additional content from logic pro X....)
Gigasampler
(version 1 & 2 only, 3 is not supported)
(shown as a folder)
Kontakt 1
(but importing K1 in Kompakt will get you a dialog sayin that's a kontakt patch
to get rid of that first create a custom Kompakt patch by importing a .wav
then using kontakt 1 to copy the samples to the kompakt patch which you just created
unless you trick the save patches in Kontakt format in option)
LM4
SF2
(might mapped wrongly if samples' names are too long, it seems to be SF2 's fault)
 (shown as a folder)
HAlion
(version 1 only)
AIFF, WAV
(from 8 to 32 bits with 44.1 -- 96 kHz)
Automation:
Kompakt
512 host automation in total for 8 instrument slots
(64 per slot
63 practically as Glide automation is not working  :'(
it you really need Glide automation
map that to midi CC manually using Kontakt 1)
(ctrl+right click)
support CC1, 7, 10, 64, 123 natively
other midi cc are NOT supported/assignable
unless you edit the patch by using kontakt
(external sources >midi cc)
many East West libraries have cc 11 programmed
if you want to
you can map midi CC to VST parameters (aka host automation) in your DAW
almost all DAWs have this feature.
Cubase:
Device Setup > Add device > generic remote
host automations are not named when the respective slot is empty
when you load a patch/audio file into the slot
the parameter names appear
if they don't
save the project and reopen it
(not very well named though
the following automation list may come in handy)
Intakt
14 host automation
other midi cc can be assigned manually by Ctrl+clicking the knobs
here is the host automation list for Kompakt which i found on NI forum
Main Vol
0 64 128 192 256 320 384 448
Main Pan
1 65 129 193 257 321 385 449
Main Tune
2 66 130 194 258 322 386 450
Reverb Size
3 67 131 195 259 323 387 451
Reverb Damping
4 68 132 196 260 324 388 452
Reverb Amount
5 69 133 197 261 325 389 453
Chorus Depth
6 70 134 198 262 326 390 454
Chorus Speed
7 71 135 199 263 327 391 455
Chorus Amount
8 72 136 200 264 328 392 456
Delay Time
9 73 137 201 265 329 393 457
Delay Feedback
10 74 138 202 266 330 394 458
Delay Amount
11 75 139 203 267 331 395 459
Master Filter Freq.
12 76 140 204 268 332 396 460
Master Filter Reso.
13 77 141 205 269 333 397 461
Master EQ Freq.1
14 78 142 206 270 334 398 462
Masrer EQ BW1
15 79 143 207 271 335 399 463
Masrer EQ Gain1
16 80 144 208 272 336 400 464
Master EQ Freq.2
17 81 145 209 273 337 401 465
Masrer EQ BW2
18 82 146 210 274 338 402 466
Masrer EQ Gain2
19 83 147 211 275 339 403 467
Master EQ Freq.3
20 84 148 212 276 340 404 468
Masrer EQ BW3
21 85 149 213 277 341 405 469
Masrer EQ Gain3
22 86 150 214 278 342 406 470
Group Vol
23 87 151 215 279 343 407 471
Group Pan
24 88 152 216 280 344 408 472
Group Tune
25 89 153 217 281 345 409 473
Group Filter Freq.
26 90 154 218 282 346 410 474
Group Filter Reso.
27 91 155 219 283 347 411 475
Glide
28 92 156 220 284 348 412 476
Group LFO Vol
29 93 157 221 285 349 413 477
Group LFO Pan
30 94 158 222 286 350 414 478
Group LFO Tune
31 95 159 223 287 351 415 479
Filter - LFO
32 96 160 224 288 352 416 480
Filter - Env
33 97 161 225 289 353 417 481
Group Vol-Velocity
34 98 162 226 290 354 418 482
Filter - Velocity
35 99 163 227 291 355 419 483
Filter - Key
36 100 164 228 292 356 420 484
Vol Env - Curve
37 101 165 229 293 357 421 485
Vol Env - Atk
38 102 166 230 294 358 422 486
Vol Env - Hold
39 103 167 231 295 359 423 487
Vol Env - Decay
40 104 168 232 296 360 424 488
Vol Env - Sus
41 105 169 233 297 361 425 489
Vol Env - Rel
42 106 170 234 298 362 426 490
Filter Env - Curve
43 107 171 235 299 363 427 491
Filter Env - Atk
44 108 172 236 300 364 428 492
Filter Env - Hold
45 109 173 237 301 365 429 493
Filter Env - Decay
46 110 174 238 302 366 430 494
Filter Env - Sus
47 111 175 239 303 367 431 495
Filter Env - Rel
48 112 176 240 304 368 432 496
Free Env - Curve
49 113 177 241 305 369 433 497
Free Env - Atk
50 114 178 242 306 370 434 498
Free Env - Hold
51 115 179 243 307 371 435 499
Free Env - Decay
52 116 180 244 308 372 436 500
Free Env - Sus
53 117 181 245 309 373 437 501
Free Env - Rel
54 118 182 246 310 374 438 502
Vol LFO - Freq.
55 119 183 247 311 375 439 503
Pan LFO - Freq.
56 120 184 248 312 376 440 504
Tune LFO - Freq.
57 121 185 249 313 377 441 505
Filter LFO - Freq.
58 122 186 250 314 378 442 506
Vol LFO - Key
59 123 187 251 315 379 443 507
Pan LFO - Key
60 124 188 252 316 380 444 508
Tune LFO - Key
61 125 189 253 317 381 445 509
Filter LFO - Key
62 126 190 254 318 382 446 510
Free Env - Amount
63 127 191 255 319 383 447 511
« Last Edit: November 20, 2016, 04:17:06 PM by VMS »
