Author Topic: 19" MusicQuest 8Port/SE parallel (Jun 1996) MIDI Interface win3.1/95 pc-only  (Read 11492 times)
MusicQuest 8Port SE
Distinctive Features
Footswitch/trigger input
Requirements
MIDI compatible instrument(s)
Music software
MIDI Interface
SMPTE Synchronization
Patchbay Operation
Software Compatibility
Multi-Client Windows Driver
Windows Patchbay Software
The included Windows Patchbay program allows the user to program, retrieve, and save 8Port/SE user programs; dynamically change MIDI routing and filter settings; and stripe and verify SMPTE tapes
Re: MusicQuest 8Port SE parallel MIDI Interface (Sep 1995) win3.1/95
« Reply #1 on: November 15, 2016, 10:40:30 AM »
further info from the readme
MIDIEngine 8Port/SE Notes
July 17, 1996
Driver version 1.5
CONTENTS:
: 8PSEDIAG Diagnostic Program
: Special Printer Port Notes
: 8FIXPORT Program
: 8Port/SE Sysex Commands
: Obtaining Technical Support
            -or-
1. Start Windows.
Drivers Icon.
'Restart Now'.
by default.
the 'Next' button.
and select Music Quest.
following:
corner of the window.
4. Exit File Manager.
subdirectory.
function.
warranty.
any system component.
>>>>>>>> Function
>>>>>>>> Running 8PSEDIAG
8PSEDIAG
and then press the ENTER key.
        or replace Print Manager
device=LEX01.386
;device=LEX01.386
of the printer port.
8FIXPORT Program
>>>>>>>> Function
>>>>>>>> Running 8FIXPORT
8FIXPORT
on this diskette.
>>>>>>>> Contact Us Directly
2000.
will not interface.
Microsoft Windows 98
Help topic in Regedt32.exe.
SYMPTOMS
RESOLUTION
Emergency Repair Disk (ERD).
00 00 to 00 00 00 00:
Type in Regedit and click OK.
“StaticVxD”=”*VCOMM”
“Start”=hex:00
Mike Vangen
Re: MusicQuest 8Port/SE parallel (Jun 1996) MIDI Interface win3.1/95 pc-only
« Reply #6 on: September 16, 2018, 07:43:26 PM »
« Reply #7 on: September 18, 2018, 11:25:06 AM »
check the manual
see this thread
MIDI ENGINE 8PORT/SE
Features
Requirements
Music software
MIDI Interface
Patchbay Operation
