Hardware > 1990s
PCI/AGP Graphics Cards Timeline - Mid 1990s - mid 2000s - mid 2010s
chrisNova777:
another way of perusing the graphic cards is by their direct x classification
newegg lists cards of a certain directx revision together
directx 9
DirectX 9 (DX9) was first released on December 19, 2002, with later significant updates like DX9.0c introducing Shader Model 3.0 in July 2004, becoming the standard for many Windows systems, including Windows XP Service Pack 2 and later. https://www.newegg.com/p/pl?N=100007709+600007813&srsltid=AfmBOoroAwKyFb9rHKbf5MlwMFdpvjSWBMY1xzVDLWOOK0FAeCFuitWh
directx 10
DirectX 10 was officially released on November 30, 2006, as part of the launch of the Windows Vista operating system,
https://www.newegg.com/p/pl?N=100007709+600007816&srsltid=AfmBOoqr6bnSOD8IvO6EWo0cEhx-PXtTnrS8fVB2WWRMfLGY1wGxyZ8t
directx 11
DirectX 11 was officially released on October 22, 2009
https://www.newegg.com/p/pl?N=100007709+600007818&srsltid=AfmBOoqDs-p5FpnPvX9lT9PpaYGmPj3hkDUm1N0Bkr735jkwckIv35DE
directx 12
released alongside windows 10 in July 2015
The latest version of DirectX is DirectX 12 Ultimate DirectX 12 is a graphics API supported by a wide range of modern GPUs from NVIDIA, AMD, and Intel. NVIDIA's GeForce RTX 30 series, RTX 20 series, and some GTX 16 series cards, along with AMD Radeon RX 6000, RX 5000, and RX 500 series, and Intel Arc series GPUs, all support DirectX 12. DirectX 12 Ultimate, the latest version, requires specific hardware support, including features like ray tracing and mesh shaders, and is available on NVIDIA's GeForce RTX 30 series, AMD's RDNA 2 architecture GPUs, and Intel Arc GPUs.
chrisNova777:
https://www.gpucheck.com/
chrisNova777:
A Mini HDMI (Type C) is a smaller version of the standard HDMI port, designed for portable devices like cameras, camcorders, and some tablets, allowing them to connect to larger displays (TVs, monitors) while delivering the same high-definition audio and video quality, often requiring a special cable or adapter to fit the standard Type A port.
Examples of Cards with Mini-HDMI:
NVIDIA GeForce: GTX 460, GTX 560 Ti, GTX 570, GTX 580, GT 640, GT 730, GTX 780 Ti.
AMD Radeon: Some older Radeon HD 7000 series models.
NVIDIA Quadro: Quadro K1200 (often with Mini DisplayPort too).
Why They Use Mini-HDMI:
Space Saving: Mini-HDMI takes up less physical room on the card's bracket, allowing for larger cooling solutions or additional ports like DVI.
Compact Designs: Common in smaller form-factor PCs (like Mini-ITX) or older generations where port standardization wasn't as unified as today.
&t=92
chrisNova777:
AMD Radeon RX 460 was released on August 8, 2016
https://www.techpowerup.com/gpu-specs/radeon-rx-460.c2849
GPU Variant Baffin PRO
https://www.reddit.com/r/Amd/comments/54jh03/luke_of_linus_tech_tips_reviews_xfxs_rx_460_or/
--- Quote ---Based on the provided search results, the AMD Radeon Pro 455 is a professional mobile graphics chip that utilizes the Baffin PRO variant of the Polaris 11 graphics processor. It was launched on October 30, 2016.
TechPowerUp
TechPowerUp
Key Specifications of the Baffin PRO (Radeon Pro 455):
Architecture: GCN 4.0 (14 nm process)
Shading Units: 768
TMUs: 48
ROPs: 16
Memory: 2,048 MB GDDR5
Bus Width: 128-bit
Engine Clock: 855 MHz
Memory Clock: 1270 MHz (5.1 Gbps effective)
TDP: 35 W maximum
TechPowerUp
TechPowerUp
+3
--- End quote ---
im using a Radeon RX460 that looks identical to that pictured above with my Hackintosh i7 4770K & 16GB DDR3 1600Mhz RAM and it works incredibly well for basically everything im trying to do, im using a 27" LG ULTRAFINE 60hz display (over displayPort) and another old 1080P LG monitor over DVI (dvi-to-hdmi cable) its natively supported i didnt have to do anythign at all to make it recognized properly its just worked fantastic since i put it in. apparently the 460 blows away the 550 and pre-dates it by just over half a year. The AMD Radeon RX 460 was released on August 8, 2016
chrisNova777:
seeing prices drop to under 200$ for this card, would be a great card for an intel hackintosh
https://elitemacx86.com/threads/amd-gpu-compatibility-list-for-macos.617/
Navigation
[0] Message Index
[*] Previous page
Go to full version
