Author Topic: kawai MAV8 patchbay/merger  (Read 971 times)
« on: May 12, 2017, 06:02:38 AM »
https://www.kawaius-tsd.com/OM/MODULE~1/MAV8.pdf
http://www.kawai.co.uk/mav8.htm
The MAV-8 is a 4x8 patchbay as rack device (19"). Each of the 8 outputs can be linked or switched off to one of the 4 inputs. The setting can be effected over slides, so that you have also a visual control of it.
3 MIDI inputs and 7 outputs are situated on the rear to minimize the cabling. For the quick change 4 inputs and 8 outputs are situated on the front.
The easily understood switch matrix can be served very simple.
Therefore is the MAV-8 an indispensable and an very inexpensive helper in your daily fight with the MIDI connections.
A mains adapter is included.
« Last Edit: February 03, 2018, 03:08:27 AM by chrisNova777 »
