Author Topic: Roland DJ2000 (1998?)  (Read 1766 times)
« on: July 21, 2017, 06:14:51 AM »
Roland dj2000
http://priyonjoni.blogspot.ca/2013/09/remember-roland-dj2000-dj-mixer.html
https://www.sweetwater.com/sweetcare/articles/roland-dj-2000-technical-specification/
DJ-2000 PROFESSIONAL MIXER
EFFECTS:
Delay, Flanger, Overdrive + Delay, Overdrive + Flanger, Auto Pan Filter Robot
, Voice, Tranformer, Slicer, Jao
CH. SELECT:
Mic1, Ch1, Ch2, Ch3, Ch4,
Master
Freq. Range Select :
Low, Mid, High , Full
Sync, Type Select :
1/16, 3/8, 1/8, 3/41/4, 1/2, 1, 2, 4,
Effect Balance
Direct to Effect
Frequency Response ;
20 Hz to 20 kHz +1bB (GAIN =min)
Total Harmonic Distortion :
0.05% or less (Input Sens:-20Hz to 20kHz at nominal output level)
S/N Ratio :
80 dB (Input : 150 ^ terminated,lll-A Typ
Crosstalk ;
-70 dB or Less (1 kHz,between channel/between L and R )
Equalizer : :
High: + 16dB (12kHz,Shelving type)
Mid : +16dB(2kH,peaking Type),
Low:+16dB(40Hz,Shelving type)
Isolater :
High/Mid/Low:-00 to
12dB
Connectors
Mic Ins 1 (XLR,unbalanced,and 1/4″ unbalanced)
Mic In 2 ( 1/4″ unbalanced, Line Ins 1 to 5 (RCA),Phono Ins 1 to 3
(RCA),
Effect Send and Return (1/4″ ), Master Outs (1/4″ and RCA), Phones
out
Power Supply
AC117v
/230v/240v
Power Consumption
35 W
Dimensions
482 (W) x 311 (D) x 112 (H)mm/19×12-1/4×4-7/16in.
Weight
6.8 kg/15Lbs
