WOW...And all these problems on windows 7?...You would think you would not have these issues but seems like old Image-Line stuff that way....
Even here on XP not everything Peaches & Cream....
By the way thanks for that 3.56 but it is same as I have had before...Installs & run fine but no WAV render for me, earlier version 3 (3.1 & 3.3) seem fine but if there's a crash on rendering to WAV or other roadblock then I must delete registry entry-
HKEY_CURRENT_USER\Software\FruityLoops 3
Some corruption happens there on crash, delete fixes but prefs must be redone...
Reg info is not stored there but under-
HKEY_CURRENT_USER\Software\Image-Line\Registrations\FruityLoops 3
But for you I don't think deleting that first entry would help at all...
Might be best to just get an old laptop for 20 bucks that has XP on it...The whole 'compatibility mode' settings are complete bullshit & in all my years I've never had changing them make any difference at all....
One thing you could try is changing your DirectX version running Fruity then change back when running everything else...
I had to do this to install Cakewalk SONAR 2 as it said I did not have DX8...NO SHIT! I had DX9 but after changing version number for install then changing back AFTER install no problem running...
Problem with Fruity is that it is CHECKING version number in registry...
So HERE is my reg entry BEFORE installing SONAR-
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectX]
"Version"="4.09.00.0904"
So I find valid DX8 entry & change to-
REGEDIT4
"Version"="4.08.01.0810"
Then it install fine & after I just change back to first one...
This done by saving these as .REG files then Double-click to enter one or the other...
This means you's have to Dbl-Clk a reg file before using Fruity then when done Dbl-Clk a reg file to get back to stock entry...
You just need to find a valid DX5 version number....
Other than that maybe Fruity is past using at least these old versions...But, BUTT! I GET IT!! They are nostalgic & very fun to use...YES!...But other old soft sound better...
Say like Aero Studio it's from 2003 but sound real good I just attached a SHORT audition video of just samples in the sampler units sounds great to me-
VIEW IT-
http://www.oldschooldaw.com/forums/index.php?action=dlattach;topic=2053.0;attach=11752Sequential Vibes from 2003 & sounds good too...
Fruity started sounding OK at version 3.3 but really started to shine at 5...
I will post the version 5 soon...maybe try that one...
