Author Topic: FirmTek SeriTek/1VE4 (for mac os 9/X ppc users)  (Read 2322 times)
Online chrisNova777
« on: October 23, 2014, 09:17:48 PM »
http://www.firmtek.com/seritek/seritek-1ve4/
Specifications
General System Hardware Requirements
    PCI based Power Macintosh with available PCI expansion slot
    PCI-X 1.0a compliant 64-bit at 133/100/ 66MHz bus speeds. Backward compatible with standard 32/64-bit PCI at 33MHz and 66MHz bus speeds
Operating Systems Supported
    Mac OS 9.xx
    Mac OS X version 10.1.5 or later (works best with 10.2 or later)
Bus Types
    32/64 bit, 33/66MHz PCI
    133/100/66MHz PCI-X
    Compliant 32-bit PCI bus version 2.2
    Compliant with PCI-X bus version 1.0a
External Connectors
    4-port special sheilded external Serial ATA (SATA) interface connectors support up to 4 external hard drives
Drive Types Supported
    Serial ATA hard drive
    Backward compatible with Ultra DMA 133/100/66 hard drives*
ATAPI Device Support
    Yes*
Data Transfer Rates
    Up to 150 MBytes/second or 1.5Gbits/second burst data transfer rate
Drive Modes Supported
    Serial ATA
    UltraDMA modes 6/5/4/3/2/1/0
Advanced Data Features
    Fully compliant with Serial ATA 1.0a specification
    Bus Mastering off-loads data I/O handling from CPU
    Complete 32-bit CRC error checking, for all bits transmitted (command, data, and status), offers enhanced data protection for high-speed Serial ATA drives
    Dual independent data channels allows for separate device timings
    Automatically identifies and configures drive types*
    Automatically detects and supports devices utilizing many transfer modes including UltraDMA 6/5/4/3/2/1/0
Onboard Flash ROM
    Allows easy upgrades to the latest firmware
Cables Supported
    7-pin SATA cable
Warranty
    Two year limited parts & labor
Physical Dimensions
    163mm(L) x 1.6mm(W) x 64.4mm(H) (not including bracket)
Power Requirements
    5V ± 5%
Environmental
    Temperature:
    Operating:    +5°C to +55°C
    Non-Operating:    -25°C to +70°C
    Relative humidity:
    Operating:    20% to 80%
    Non-Operating:    15% to 90%
EMC Compliance
    EN55022/1998, EN55024/1998 (European Community)
    FCC Part 15 Class B (US)
    RoHS Compliant
« Last Edit: October 23, 2014, 09:26:04 PM by chrisNova777 »
