Author Topic: korg D16 (2000) digital recording studio  (Read 5282 times)
« on: August 21, 2017, 05:39:44 AM »
https://web.archive.org/web/20000302142530/http://www.korg.com:80/d16.htm
https://web.archive.org/web/20000301203438/http://www.korg.com:80/d16spec.htm
http://www.emusician.com/gear/1332/korg-d16/31720%20korg%20d16%20digital%20recording%20studio
Recorder Section
Tracks: 128 tracks (including virtual tracks), 16 tracks simultaneous playback, 8 track simultaneous recording @16bit, 8 tracks simultaneous playback, 4 track simultaneous record-ing @24bit
Recording Format: 24bit/16bit uncompressed, 44.1kHz
Recording time: 6.5 hours maximum (one track, when using internal 2.1Gbyte hard disk)
Maximum Recording Capacity: Internal + 1000 Gbyte x 7 drives
Songs: 100 songs
Locate Points: 4 points per song
Mark Points: 100 points per song
Metronome/Rhythm Patterns: 96 / 200 patterns (PCM sound generator)
MIDI Synchronization: Transmitted (MTC, MIDI Clock), Received (MMC, Scene change), Tempo Map (100 event per song), Sync Track (1 track per song)
Editing: Track (Copy, Insert, Erase, Swap, Delete, Reverse, Optimize, Time Expansion/Compression; Tracks can be copied between songs.), Song (Copy, Move, Delete, Rename, Protect)
Counter/Locator Format: Min/Sec/mSec (with reset), Min/Sec/mSec (without reset), Meas/Beat/Tick, Min/Sec/ Frame (30 NDF only)
Mixer Section
Structure: 24 channel 8 bus, 1 AUX, 1 MASTER
Signal Processing: 32 bit 44.1kHz
Equalizer: High (f:10kHz G: ±15dB), MID (f:20Hz-20kHz G: ±15dB), LOW(f:100Hz G: ±15dB)
Scene Memory: 100 scenes per song
Multi-Effect Section
Structure: Insert x 8 (max.), Master send x 2 (max.), Master total x 1 (max.)
Signal Processing: 44 bit 44.1kHz
Programs: Insert (128 preset, 128 user), Master send total (32 preset, 32 user) Overall (32 preset, 32 user)
Chains: 98 types
Effects: 106 types
General
Display: 240 x 64 dots, LCD with backlight/touch panel
Power Supply: AC9V AC/AC power supply
Power Consumption: 18W (AC 9V 2.0A max)
Dimensions: 357mm(W) x 245mm(D) x 72mm(H)/14.06"(W) x 9.65"(D) x 2.84"(H)
Weight: 2.0 kg / 4.4 lbs.
Main Formats:
Frequency Response: 10Hz -20kHz ± 1dB @+4dBu, 10k-ohm load
S/N: 100dB (Standard) @IHF-A
Dynamic Range: 100 dB (Standard) @IHF-A
THD+N: 0.02% (Standard) 20Hz - 20kHz @+16dBu, 10k-ohm load
A/D Conversion: 24 bit linear 64 times oversampling
D/A Conversion: 24 bit linear 128 times oversampling
Sampling Frequency: 44.1 kHz
Analog/Digital Input / Output Formats
LINE, MIC INPUTS 1,2:
Connector: XLR-3-31 type, 1/4" TRS phone jack (balanced)
Input Impedance: 10 k-ohm
Nominal Level: -60 dBu @TRIM=max., +16 dBu @TRIM=min.
Maximum Level: -48 dBu @TRIM=max., +16 dBu @TRIM=min.
Source Impedance: 600 ohm
LINE, MIC INPUTS 3,4,5,6,7,8:
Connector: 1/4" TRS phone jack (balanced)
Nominal Level: -60 dBu @TRIM= max., +4 dBu @TRIM=min.
GUITAR INPUT:
Connector: 1/4" phone jack (unbalanced)
Input Impedance: 1 M-ohm
Nominal Level: -60 dBu @TRIM=max., +4 dBu @TRIM=min.
Max. Level: -48 dBu @TRIM=max., +16 dBu @TRIM= min.
MASTER OUTPUTS L/R & MONITOR OUTPUTS:
Connector: RCA pin jack
Output Impedance: 150 ohm
Nominal Level: -10 dBu
Maximum Level: +2 dBu
Load Impedance: 10 k-ohm or greater
AUX OUTPUT:
PHONES OUTPUTS:
Connector: 1/4" stereo phone jack (unbalanced)
Output Impedance: 100 ohm
Maximum Level: 50 mW @32 ohm
DIGITAL INPUT/OUTPUT:
Connector: Optical
Format: 24 bit S/P DIF (IEC60958, EIAJ CP-1201)
SCSI:
Connector: D-sub 25pin female
Format in accordance with SCSI-2
MIDI IN/OUT:
Connector: DIN 5 pin x 2
FOOT SW:
Connector: 1/4" phone jack (use an optional PS-1)
EXPRESSION PEDAL:
Connector: 1/4" stereo phone jack (use optional XVP-10 or EXP-2)
AC9V IN:
Connector: DIN 4 pin
Accessories:
AC/AC power supply
Re: korg D16 (2000) digital recording studio
« Reply #1 on: April 12, 2018, 09:24:53 PM »
