Author Topic: running a socket 370 tualatin cpu on a slot 1 intel i440bx motherboard  (Read 10454 times)
click here to search all products on ebay
abit be6
the following info is related to achieving best performance (above 1ghz with coppermine or tualatin cpu) on an older Pentium iii motherboard
some of these boards have ISA slots That allow us to use ISA peripherals... thats my reason for finding out this info..
to be able to use my  "Winman 4x4/s" midi interface
LinLin
http://www.hardwarecentral.com/showthread.php?172281-RESOLVED-Upgrading-A-FCPGA-Socket-370-With-Adaptor-To-Use-FCPGA2-Tualatin-Processor
SlotKet
http://en.wikipedia.org/wiki/Slotket
Slot-T
http://web.archive.org/web/20060314140253/http://www.upgradeware.com/english/product/slott/compatibility.htm
http://duhvoodooman.com/powrleap/lfl/slot-t_1.htm
powerLeap
http://tweakers.net/nieuws/19405/powerleap-pl-ip3-t-review.html
http://www.powerleap.com/
http://www.powerleap.com/pdf_files/PL-iP3T.pdf
http://www.megaoverclock.it/PLIP3TTRE.html
tested on an Asus P3B-F
https://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fwww.ixbt.com%2Fcpu%2Fpowerleap-ip3-t.shtml
http://www.powerleap.com/PL_iP3T_troubleshooting_08.html
Code: [Select]
ABIT">ABIT
                                    Acer">Acer
                                    Albatron">Albatron
                                    Alienware">Alienware
                                    Amptron">Amptron
                                    Aopen">Aopen
                                    ASRock">ASRock
                                    ASUS">ASUS
                                    ATC">ATC
                                    Atrend">Atrend
                                    AT&T">AT&T
                                    Averatec">Averatec
                                    Biostar">Biostar
                                    Chaintech">Chaintech
                                    HP/Compaq">Compaq
                                    Dell">Dell
                                    DFI">DFI
                                    ECS">ECS
                                    eMachines">eMachines
                                    Epox">Epox
                                    FIC">FIC
                                    Foxconn">Foxconn
                                    Fujitsu-Siemens">Fujitsu-Siemens
                                    Gateway">Gateway
                                    Gigabyte">Gigabyte
                                    HP/Compaq">HP
                                    IBM">IBM/Lenovo
                                    Intel">Intel
                                    Iwill">Iwill
                                    Jetway">Jetway
                                    Medion">Medion
                                    Micron">Micron
                                    Micronics">Micronics
                                    MSI">MSI
                                    NEC">NEC
                                    Packard Bell">Packard Bell>
                                    PCChips">PCChips
                                    QDI">QDI
                                    Quantex">Quantex
                                    SGI">SGI
                                    Shuttle">Shuttle
                                    Soltek">Soltek
                                    Sony">Sony
                                    Soyo">Soyo
                                    Supermicro">Supermicro
                                    Syntax">Syntax
                                    Tekram">Tekram
                                    Tiny">Tiny
                                    Toshiba">Toshiba
                                    Trigem">Trigem
                                    Twinhead">Twinhead
                                    Tyan">Tyan
                                    VIA">VIA Technologies
                                    Winbook">WinBook
http://www.motherboards.org/forums/viewtopic.php?p=520886&highlight=#520886
click here for adapters on ebay
« Last Edit: November 11, 2014, 08:15:43 PM by chrisNova777 »
