Author Topic: Midisport 2x4 (2003?)  (Read 2794 times)
« on: November 08, 2017, 12:43:13 AM »
https://web.archive.org/web/20040225141331/http://www.m-audio.ca:80/EngSite/EngProfolder/EngMIDIIntpages/EngMidiSp2x4.html
The USB MIDISPORT 2x4 is a compact bus-powered, multi-port MIDI interface for USB-equipped PC and Mac computers that’s perfect for laptop music-making. The unit’s 2 x 4 architecture also lets you go beyond the MIDI spec’s limit of 16 channels. Two separate 16-channel input ports allow your system to accept up to 32 discrete MIDI input channels. And four individual 16-channel output ports allow you to address up to 64 discrete MIDI output channels.
USB MIDISPORT 2x4’s high-speed USB connection to the computer assures reliable, immediate MIDI transfers. Installation is a breeze—no computer disassembly, no jumpers to set, no I/O addresses, IRQ’s or DMA channels to configure. Expansion is just as easy—just plug additional USB MIDISPORT units into your computer for more MIDI ports.
MIDIsport 2x4
Operating mode:
• USB mode provides discrete 2x4 routing via software.
• Standalone mode routes input 1 to outputs 1 & 2; input 2 to outputs 3 & 4.
Midisport 2x4 Features:
• 2-in/ 4-out MIDI interface.
• Accepts up to 32 discrete MIDI input channels.
• Addresses up to 64 discrete MIDI output channels.
• Expands easily by combining MIDISPORT interfaces.
• High-speed connection to USB-equipped PC or Mac computers.
• MIDI activity indicators for each port.
• Bus-powered—requires no external power supply.
• Includes 6’ USB cable.
• Windows compatible—true Plug-and-Play installation requires no IRQ, I/O Address or DMA channel setup.
• Includes Mac OMS drivers for OS 9.x.
• Compact and lightweight for mobile or desktop use.
• Power derived from USB bus.
Dimensions:
• Size: 18.5cm (w) x 10.8 cm (d) x 3.5 cm (h)
• Weight: 0.45 kg.
Minimum System Requirements for PC:
Windows 98SE, Windows ME, Windows 2000, Windows XP
Minimum System Requirements for Macintosh:
OS 9.1 and higher, or OS 10.1 and higher; OMS under OS 9 (included)
