Author Topic: M-audio Lagoon (1999?)  (Read 3282 times)
« on: November 27, 2017, 02:47:47 AM »
https://web.archive.org/web/20000711230300fw_/http://www.midiman.com:80/Html/products/lagoon.html
http://web.archive.org/web/20010211105719/http://www.midiman.net:80/m-audio/html/dr/drlagoon.htm
https://web.archive.org/web/20000229105308fw_/http://midiman.net:80/product.HTM
Lagoon
ADAT PCI Digital Recording Interface
 (msrp: $499.95)
24 Bit 96 kHz Optical Digital I/O With ADAT Sync and Synth
The long-awaited Lagoon fills the need for a high-performance ADAT optical I/O card, but with several twists. First, the card supports ADAT optical and S/PDIF optical I/O with word widths up to 24 bits and sample rates up to 96kHz. Secondly, “mixed modes” of operation are available in which the Lagoon offers ADAT input and S/PDIF output, or S/PDIF output with ADAT input. This allows for mixed mode transfers and mastering direct from ADAT to S/PDIF. ADAT sync is provided, and when not in use can alternately be configured as a midi interface. As an added surprise, the Lagoon card also harbors a virtual analog synthesizer that runs on Lagoon’s built-in DSP. Capable of duplicating hundreds of retro sounds from the era of vintage analog synths, this virtual synth adds an element that will surely spice up your music-making arsenal.
Features
• Low profile PCI card (requires PCI BIOS version 2.1).
• Operates in Full Duplex for simultaneous record and playback.
• Onboard Motorola 56301 running at 80 MHz, delivering 80 MIPS computing power.
• Onboard 768 kByte fast EDO-DRAM to ensure reliable audio streaming and effects.
• Onboard DSP supports downloadable audio effects and processing.
• 1 Toslink Optical In and 1 Toslink Optical Out supports the following I/O modes:
• ADAT 8-Channel Optical
All ADAT word widths up to 24 bit
ADAT sample rates from 39 kHz to 51 kHz
• S/PDIF Optical (All word widths up to 24 bit)
Sample rates: 32 44.1 48 64 88.2 96 kHz
Consumer or Professional mode
• Mixed mode: S/PDIF In and ADAT Out or ADAT In and S/PDIF Out
ADAT Sync In or MIDI Options via 9-pin DB connector supports:
Sync In using standard Alesis ADAT Sync cables.
1 In and 1 Out MIDI Interface.
• Uses supplied break out cable to connect to MIDI devices.
• Allows for MTC or MIDI clock synchronization through user application software.
Synth Features
• Monophonic operation.
• 2 tunable oscillators per voice.
• 2 ADSRs.
• ADSR envelopes for volume and filter.
• LFO with selectable waveforms (saw, square, triangular, or pulse).
• LFO may effect volume and/or cutoff.
• 24db resonant low pass filter with tunable cutoff, resonance, and key tracking.
Minimum System Requirements
Windows 95 or 98
Pentium 166 or higher with MMX,
200 MHz recommended.
32 MB RAM, 64 MB recommended.
