Author Topic: Akai D1  (Read 1661 times)
Akai D1
« on: January 30, 2018, 01:51:18 PM »
https://web.archive.org/web/20021228123903/http://www.akaipro.com:80/consumersite/productpage.asp?id=83&section=
*** USA Models Only ***
D1 - Shred-O-Matic
Tube / Solid -State Hybrid Distortion
The Akai Shred-O-Matic offers mind-bending 12AX7A tube and diode distortion in one unit. Using Shred-O-Matic's MIX function in either TUBE or DIODE mode allows player dynamics to customize the distortion. When playing softly, the signal is routed only through the tube section, resulting in a mellow, low-level distortion. Harder playing will mix the warm, low-level output of the tube section with the screaming output of the diode section. For maximum flexibility, two user selectable modes are also available, SMOOTH, providing a gradual change between tube and diode and PASSION, providing an abrupt change.
Shred-O-Matic features easy-to-see and easy-to-use controls including output level control and LED indicator for distortion mode. The foot switch turns the effects on and off and when the unit is off, and the internal circuitry allows the signal to bypass the unit, without coloring the sound. The Shred-O-Matic's foot pedal provides total control of either the output level or the drive level. Additionally, while operating in the MIX mode, the pedal can be used to switch between tube and diode distortion.
   Mind-bending 12AX7A tube sound plus diode distortion in one pedal
   Pedal allows dynamic control of drive level, output level, and the ability to mix tube and diode distortion for shred customization
   The Shred-O-Matic allows you to choose between 4 distortion modes:
TUBE - Provides the warm, fat sound of tube distortion
DIODE - Provides the harder, edgier sound of diode distortion
MIX - In both modes the mix is determined by player dynamics. When playing softly, the signal will be routed only through the tube section, resulting in a mellow, low-level distortion. Harder playing will mix the warm, low-level output of the tube section with the screaming output of the diode section. Two modes are available;
SMOOTH - Gradual change between tube and diode
PASSION - Abrupt change between tube and diode
   Pedal Assign - Selects the Foot Pedal assignment. In DRIVE, the Pedal controls the distortion level In OUTPUT, it controls the volume of the output signal
   True Bypass
