Author Topic: Asus p5pe-vm (2006)  (Read 4515 times)
    • View Profile
Asus p5pe-vm (2006)
« on: March 04, 2018, 07:11:25 PM »
https://www.asus.com/ca-en/Motherboards/P5PEVM/
https://www.asus.com/us/Motherboards/P5PEVM/specifications/
http://www.insanelymac.com/forum/topic/206555-success-iatkos-v7-on-asus-p5pe-vm/
https://mattgadient.com/2008/03/16/the-kalyway-osx-1052-install-experience/
CPU
LGA775 socket for Intel®Pentium D/Pentium 4/Celeron CPU
Compatible with Intel® 05B/05A and 04B/04A processors
Support Intel®EM64T/Hyper-Threading Technology
(note. This motherboard does not support Intel Pentium® Processor Extreme Edition. )
Chipset
Intel 865G
Intel ICH5
Front Side Bus
1066/800/ 533 MHz
(FSB1066 for external graphic, FSB800 for internal graphic)
Memory
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR SDRAM memory
VGA
Intel® Extreme Graphics 2
Expansion Slots
1 x AGP 8X
3 x PCI
Storage/RAID
ICH5 South Bridge:
2 x UltraDMA 100/66/33
2 x Serial ATA
USB
Max. 8 USB2.0 ports
Audio
ADI 1888 6-Channel AC'97 Audio CODEC
Audio Sensing Technology
LAN
Marvell 88E8001 GB LAN
Other ASUS Special Features
MyLogo
CrashFree BIOS2
EZ Flash
ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x Parallel
1 x COM1
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x 6-Channel Audio I/O
1 x RJ45
4 x USB 2.0/1.1
Internal I/O Connectors
2 x USB 2.0 connector supports additional 4 USB 2.0 ports
CPU/ Chassis FAN connectors
CD audio in connector
Front Panel Audio connector
20-pin ATX Power connector
4-pin ATX 12V Power connector
BIOS
4 Mb Flash ROM, AMI BIOS, PnP, DMI2.0, WfM2.0
Support Disc
Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS LiveUpdate Utility
Accessories
1 x Serial ATA cable
1 x Serial ATA power cable (For one devices)
1 x UltraDMA 100/66 cable
1 x FDD cable
I/O shield
User's manual
Form Factor
uATX Form Factor, 9.6" x 7.6" (24.5cm x 19.3cm)
    • View Profile
Re: Asus p5pe-vm (2006)
« Reply #1 on: March 05, 2018, 03:26:05 PM »
http://webcache.googleusercontent.com/search?q=cache:Q_FmFFzmOz8J:www.insanelymac.com/forum/topic/206555-success-iatkos-v7-on-asus-p5pe-vm/+&cd=1&hl=en&ct=clnk&gl=ca
After many unsuccessful attempts with iPC 10.5.6 and iDENEB 10.5.6, I have successfully installed iATKOS v7 (10.5.7) on Asus P5PE-VM. Thought I would share the news in case others are having similar problems.
My System:
-Asus P5PE (Intel 865G, Intel ICH5)
-nVidia 6600 GT VGA Graphics
-On-Board Marvell 88E8001
-On-Board ADI 1888 6-Channel AC'97 Audio
-Two IDE hard drives
-Two SATA hard drives
-Two IDE DVD Writers
I installed to one of the IDE hard drives.
As best I can remember the options I selected at installation were:
-iATKOS v7 Main System
-Chameleon v2
-/Extra directory
-DSDT
-AppleDecrypt
-Disabler
-EFI string for nVidia::DVI/VGA
-Intel SATA/IDE
-Voodoo HDA driver (This didn't end up working so I installed AppleAC97
-Marvell Yukon 88E8001
-Post-Install Actions
I had three problems after installation:
1. I could only boot successfully with the 'cpus=1' flag. I fixed this by setting the 'Execute Disable Function' to 'Enabled' in the bios.
2. Audio didn't work. I simply installed AppleAC97Audio.kext from my old Kalyway 10.5.2 installation, and presto it worked!
3. I can't change the resolution. Using "Graphics Mode" has not effect. I couldn't find a fix for this and decided it wasn't really a problem since it correctly found the max resolution of my tv (1920x1080x32) and runs flawlessly at that res.
I was able to upload to 10.5.8 directly from Software Update without any problems.
Graham
