Author Topic: v9 is the last 32-bit version of Ableton Live  (Read 549 times)
« on: November 13, 2018, 06:30:36 AM »
https://help.ableton.com/hc/en-us/articles/115001398390-Live-32-bit-discontinued
Live 32-bit discontinued
    Operating System: All
    Live Versions: 1 - 9
Due to persistent out-of-memory crashes during use, Live 9 is the last version of Live which will be available in 32-bit. Live versions 10 and onwards are available in 64-bit only. It is possible to install two instances of Live on your computer in case you still need to continue using a 32-bit version of Live.
Note: The 32-bit version of Live 9 will remain permanently available to download in your User Account.
The 32-bit version of Live (like all 32-bit applications) can use a maximum of 4GB of RAM only, which can quickly be exceeded when using large multisamples or memory-hungry plug-ins, resulting in crashes. In contrast, the 64-bit version of Live can use a theoretical maximum of 16 exabytes of RAM - much more RAM than computers actually have. This means you can work with Live Sets that are much larger and more memory-intensive than in the 32-bit version.
Legacy Plug-ins: If you are using legacy 32-bit plug-ins, please read our articles on using JBridge or 32 Lives to bridge plug-ins on Windows and Mac.
Further reading: For more information check our 64-bit vs. 32-bit FAQ.
more system requirements info here:
https://help.ableton.com/hc/en-us/sections/115000582970-System-Requirements
