Author Topic: JX-3P Software Synthesizer requires 10.11 el capitain  (Read 423 times)
Online chrisNova777
« on: December 22, 2018, 10:54:49 PM »
https://www.rolandcloud.com/catalog/legendary/jx-3p
Specifications
Maximum Polyphony   8 voice
LFO   WAVEFORM (SIN, SQR, RANDOM)
Rate
Delay
KEY TRIGGER SW(ON, OFF)
TRIGGER ENVELOPE SW(ON, OFF)
DCO-1   WAVEFORM (SAW, SQR, PULSE)
RANGE (64', 32', 16', 8', 4', 2')
LFO MOD
ENV-1 MOD
DCO-2   WAVEFORM (SAW, SQR, PULSE, WHITENOISE)
TUNE
FINE TUNE
LFO MOD
ENV-1 MOD
VCF   SOURCE MIX DCO-1
SOURCE MIX DCO-2
CUTOFF FREQ
RESONANCE
PITCH FOLLOW
VELOCITY SENS
HPF CUTOFF FREQ
LFO MOD
ENV-1 MOD
VCA   VELOCITY SENS
BRILLIANCE
MODE (ENV-1, ENV-2, GATE)
LEVEL
ENV-1   ATTACK
DECAY
SUSTAIN
RELEASE
ENV-2   ATTACK
DECAY
SUSTAIN
RELEASE
EFFECT   TYPE (OVERDRIVE, DISTORTION, JX-3P CHORUS1, FUZZ, CRUSHER, PHASER)
TONE
DEPTH
DELAY   TYPE (DELAY, PANNING DELAY, CHORUS 1, CHORUS 2, FLANGER, DELAY + CHORUS)
TIME
LEVEL
REVERB   TYPE (AMBIENCE, ROOM, HALL 1, HALL 2, PLATE, MODULATION)
TIME
LEVEL
Controller   BEND SENS PITCH
BEND SENS FILTER
MOD SENS PITCH
MOD SENS FILTER
PORTAMENTO
LEGATO (ON, OFF)
BEND RANGE
BEND GAIN (1, 2, 3, 4)
TEMPO SYNC (ON, OFF)
KEY ASSIGN (POLY, MONO, UNISON)
KEY HOLD (ON, OFF)
OCTAVE (-3, -2, -1, 0, +1, +2, +3)
CONDITION
Arpeggio   ARPEGGIO (ON, OFF)
ARP TYPE (1OCT UP, 1OCT U+D, 1OCT DOWN, 2OCT DOWN, 2OCT U+D, 2OCT UP)
ARP STEP (1/4, 1/8, 1/16, 1/4T, 1/8T, 1/16T)
Tune   430.0Hz--450.0Hz
Sampling Frequency   44.1 kHz, 48 kHz, 88.2 kHz, 96 kHz, 176.4 kHz, 192 kHz
Patches per bank   64 patches
*User can make new user banks.
Plug-In Formats   VSTi 2.4 (64 bits) * Windows only
VSTi 3.6 (64 bits)
AU
AAX
System Requirements (macOS™)
Operating System   macOS™ 10.11 or later
Host Application   VST instruments (VSTi) version: VST 3.6 compatible
Audio Units (AU) version: V2 Audio Units compatible
AAX compatible
CPU   Intel®  Core™ i5 or better (Quad-core CPU recommended)
RAM   4 GB or more
Hard Disk   100 MB or more
Display resolution and Colors   1280 x 800 dots or higher, 16.7 million colors or more
Other   You'll need Internet connectivity to activate this software.
The SYSTEM-8 driver must be installed on your computer to connect this software to the SYSTEM-8. ​
System Requirements (Windows®)
Operating System1   Microsoft® Windows® 7 SP1
Microsoft® Windows® 8/8.1
Microsoft® Windows® 10
Incompatible with Windows® RT, Windows® Phone or virtual machines such as Hyper-V, Virtual PC.
Host Application   VST instruments (VSTi) version: VST 2.4/3.6 compatible
AAX compatible
PLUG-OUT Hardware2    SYSTEM-8
RAM   4 GB or more
Display resolution and Colors   1280 x 800 dots or higher, 24 bits Full Color or more
You'll need Adobe Reader (available free of charge) in order to read the online help.
