Author Topic: E-mu 1212M PCIe (2009)  (Read 587 times)
« on: December 29, 2018, 11:46:03 PM »
1212M PCIe
http://www.creative.com/emu/products/product.aspx?pid=19169
PCIe Digital Audio System
E-MU's 1212M PCIe Digital Audio System delivers everything you need to produce audio on a PC with professional results - 24-bit/192kHz converters and hardware-accelerated effects and mixing, and seamless compatibility with your favorite PC audio/sequencer software. The 1212M PCIe also ships with ASIO2 and WDM drivers for Windows XP, XP x64, Windows Vista and Vista x64, as well as the E-MU Production Tools software bundle that includes E-MU's Proteus X LE, plus software by Steinberg, Ableton, IK Multimedia, and many more - everything you need to create, record, edit, master and burn your music.
The E-MU 1212M PCIe features:
         Mastering grade 24-bit/192kHz converters - the same A/D converters used in Digidesign's flagship ProTools HD 192 I/O Interface delivering an amazing 120dB signal-to-noise ratio
         Hardware-accelerated effects - over 600 standalone and E-MU Power FX VST plug-in effects with no CPU overhead
         PatchMix™ DSP zero-latency hardware mixing and monitoring - with super-flexible patchbay - no external mixer needed
         Comprehensive analog and digital I/O plus MIDI - 12 inputs and 12 outputs, plus MIDI I/O
         Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO2, WDM and 64-bit drivers
         E-MU Production Tools Software Bundle - includes Cakewalk SONAR LE 6.3, Steinberg Cubase 4 LE, Ableton Live Lite 6 E-MU Edition, IK Multimedia AmpliTube LE and T-Racks EQ, Celemony Melodyne essential, Waldorf Attack, Waldorf D-Pole, Waldorf PPG Wave, SFX Machine LT, Creative EAX® ADVANCED HD™ ALchemy (Vista only), E-MU Proteus VX - everything you need to create, record, edit, and master is in the box.
I/O Configuration:
         Two 1/4" Balanced Inputs
         Two 1/4" Balanced Outputss
         24-bit/192kHz ADAT In/Out (switchable to S/PDIF)
         24-bit/96kHz S/PDIF In/Out (switchable to AES/EBU)
         MIDI In/Out
E-DSP Hardware-accelerated Effects, Mixing and Monitoring:
E-MU's Digital Audio Systems feature the powerful E-DSP chipset, which features a hardware-accelerated effects processor with over 28 effects plug-ins (over 600 presets). This effects architecture is fully expandable, allowing you to add more effect plug-ins to your system as needed. E-DSP also provides zero-latency, hardware-based mixing and monitoring via the included PatchMix DSP mixer, delivering unmatched flexibility in routing audio between all of your physical and virtual (ASIO/WDM) inputs and outputs- no external mixer needed.
