Author Topic: E-MU 1616M PCIe (2009)  (Read 904 times)
« on: December 29, 2018, 11:47:15 PM »
http://www.creative.com/emu/products/product.aspx?pid=19007
PCIe Digital Audio System
E-MU's 1616M PCIe Digital Audio System delivers everything you need to produce audio on a PC with professional results - 24-bit/192kHz converters and hardware-accelerated effects and mixing. comprehensive sync options and seamless compatibility with your favorite PC audio/sequencer software. The MicroDock M breakout box offers a total of 16 inputs and 16 outputs plus 32 channels of MIDI I/O, including two E-MU XTC Class-A ultra-low noise mic/line/hi-Z preamps with 48V phantom power and analog soft limiting circuit for clip protection. The 1616M PCIe also ships with ASIO2 and WDM drivers for Windows XP, XP x64, Windows Vista and Vista x64, as well as the E-MU Production Tools software bundle that includes E-MU's Proteus X LE, plus software by Steinberg, Ableton, IK Multimedia, and many more - everything you need to create, record, edit, master and burn your music.
The E-MU 1616M PCIe features:
         Mastering grade 24-bit/192kHz converters - the same A/D converters used in Digidesign's flagship ProTools HD 192 I/O Interface delivering an amazing 120dB signal-to-noise ratio
         Hardware-accelerated effects - over 600 standalone and E-MU Power FX VST plug-in effects with no CPU overhead
         PatchMix™ DSP zero-latency hardware mixing and monitoring - with super-flexible patchbay - no external mixer needed
         Comprehensive analog and digital I/O plus MIDI - MicroDock M offers 16 inputs/16 outputs plus MIDO I/O - everything from balanced analog and turntable inputs to ADAT and S/PDIF (switchable to AES/EBU)
         Two E-MU XTC™ Class-A, ultra-low noise preamps (-129.5dBu) - Mic/Line and true Hi-Z inputs via Neutrik connectors, with analog soft limiter, 48V phantom power and 60dB of gain
         Compatibility with most popular audio/sequencer applications - ultra-low latency 24-bit/192kHz ASIO2, WDM and 64-bit drivers
         E-MU Production Tools Software Bundle - includes Cakewalk SONAR LE 6.3, Steinberg Cubase 4 LE, Ableton Live Lite 6 E-MU Edition, IK Multimedia AmpliTube LE and T-Racks EQ, Celemony Melodyne essential, Waldorf Attack, Waldorf D-Pole, Waldorf PPG Wave, SFX Machine LT, Creative EAX® ADVANCED HD™ ALchemy (Vista only), E-MU Proteus VX - everything you need to create, record, edit, and master is in the box.
I/O Configuration:
         Two E-MU XTC™ Ultra-low Noise Mic/Line/Hi-Z Preamps with Soft Limiter and 48V Phantom Power (-129.5dBu EIN)
         Four 1/4" Balanced Inputs
         Six 1/4" Balanced Outputs
         Turntable Input (w/ground lug and hardware RIAA preamp)
         24-bit/192kHz ADAT In/Out (switchable to S/PDIF)
         24-bit/96kHz S/PDIF In/Out (switchable to AES/EBU)
         Two sets of MIDI In/Out
         Stereo 1/8" Speaker Outputs (configurable from stereo to 5.1)
         Stereo Headphone Output
