Author Topic: History of the Hammond B3 Organ  (Read 881 times)
  • Hero Member
« on: January 27, 2019, 10:16:50 AM »
http://theatreorgans.com/grounds/docs/history.html
Introduction
Because of my interest in analog synthesizer technology, and the fact that I am an jazz organ player, specifically, a Hammond organ player, I thought it would be fitting to do a report explaining the technology used in the original Hammond organs (quite possibly the world’s first synthesizers), and explain how their immense popularity in the 50’s and 60’s helped shape the technology of the earliest synthesizers, and the needs of early keyboard players in general.
The Hammond B-3
There were many varieties of the Hammond organ, some designed for home use, some designed for church use, and some designed for live gigs and studio recording. But the most popular variety, and the one still commonly in use today (if you can find one that isn’t too beat up) is the Hammond B-3. This organ has two 61 note keyboards, (manuals), sometimes called the swell (top) and the great (bottom), a variety of built-in special effects, (including "percussion" effects, several different chorus and vibrato effects, and adjustable attack and decay effects), 9 preset keys for both manuals, (the inversely white and black keys on the bottom octave of each manual), two sets of nine stops (drawbars) for each manual, a full two octave set of foot pedals with two pedal drawbars built in to the console, a volume pedal (expression pedal) built into the base, a solid walnut body with 4 legs and base, a built-in stool, and it weighed in at over 400 pounds. Also, it needed to be run through a separate speaker called a Leslie (which I will explain later), which also came in many varieties and sizes, but which was usually around six feet tall and weighed almost as much as the organ. To get a B-3 to a gig, you would probably need a truck or a van to transport it, a dolly or three to four guys to carry it, and then a prayer that you didn’t have to carry it up too many flights of stairs. Why, you must be wondering, would any sane musician want to take this piece of furniture with them out to a gig? If you have ever heard a good B-3, you would understand. A Hammond B-3 can all at once sound like a carnival, a big band, a horn section, a small jazz combo, a funk group, a percussion section, a flute, and/or countless other things. How does one instrument manage to do all this? The answer begins in the drawbars.
The Drawbars
You’ve heard the expression, "Pulling out all the stops?" The drawbars on the organ are these very stops. The organist can "voice" each stop as he plays. Meaning, any one of the nine drawbars that go into the makeup of an organ sound can be individually altered, either while playing, or permanently preset into one of the 9 preset keys. (The other three are for setting or clearing the presets.) Each drawbar has eight degrees to which it can be literally "drawn" or pulled, out of the console of the organ, the eighth being the loudest, and all the way in being silence. The nine drawbars represent the nine most important harmonics, going in order of left to right, the sub-octave, the fifth, the unison or fundamental octave, the 8th, the 12th, the 15th, the 17th, the 19th, and the 22nd. All of these except the 17th are either roots or fifths. The 17th is a third. The colors on the drawbars themselves are also related to their harmonic pitch. The white and brown drawbars are called the consonants, all the roots and the lower fifths, and the black drawbars are called the dissonants, the higher fifths and the third. Using this basic harmonic series, almost any instrumental tone may be imitated or mimicked. Also, the inventor of the Hammond organ, Laurens Hammond, who invented the B-3 around 1937-39, and who later unveiled it at the 1939 AES show here in New York City at the RCA building, used some of his father’s techniques, who happened to be a designer of pipe organs, in the development of his new organ. The drawbars are all labeled to represent pipe pitches, represented by length, ranging in order of largest to smallest, from left to right. These "lengths" are, 16', 8', 5 1/3', 4', 2 2/3', 2', 1 3/5', 1 1/3', and 1', being the smallest. By the way, the two drawbars for the pedals are called the Super-Octave and the Sub-Octave, and their respective "lengths" are 16' and 8'. Just like the fundamentals for creating sound waves lies in harmonics, (much like what we have learned in this class,) such is the way with the drawbars and their harmonic series. For instance, in terms of sound waves and frequency, the 1st harmonic by itself creates a sine wave, or a flute/recorder-type sound. The odd harmonics create a square wave, or a clarinet-like sound. The odd harmonics "squared" create a triangle wave, or a string-like sound. And all harmonics together create a sawtooth wave, or an oboe-like sound. Drawbar settings use the same kind of premise; various levels and volumes of harmonics are used to create sounds. There are literally millions of tone qualities and endless shades of dynamic level available on the Hammond organ. Figure 1, (see back pages), or drawbar setting (00 6200 000) is an example of a flute tone. Figure 2 (00 4345 554) is an example of a violin tone. Figure 3 (00 6876 540) is an example of a trumpet-like tone, and Figure 4 (54 5444 222) is an example of a diapason, or a typically organ-like tone quality. There are also the typical jazz settings (not included in the appendix,) such as 88 8000 000, the most common, used by jazz players 90% of the time, 88 8400 080, for a bit more of a whistle during solos, 80 0000 088, for a high-end chordal voice setting, or the full blown 88 8888 888, the largest sound possible on the organ, which is used usually for loud chord solos, or huge crescendos or climaxes. That particular setting truly defines the phrase "pulling out all the stops", and it means exactly what it says; the works. Of course, there are a multitude of other possibilities, and every player out there has his or her own particular setting, or 'sound'. But how exactly do the drawbars do what they do? The answer to that lies in the tone generator.
The Tone Generator
The tone generator, except for the Pedal Solo Unit, which controls the sound generated by the pedals, is composed of 91 tone wheels, located inside the console. Each tone wheel generates magnetically one of the pitches of the fundamentals (the first harmonic) or the overtones, (all harmonics above the fundamental) of the many "stops". By the way, musical pitches on the organ range from 32.692 Hz in the bass to 5919.85 Hz in the treble, a span of seven and a half octaves. The frequencies of the Solo Unit for the pedals range from 16 to 3136 cycles per second. The expression pedal has a range over 48 decibels in power. (The B-3 is a loud instrument.) Anyhow, on the outer rim of each tone wheel, which are only about the size of silver dollars, are a series of "hills and valleys" which disturb the electromagnetic field in a near-by magnet and the circuitry with which it is connected. These wheels turn on their axles at a carefully controlled speed. The disturbances are in the nature of sine waves, and are timed as the musical pitches themselves. These disturbances, which are really just fluctuations of electrons in tubes and wires, are extremely weak and have to be amplified millions of times before they are strong enough to move the cones in the external speakers, which, in turn, must move all of the tons of air in a room before the sound actually gets to you, the listener. The waves, while they are still in the electrical form, pass through an amazing set of filters, mixers, and other devices that process the final result, but to the player, it is so much more less complicated than all of that.
Why The Hammond?
Even today, the influence of the Hammond organ is felt everywhere. Listen to any song on any given radio station, and it is a strong bet that you will hear someone banging away at a B-3. By the way, the B-3 is only one of the many different styles of organs that the Hammond company produced, among which were also the Chord organ and the Spinet organ. This one just happened to be the most "portable", if you can call it that, and it really had the best sound, today what we would call the "classic" Hammond sound. The Hammond is used in all types of music, from Gospel, to Blues, to Jazz, to Funk, to Rock. My first real exposure to the organ was early in my musical career when I was still listening to Emerson, Lake & Palmer, and Yes almost exclusively, studying and memorizing every Keith Emerson and Rick Wakeman lick that I could transcribe. (Especially Keith Emerson, who used to take his B-3 and throw it around the stage, ride it like a horse, set it on fire, stab it, or whatever else.) Back then I knew I loved the sound of the organ, but I never really realized it’s full capability until I reached college and was introduced to my first Jimmy Smith record, who is world renowned as the master of the jazz organ, and really the first musician to treat the organ as an honest-to-god instrument, and not just a novelty to be thrown in at sporadic times, the way Count Basie did back in the early fifties. My friend popped in the album Organ Grinder Swing, and said, "Check this out - this guy solos with his right hand, comps chords with his left, plays bass lines with his left foot, and controls the volume with the right." I must have said something like "Yeah, right". Not only was this man doing everything that my friend had described, but he was also soulfully moaning and wailing to the music that he was creating, and I knew immediately that this was something serious that I had to know more about. Four years later, and I consider myself to be a full time jazz organ player. Jimmy Smith, though, was not the only one to make a name for himself playing the Hammond. Among the many in jazz, funk, and rock are Richard "Groove" Holmes, Jack McDuff, Jimmy McGriff, Joey and John DeFrancesco, Shirley Scott, Dr. Lonnie Smith, Larry Young, Don Patterson, Paul Shaffer, Don Pullen, Larry Goldings, 'Big' John Patton, Booker T. Jones, Billy Preston, Merl Saunders, Ray Manzerek, Jon Lord, Fats Waller, and so many others. I have had the opportunity to take lessons with both Dr. Lonnie Smith and Larry Goldings, and let me assure you that these men take the instrument very seriously, and that they are monstrous musicians, capable of doing amazing things. I have also had the opportunity to meet Jimmy Smith at a club in Boston, and let me assure you that the man, although intense, is completely insane.
The Leslie
There is one more thing that must be described if we are to fully appreciate the character of the Hammond, and that the is the Leslie tone cabinet. The organ needed an external speaker in order to be heard, and it also needed one specially designed that had rotating speakers, so that the vibrato effects in the organ could come out. Besides, the organ had a special multi-pin output that could only be connected to a tone cabinet, a conventional amplifier would never have worked. The Hammond company actually designed several tone cabinets of their own, but they never caught on as well as the similar model produced by the Leslie corporation, which simply sounded better anyway. In the early days, there was a sort of rivalry between the two companies going on, but not long after the Leslie pretty much became accepted as the standard. Even Laurens Hammond, who publicly pooh-poohed them had his own home organ coupled with a Leslie. Like the organ itself there were a lot of varieties of these speakers, but one of the most commonly used models was called the Leslie 122, which stood around six feet high, and had two rotating treble horns at the top of the cabinet, a bass woofer inside, and another pair of rotating horns at the bottom. The rotation of the horns were continuous, and they only had two speeds, fast and slow. When moving slow, which they most often do, is when the clean, pure organ sound comes through. But when the fast switch is activated on the console of the organ, the speakers pick up speed, eventually going as fast as they can, and that is the classic huge Hammond vibrato sound. A Leslie is really something to hear close up. It is a very loud and a very powerful sounding speaker. Someone at the controls of an organ has a lot of power at their disposal, not to mention the possibility of overdrive, which is a common sound used by organ players. This happens when you maximize the volume on the expression pedal and the Leslie distorts, which is very effective, but should probably only be used sparingly. Most organ players preferred the sound of stereo Leslies, but one would work just fine. Some other models were made that were smaller and more portable, and it often depended upon the tastes and needs of the players themselves. Some players preferred the sound of the Leslie if only the bottom horns rotated instead of both, or the other way around. Some players combined other speakers, like bass cabinets, in conjunction with their Leslie. The way you set up your Leslie was almost as important as the drawbar settings themselves. But enough background on the instrument; its time to move on and explore the legacy that the Hammond organ has left the future generation of keyboard players and the future of music technology in general.
The Hammond's Influence
As I mentioned before, the Hammond B-3 was immensely popular during the 50's and 60's, and even into the seventies when the first portable synthesizers began to appear. Keyboard players like Keith Emerson and Rick Wakeman, even though they were surrounded by an army of Moogs, Mellotrons, and electric pianos, would still lug these things around. For one reason, because even to this day, though the Hammond could imitate the sound of almost any instrument, nothing could imitate the sound of a Hammond. And it can be safely said that players were infatuated with the instrument because it really was the world's first portable synthesizer. Well, was it? It utilized oscillating vacuum tubes, manipulated sine waves through the use of harmonics, could actually save preset sounds, (not to mention sounds that actually sounded like something else besides an organ), had modulation control, (the two Leslie speeds and the different tremolo, chorus, and vibrato settings), had attack and decay parameters, volume pedal control, and even had echo and sustain available on later models. Doesn't that sound a lot like the early synths we know? When the early developers of synthesizers, Robert Moog on the east coast and Don Buchla on the west, were tinkering with oscillators, it is a good bet that they knew of the Hammond and what it was capable of. Moog even used a modified organ manual as his keyboard controller. Especially later on, when new synthesizer companies began mass-producing their instruments, the demands of keyboard players that were already out there on the scene playing warranted that they would have to appease the Hammond enthusiasts, who had become comfortable with the organ's by-then 'standard' features. Entire dictionaries were put out on the Hammond organ alone, jammed with the different drawbar settings that all sounded different from one another. Numerous publications were being put out on the instrument. Teachers actually began instructing students on the Hammond as its own new instrument. Needless to say, the movement was large, and it is true that much of what was standard on the Hammond organs back then became standard on the synthesizers that we know of and use regularly today.
The Future
There has been a great effort by the synthesizer companies of today to emulate the sound of the Hammonds. You yourself may have a couple of killer Hammond samples on your machine, but there is nothing like being behind the real thing, starting the motor, (which is a technique all to itself) and feeling the thing purr to life like a giant, breathing creature. Not only that, but a sample is just a sample, and you cannot do the any one of a hundred things to the sound that you could do if you were playing the real thing. Nevertheless, there has been a good deal of genuine effort made by different companies. In the early eighties, the Korg company were the first to delve into the field. They released two keyboards, the B-X3 and the B-X2, both good efforts, yet both flawed in many ways. The B-X3 was a dual manual organ, with one full set of drawbars for each manual, and the B-X2 was a single manual organ, with one set of drawbars. Both were highly portable, and relatively lightweight. Korg had managed pretty well to nail the grungy, down and dirty sound of the Hammond, but you could not program presets onto it, (it came with three unchangeable presets that were terrible), most of the special effects, especially the percussion (attack) effects were cheesy sounding, and the built-in Leslie simulator was horrendous. More recently, though, a lot of new efforts have been made, but still nothing has exactly hit the mark. The Hammond company, which actually closed down for good in 1975, reopened in 1992 with a whole new line of fully digital, MIDI capable organs. Incidentally, that means that even if you could get the last B-3 to come off the production line, you're still buying an instrument that is 18 years old. Among Hammond's new line is the popular X-B2 (which I traded up to after owning the Korg B-X3), which is a single manual organ that was pretty much modeled right after the old Korg B-X2. The X-B5 is another, a dual manual organ with a whole slew of special features, most of which aren't really necessary on an organ, and also the X-B3, an exact replica of the original B-3 console, only with a 90's style high gloss finish. As far as sound quality, these new Hammonds come very close, especially when coupled with the also brand new highly portable Leslie 302 tone cabinets, designed specifically for the new Hammond line, but they too have their nitty-gritty flaws. Other recent efforts include a new Rhodes drawbar keyboard, which has some nice features but also lacks a great deal, a rack mount module called Vintage Keys, another rack mount module called the VOCE DMI-64 Mark II, and its later version, the VOCE Micro B, and a few others. There is even a new rack mount Leslie simulator available from a German company which is very good, but very expensive. So far, the new Hammond line has pretty much dominated the new organ market, and happily, there has been somewhat of a B-3 revival going on. KEYBOARD magazine recently devoted an entire issue to the subject of the Hammond B-3. GOFF Professional of Newington, CT, run by Mr. Al Goff, which started out as a kind of basement operation has expanded into a very successful new company committed to the restoration and rental/sale of vintage B-3s and Leslies. (See their ad in the classified section of any issue of KEYBOARD magazine.) He is an excellent resource of information, and has become the foremost authority on the east coast for Hammond organs. Just about every famous organ player on the scene today including Keith Emerson, T. Lavitz, Jimmy Smith, Joey DeFrancesco, and Jimmy McGriff has had their organ or Leslie restored by Goff Professional. They even rework the brand new models and the new Leslies to sound awesome. They have also done work for groups like Hall and Oates, the Allman Brothers, Phish, Grayson Hugh, and Widespread Panic. Joey DeFrancesco, by the way, famous son of organist John DeFrancesco, is one of the fresh new musicians on the jazz scene who is helping to put the Hammond B-3 back into the spotlight. He is currently working with John McLaughlin. Also, Larry Goldings is a hot new player on the scene who has already worked with Maceo Parker, Jim Hall, and John Scofield. A lot of the old jazz players too, like saxophonist Lou Donaldson, are returning to the classic old sound of the jazz organ trio (organ, guitar, drums) as a rhythm section. Go to any rock show now, and you're bound to see the group's keyboard player on stage with a restored B-3 and Leslie cabinet. New groups like the Black Crowes and Phish use the B-3 almost exclusively as their keyboard instrument. I've seen Hammonds all over the place in rock videos, from Bryan Adams to Eric Clapton. Basically, they're trendy again, and they're everywhere. Even in this day and age, when technology can do amazing things, some things stubbornly refuse to be replaced. It will be interesting to see what other developments in this field take place in the years to come. Many keyboard players, myself included, will be watching intently.
« Last Edit: January 27, 2019, 10:17:09 AM by chrisNova777 »
  • Hero Member
Re: History of the Hammond B3 Organ
« Reply #1 on: August 01, 2019, 03:12:28 PM »
https://web.archive.org/web/20150608011928/http://www.soundonsound.com/sos/1997_articles/oct97/hammond.html
The History Of The Hammond
Exploration
Published in SOS October 1997
Printer-friendly versionBookmark and Share
People + Opinion : Industry / Music Biz
In these days of synths that stay in production for just a couple of years before being discontinued, respect is due to a keyboard design that's survived more than half a century of changing musical fashion and is still going strong. Hammond-lover ROD SPARK pulls out all the stops to bring you a personal organ odyssey.
Since my childhood there's always been a sound I loved but never managed to identify. I had a faint memory of hearing this sound in theatres and cinemas, but after playing guitar for a good few years in a band, I started coming across it again in '60s soul and jazz songs. At long last I discovered what it was: the Hammond organ.
These days, the mention of a Hammond is as likely to conjure up pictures of Blackpool pleasure beach as it is Jimmy Smith in full R&B flight. Cast aside the memories of Peter Fenn playing the Sale of the Century theme (that was actually a Yamaha anyway!) and read on. Hammonds play a much bigger role in modern music than the cheesy sound (that's probably a Farfisa anyway) playing in the background while you practice your double axel at the local ice rink.
QUICK ON THE DRAW(BAR)
My first Hammond was an X5, a portable model made by the Japanese in the late '70s. We called it a Hammondo. This was a very exciting instrument for me, having two decks of keyboards, a pedal board (something I've never used on a Hammond and never will, thereby omitting any mention of it from this article!), and drawbars giving almost infinite variations in sound. The drawbars actually emulate the pipes on a church organ, which is the job the Hammond was originally designed to do. They match up to the lengths of a church organ pipe and supposedly give the same sound -- pulling out the lower drawbar produces a deep sound similar to the largest church organ pipe.
In reality, the drawbar controls the level of harmonic or sub-fundamental introduced into the sound. The white drawbars are octave transpositions, the black ones are for third or fifth frequencies, and brown drawbars give the octave sub-fundamental and its third harmonic. If you don't understand this, don't worry -- I don't either; I just read it somewhere once! All you need to know is that these drawbars allow you to carve out your own trademark sound, which is something I'm still working on.
"The drawbars actually emulate the pipes on a church organ, which is the job the Hammond was originally designed to do."
The classic jazz organ setting (as used by Hammond supremo Jimmy Smith) is obtained by pulling out the first three drawbars and flicking the percussion switches for soft volume, third harmonic and fast decay. For the classic Hammond track 'Green Onions', Booker T used the same setting, but with the fourth drawbar pulled out too. Jon Lord does the same but prefers the percussion set to second harmonic. Many other Hammond players just pull all the drawbars out. No matter what, you'll still produce a unique sound, as every Hammond, even models from the same series, sounds different to its brothers and sisters.
ALL HAMMONDS ARE NOT CREATED EQUAL
Meanwhile, back at the main storyline... the X5 had a great sound but wasn't the best I'd heard. I was soon to learn that this was a solid-state Hammond. Early (real?) Hammonds have a generator which runs at 1800 revs per minute and drives a number of tonewheels (96 on a C3/B3, less on other Hammonds). These are small metallic discs, about an inch and a quarter in diameter, with high spots which spin past a system of electro-magnets, creating an alternating current corresponding to the equal temperament scale. This tone passes through a filter and can be controlled by the keyboard. Each key presses down on nine contacts which relate to the drawbars. All that's left is to amplify the signal and play through a speaker. My X5, however, didn't have a tonewheel and so wasn't authentic enough. It had to go!
I then managed to get hold of a T100, which was also a fairly modern Hammond, having been produced around 1967. However, it looked more like the real ones that proper bands used than the Joe 90 effort I had before. The T100 was a spinet-style organ -- basically an upright box with a bit sticking out near the top where the keyboard is! Take a look at the picture above to get my drift. It also had a spring reverb, giving it a great crashing sound when I threw it around. (I made up for my lack of playing ability by performing neck-breaking stunts on it instead.)
After a while, I began to wonder why my organ didn't sound as good as the classics -- apart from the obvious fact that I wasn't very good. It was then that I first met Graham Sutton, who had been a demonstrator for Hammond UK in the '60s and '70s. He told me all about the Hammond Organ to end all Hammond organs -- the father of them all, the C3 (or B3, which is the American version -- exactly the same Hammond but with four legs instead of a solid body. The C stood for Church, and the B was for the home). I had to get one! Unveiled by Hammond in 1955, it had made its mark in jazz circles by 1958, courtesy of the great Jimmy Smith, Jackie Davis, Fats Waller and Wild Bill Davis.
While down in Milton Keynes rehearsing for the UK version of The Who's Tommy, I popped in to see Graham for a chat and rather recklessly left with a C3. It was split into two to allow for easier carrying (although easier isn't the word that anyone who's helped me carry it has ever used) and was the bee's knees, the big boss sound. There was no messing now. This wasn't a poxy wee synth -- this was a man's machine.
BEFORE THE B3
The C3 and the other tonewheel Hammonds (the T500 was the last) were discontinued in 1974, due to mounting costs, and would be uneconomical to produce these days, due to the man-hours involved. Although he owned other, earlier Hammonds, Georgie Fame managed to get one of the last C3s off the line before production ceased. This was the end of an era which began in 1934 with inventor Laurens Hammond. At that time he was running The Hammond Clock Company of Chicago, though he had previously invented collapsible bridge tables and would later dabble with missile systems. Mr Hammond became interested in the Cahill Telharmonium, a late 19th-century instrument employing rotary generators to create electrical impulses, which were turned into sound by way of telephone receivers. The idea was to distribute sound over the telephone network, but this was soon abandoned because of the machine's weight (apparently it occupied several rooms) and complexity.
"The Leslie looks like a chest of drawers."
Nothing daunted, Laurens took the idea of the rotary generators and created a portable (for its day) organ. The 'Model A' Hammond organ was patronised by no less a personage than Henry Ford, who became the first buyer. The second model off the production line was presented to the then President of the USA, Franklin D Roosevelt, with George Gershwin being another early buyer. The model B, B3, C3 and M100/L100/T100 series all followed, along with countless other models (it would get very boring if I listed them all here) and since then many famous keyboard players have fallen in love with the Hammond. Players such as Georgie Fame, originally a jazz pianist, Jon Lord of Deep Purple, originally in the very hip combo The Artwoods, Keith Emerson of ELP and The Nice, well known for their banned version of 'America' and the abuse he gave his instrument.
SOMETHING GETS IT STARTED...
If you ever come across a Hammond, perhaps in a studio you might be recording in, chances are you won't even be able to get it started! Not content with just having an on/off switch, the earlier Hammonds had an ignition-like switch to wake them up. One switch, helpfully labelled 'Start', needs to be flicked and held for 10 seconds (which is usually where I start praying that it will work). Then, keeping the Start switch held, you flick the 'Run' switch; this should start the Leslie horns spinning, providing a Leslie is connected). Hold the Start switch for a further 5-10 seconds and then let it go. Following a worrying, confusing and quite comical clunking, a whirring of wheels, a grinding of gears and a rumbling beneath your hands, Kazoom! The Hammond should now be ready to play.
Although all this might sound like a clever way of preventing unauthorised hands from playing your instrument, holding the Start switch sets the Hammond's generator running and allows it to reach the correct speed for those tonewheels. The Run switch is actually what powers everything else up. If the power is interrupted, even for a second, this procedure must be repeated, as the generator will wind down.
Other knobs and switches to play with on most Hammonds include 'Percussion', which I mentioned earlier. This isn't for adding a naff Bossanova rhythm track. It lends attack to the top elements of the sound and reinforces either the second or third harmonic, producing the familiar 'chink' sound common in Hammond-rich tracks.
Vibrato is a common effect present on most Hammonds. While vibrato isn't everyone's cup of tea, the C3 (Chorus 3) setting on the B3 and C3 is particularly nice (if working properly. After 20 years or so, the Vibrato unit really needs a good overhaul to stop it detracting from the sound rather than enhancing it).
Some of the later, 1970s transistor Hammonds also had rhythm units, which supposedly emulated a drum kit. Some Hammonds (such as my old T100) also had spring reverb. Originally invented by Hammond for their Church organs, this was so successful that Leo Fender bought the idea from Hammond and made it a feature on his range of guitar amps.
Your choice of Hammond may be dictated by the music you plan to play with it. The 'big' Hammonds, such as the C3 and B3 (full bodied 'console' organs, as opposed to 'spinet'-type models) are usually regarded as the classic Hammonds because all the famous players used them. Two drawbacks with them, however, are the fact that they're so big and heavy (expect to need four people, lifting a corner each) and the fact that the generator requires a precise 50Hz power rating, which I'll explain later. The spinet-style Hammonds, such as the L100 and M100, are smaller, but they can still give the classic overdriven sound -- and even if they don't, the amps can easily be tweaked to produce the desired effect.
YOU SPIN ME RIGHT ROUND
Many Hammonds don't have their own speakers, and produce sound instead through the famous Leslie cabinet, which was invented by Don Leslie, quite some time after the Hammond was first invented. The Leslie cab was originally designed as a sound modification device rather than a 'hi-fi' speaker, which partly explains why putting anything other than an organ or guitar through it (Hendrix did the latter quite a lot) always sounds crap. The only exception is, perhaps, singing through it, which produces a nice megaphone effect. Minus the speaker, Del Amitri put most of their vocals through a 145 model Leslie amp for warmth.
"The drawbars allow you to carve out your own trademark sound."
The Leslie looks like a chest of drawers and has a 40-watt monophonic tube amplifier, an 800Hz 16(omega) passive crossover, a rotating treble horn, and a rotating bass speaker (at least, the classic 145, 147 and 122 models do). It can produce two distinct sounds: the 'Chorale' effect when the speakers rotate slowly, and the 'Tremolo' when they spin quickly. There is actually a third effect that can be coaxed from the Leslie: if you disconnect the slow motors (either by pulling the slow-motor connections out or by using the small black Leslie brake accessory plug), you can stop the rotors. Switching the Leslie from slow (which will now actually be stop) to fast makes the difference in sound much more exaggerated, and also allows the vibrato and chorus on the Hammond to shine through and sound much sweeter than when the Leslie is on the Chorale setting.
Unfortunately, the Leslie and Hammond usually take up half the space in a tour bus and are a roadie's nightmare (they can weigh a good 500 pounds).
SOUND STUFF
I've been cursed many a time for the weight of my rig, but in my defence insisted that the Hammond/Leslie sound could not be emulated by a modern keyboard. This still holds true, though modern samplers can come very close when each note is played individually. Try a run of notes, though, and you can tell the difference. Most synths have a few organ settings which never quite get there; the slow Leslie effect can be almost passable, but the fast Leslie is next to impossible to reproduce, in my opinion. A closer contender is Korg, with their CX3 (or the double-manual BX3), made specifically as a small Hammond substitute in the late '70s. However, even this doesn't come close to the real thing -- I know, as I have one as a backup should my 30-year-old baby fail on me. In truth, though, the C3 is very rugged and only ever let me down once, when a valve fell out of the Leslie after it was placed on its side. I now always carry a spare set of valves with me.
I recently found out that pre-1968 Hammonds have white capacitors in their generator and vibrato line box, while later ones have red capacitors. The newer red ones allow for a much brighter sound than the white ones, and also last a lot longer. The difference in sound quality can be very noticeable to a player who is familiar with Hammonds. When Georgie Fame was playing in Scotland recently, a friend of mine who runs a Hammond hire company supplied him with a B3. Fame wasn't sure about the sound and thought it could be a lot brighter. The next day, my friend asked Fame what he had at home. When Fame answered that he had a 1974 C3 the problem was solved instantly. Fame's C3 would have had red capacitors, while my friend's B3 had white ones. Not many people would notice this difference, but the ever-professional Fame, having played Hammonds for nigh on 30 years, certainly did!
WHAT'S THE DAMAGE?
If you want to buy a Hammond now, values range considerably, from £100-200 for a battered old T100, to £6500 for a brilliantly preserved B3. The more common C3 would set you back about £2000. If you plan to gig with an organ you really need it split in two (horizontally!) and this can add £200-300 to the cost, depending on whether it has the pedal board and which model it is (some are easier than others to split).
I paid £1000 for my C3 and an extra £100 to have it split in two to allow for portability. Mind you, this was before Hammonds were back in vogue: these days the prices have jumped dramatically, as everyone wants one. You should look in the classified ad sections of keyboard magazines for people selling them, and also seek out the various dealers, who will always have a handful of Hammonds in stock. If you look around you might come across a church selling one, or perhaps a working men's club.
Remember when you buy a Hammond that it's nothing without its Leslie cabinet. You may have been lucky enough to get the matching Leslie with the Hammond, but chances are that if your Hammond has speakers, this was all the previous owner used. The Hammond will work fine and still make a nice sound, but it won't be the great sound you're after, and it won't be loud enough for gigging. When you do track down a Leslie, make sure you check the number of pins on the connector. The older ones have six pins, but the newer (generally transistor) ones have nine or 11 pins. I (like most) reckon valve Leslies have a much nicer sound than transistor ones, though it comes down to taste. Transistor Leslies can be a lot louder than their valve counterparts -- though, in fairness, most valve Leslies are more than loud enough. The valve amps (contained in the Leslie) are only 40W, but this is 40W by valve, so it's louder! Personally, if I've gone to the bother of getting a valve Hammond, I'd want it amplified by a valve amp. If you are not able to get a Leslie at the same time as you buy a Hammond (and Leslies are certainly harder to get hold of), and you find a Leslie at a later date, you must ensure that you get the right connection kit for your Hammond. If you don't, you risk blowing up the amp and possibly causing yourself injury. This really should be left to an expert to arrange for you, as there are over 20 different models of Leslie cab out there and several connection kits. Incidentally, brand new Leslie cabinets range in price from from £1300 to £2000.
NEW FACES
In the late '80s, Suzuki brought the Hammond name, and a new entity appeared, Hammond-Suzuki, and you can still buy new organs made by the new company. But how do they match up? The Hammond Suzuki XB2, XB3 and XB5 have all the features which have become classic in the older Hammonds -- the drawbars, the 2nd/3rd percussion, the key click -- but they don't have that all-important grungy mechanical sound. They cost around £1400 for the single-manual, portable XB2, £8000 for the double-manual XB3, and between £4000 and £7000 for the XB5. It's a matter of taste, of course, but I don't think they're a patch on the old ones. Hook one up with a Leslie and you'll get a much better sound than any synth, but they ain't tonewheel.
SOUL MACHINE
Booker T and the MGs made a living out of it, James Brown gave singing a miss to play it on several ultra-funky tunes, Deep Purple wouldn't have been the same without it. Although there are others, the prominent purveyors of the Hammond these days are probably the German jazzer Barbara Dennerlein and Jamie Taylor from cool Mod outfit The Prisoners, now with his own Acid Jazz Quartet. The Hammond organ is the essential instrument for breathing soul into music, and long may it continue.
A HAMMOND TIMELINE
1935-38: Model A organ (the first!).
1935-38: AB (as model A, in B-series cabinet).
1936-42: BC (as AB, plus chorus, extra generator).
1938: B-A (as BC but could also be played with rolls of paper, similar to a player piano).
1939-42: C (as AB but with C-series cabinet).
1939-42: D (as model C but with Chorus).
1939-42: Novachord (72-note poly synthesizer).
1940-48: Solovox (3-octave valve-based monosynth).
1941-44: G (built for US Government and found in forces recreation halls. As model D but with reverb).
1948-51: M (home-style spinet with tonewheel generator, internal amp and speaker. Drawbars only, no presets of any kind).
1949-54: B2 (as B3 but without percussion).
1949-54: C2 (as earlier CV from 1945, but with additional controls for vibrato on either/both manuals, and for 'normal' or 'soft' overall volume).
1951-55: M2 (similar to M, above).
1955-74: B3 (a big box on four legs).
1955-74: C3 (B3's innards in C-type church case).
1955-64: M3 (similar to M, above).
1959-65: A100, 101 and 102 (as C3 but with home-style console. Had built-in sound system and reverb).
1961-68: M100 (home-style spinet with internal amp and speakers).
1964: Hammond UK set up.
1965-72: X66 (non-traditional Hammond console organ with top octave tonewheel generator).
1965-74: H100 (a biggie with all the trimmings. Mixed valve/transistor circuitry).
1967-72: L100 (spinet model with tonewheel generator and non-scanner vibrato).
1967-75: X77 (49-note arpeggiator, stereo reverb, variable reiteration and harp sustain).
1968-75: T100 (transistor spinet organ, vibrato, repetitive percussion voices, reverb).
3rd July 1973: Laurens Hammond dies.
1979-80: X5 (portable solid-state, single manual. Made by Nihon Hammond, who licensed the Hammond name in 1970).
1986: Hammond finally go out of business.
1987: Hammond Suzuki buy Hammond name and start to make XB range (The Organ Company of America had previously taken over the spare parts and servicing of original Hammonds).
NB: Hammond made organs with different finishes, so many models had relatives in the same family.
POWER HUNGRY
One interesting thing about Hammonds is that they should never go out of tune! The generator is set to run at the correct speed when it is provided with a 50Hz cycle power rating. This is the standard for UK mains power. In the USA the standard is 60Hz, so Hammonds are set to work off that. This is great for the majority of gigs, but can turn into a nightmare for outdoor gigs. When I first got my C3, I played an outdoor gig with it the very next day. Every second song or so, the Hammond would cut out and I'd have to restart it. The Hammond was taken straight back where I got it (at midnight!). After several hours, Graham Sutton, the vendor, could find nothing wrong with it, so I explained again what had been happening. "Ah!", he said, "an outdoor gig, with a power generator instead of mains". The power generator had occasionally been running below the 50Hz I needed, so the Hammond had cut out. All other equipment on stage was unaffected, as no-one else's gear was relying on straight 50Hz power, and transistors have a much wider tolerance. Since then I've played a number of outdoor gigs when the power from a generator has fluctuated, and the result is a variation in the pitch of the organ. If the power is 51-52Hz, the Hammond sounds sharp. It's very annoying, and applicable to all the big tonewheel organs.
At the same gig where the power problem first came to light, I was lucky enough to hear my Hammond being played by the keyboard player in the support band. The Hammond sounded awesome. This was the sound I was after, and I was dying to get on that stage and let rip. I wasn't prepared for the sound that greeted me when I got there. It just wasn't the same. This has happened to me on a number of occasions since, so I stopped worrying about it and put it down to miking techniques. Not so long ago, though, I discovered that Leslie cabinets give out AM and FM frequency components (providing that deflectors are still fitted onto the ends of the Leslie's treble horn). The Amplitude Modulation is apparent beside and some distance away from the Leslie. The Frequency Modulation, however, doesn't show up until you're a few metres away from the cab. As FM is much more pleasing to the human ear than AM, this explains why, when you're standing close to the Leslie (such as when you're playing the Hammond), it doesn't sound as nice as it does out front to the audience -- who are hearing the full effect. This knowledge is essential for a Hammond player's confidence and well-being!
RECOMMENDED LISTENING
ALBUM
• Jimmy Smith: The Sermon
• Jimmy McGriff: Pullin' Out the Stops
• James Taylor Quartet: Wait a Minute
• Groove Tunnel [yes, this is Rod's own band! Ed] : Liven Up!
• Brother Jack McDuff: Screamin'
• The Artwoods: 100 Oxford Street
• The Small Faces: The Small Faces (Green Circles)
SONGS
• Jimmy Smith: 'The Cat'
• The Nice: 'America'
• Deep Purple: 'Hush'
• Hardin & York: 'Drinking My Wine'
Anything by Brian Auger Trinity, Booker T & The MGs, Groove Tunnel, Blue Note.
USEFUL HAMMOND CONTACTS
• Clive Botterill, Hammond Organ Service UK: supplies parts for, services and sells Hammonds and Leslies. Was the Production Director at the Hammond factory in Edgeware in the mid-'60s to late '70s.
