Recent | Who | Artists | Firewire | USB | Gfx | Windows | Mac | MacOS9 | IBM/DOS | ATARI ST | Midi Interfaces | Sequencers | MPCs | Roland "MC" | Roland "S" | E-mu | Ensoniq | Akai "S" | Samplers | soft-Samplers | Synths | soft-Synths (VSTi) | Roland "JV" | Modules | Drums | Tape | Mixers | hardware Effects | soft Effects | iOS | android | sw Timeline | HackintoshReason
Oct 24th :: fixed some minor permission problems with some of the areas of the site that were not accessible by guests; login with an account for best results
Author Topic: Roland PG-10 (1988)  (Read 3746 times)
Roland PG-10 (1988)
« on: February 09, 2019, 10:18:25 PM »
http://cdn.roland.com/assets/media/pdf/PG-10_OM.pdf
Roland PG-10 Midi Controller For D-10, D-20, D110, & Many More
he PG-10 Programmer is designed for use with D-5, D-10, D-20, D-110 and GR-50
https://www.roland.com/us/support/knowledge_base/201939269/
« Last Edit: February 09, 2019, 10:19:17 PM by chrisNova777 »
Re: Roland PG-10 (1988)
« Reply #1 on: September 29, 2020, 06:49:48 PM »
original power supply details
ac 120v 60Hz 8W out: DC 9v 200mA
center negative
outside positive
(the polarity noted on the PG-10 unit is the same of course, center negative, outside positive)
« Reply #2 on: September 29, 2020, 06:58:43 PM »
i believe this is a new version of the old psa-120 adapter, renamed to the psa-120T
AC 120V 60Hz 9W
OUT: DC 9.6V 200mA
center negative
outside positive
(negative or reverse polarity)
« Reply #3 on: September 29, 2020, 07:02:41 PM »
thers also a PSA-120S model now
https://www.boss.info/ca/products/psa_series/
https://www.sweetwater.com/store/detail/PSA120S--roland-psa-120s-power-supply
500 mA of current to easily power multiple pedals, even digital ones
Power cable length is increased to almost 10 feet
LED indicator for quick visual verification of on/off status
New design which does not cover adjacent power outlets
*photo: PSA-120S/120 V type
Get the right BOSS Power Supply!
The Roland/BOSS PSA-120 adapter converts AC wall current to 9 volts DC current. If you want to save money on batteries and ensure stable performance gig after gig, the BOSS PSA-120 adapter is the recommended power supply unit for products including many BOSS compact pedals, the DB-66/88 metronomes, FC-Series foot controllers, MC-202, SH-101, SP-202, TR-626, and all TU-Series tuners. Capable of powering any BOSS effect pedal, the Roland/BOSS PSA-120 can also power equipment with digital circuitry.
Roland/BOSS PSA-120 Features
Capable of powering any BOSS effect pedal, including those with digital circuitry.
Converts AC wall current to 9 volts DC current. Power supply designed to operate a multitude of BOSS and Roland products.
Regulated with a higher milliamp rating for use with digital equipment.
Output: DC9V (regulated), 500mA
Tip negative, sleeve positive
3-meter cable
Status light that flashes if there are grounding problems
Small footprint (similar to a cell phone charger)
For consistent effects pedal performance night after night, gig after gig, choose the Roland/BOSS PSA-120 AC adapter!
Tech Specs
Type:   Roland/Boss Power Supply
Output Amps:   500mA
Output Voltage:   9V DC
Sleeve/Tip Configuration:   Sleeve: Positive, Center: Negative
Manufacturer Part Number:   PSA-120S2
