Author Topic: USB MIDI KNOWN TO WORK with Apple Connection Kit (Ipad 2, Iphone 4s)  (Read 4178 times)
https://seosocially.com/ipad-apple-connection-kit-compatible-midi-keyboard-controllers/
this list was originally part of iosmidi.com
https://web.archive.org/web/20110902071444/http://iosmidi.com/
https://web.archive.org/web/20140421063159/http://iosmidi.com/
https://web.archive.org/web/20160313033122/http://iosmidi.com/
https://www.youtube.com/watch?v=1u8XLzbjYn4
https://www.youtube.com/watch?v=-e8xzqEZr5g
2 types of apple connection kid
type1: https://www.amazon.com/Apple-iPad-Camera-Connection-Kit/dp/B003RV3N1C/ref=as_li_ss_tl?s=mp3&ie=UTF8&qid=1455367394&sr=8-1&keywords=MC531ZM/A&linkCode=sl1&tag=seso04-20&linkId=da81931465446bdb2dd2589a3f202fc3
type2: https://www.amazon.com/dp/B014VGHG0U/ref=as_li_ss_tl?ie=UTF8&qid=1455365981&sr=8-4&linkCode=sl1&tag=seso04-20&linkId=dd21343bece01c7fa1ea83d62ba9d946
Akai EWI USB
Akai LPD8
Akai APC-40 (via powered USB hub)
Akai LPK25 (has power issues for some users)
Akai MPK49 & MPK61 (via powered USB hub)
Akai MPK25 (via USB hub)
Akai MPK Mini (plug in while iPad is in sleep mode and wait for connection)
Akai RPM3 (audio only)
Akai Synthstation (works via USB hub)
Akai Synthstation 49
Akai Professional AFX Controller (Powered USB Hub needed)
Akai Professional AMX Mixing Surface (Powered USB Hub needed)
Akai APC Key 25
Akai APC mini
Akai APC Key 25
Akai APC20
Akai APC40 mkii (Powered USB Hub needed)
Akai APC40*
Akai EWI5000 (Powered USB Hub needed)
Akai LPD8
Akai LPK25
Akai MAX25 (Powered USB Hub needed)
Akai MAX49 (Powered USB Hub needed)
Akai MPK mini
Akai MPK mini MKII (Powered USB Hub needed)
Akai MPK225 (uses a built-in low power mode with limited LED operation)
Akai MPK249 (uses a built-in low power mode with limited LED operation)
Akai MPK261 (uses a built-in low power mode with limited LED operation)
Akai MPK25(Powered USB Hub needed)
Akai MPK49 (Powered USB Hub needed)
Akai MPK61 (Powered USB Hub needed)
Akai MPK88 (Powered USB Hub needed)
Akai MPX16 (Powered USB Hub needed)
Akai MPC Element
Akai MPC Studio
Akai SynthStation 25 (Powered USB Hub needed)
Akai EIE (Powered USB Hub needed) (only 2-channel input possible)
Akai Pro MPD218
Akai LPD8
Akai LPK25
Akai SynthStation 25: ( powered usb hub required.)
Akai MPD26
Akai MPD32
Akai lpd8
Akai MPD18
Arturia 61 key Universal keyboard controller (powered usb hub required.)
Alesis DM6
Alesis DM10
Alesis iO Dock
Alesis iO2 (older model, via USB hub)
Alesis Photon X25
Alesis Q25
Alesis Q49 (works via USB bus – no external power necessary)
Alesis GuitarLink
Alesis MicLink
Alesis PhonoLink
Alesis Q49
Alesis iO2
Alesis iO2 Express
Alesis iO4 (only 2-channel input possible)
Alesis V61
Alesis V25
Alesis VI25
Alesis QX25
Allen & Heath XONE:K1
Allen & Heath XONE:K2
Aturia Analog Factory CME Controller Keyboard
Audiotrak MIDI Mate
American Audio VMS4 DJ (works with power supply, audio on channel 1 works also)
Arturia Analog Factory ‘The Laboratory’ 49 Key (using supplied power adaptor)
Arturia Minilab
Arturia BeatStep
Arturia KeyLab 25
Axiom 49 (2nd Gen)
Axon AX 50
Behringer BCF2000 (experiment with output ‘modes’, U-4 works well for in & out)
Behringer BCR2000 (experiment with output ‘modes’, U-4 works well for in & out)
Behringer iAxe 323 USB Guitar (audio only)
Behringer UMA25S (audio & MIDI)
Behringer UMX25
Behringer UMX61
Behringer UMX490
Behringer CMD DC-1
Behringer CMD LC-1
Behringer CMD MM-1
Behringer X-Touch Mini
Bespeco MIDI Cable
Carillon M1X1
Casio DG-20 Guitar Synth
Casio Privia PX-130
Casio WK7500
CME U2MIDI
CME U-Key 49 Mobiletone
Dave Smith Instruments Tetr4
Digitech GNX4 (audio & MIDI)
DSI Mopho Keyboard
DSI Tetra
Doepfer Dark Energy
Doepfer Dark Time
DJ TechTools Midi Fighter Twister
DJ TechTools Midi Fighter 3D
Denon HC4500 – Working (Midi Only)
E-MU X MIDI 1×1 Tab
E-MU Xmidi 2×2
EDIROL PCR-M80 (use settings to set USB driver to ‘generic’ [see instruction manual] – thanks Lorenzo!)
EDIROL PCR-1 (via USB Hub, audio interface also works)
EDIROL PCR-A30 (via adaptor or USB Hub, audio doesn’t work)
EDIROL PCR-30 (set USB mode driver to ‘generic’)
EDIROL PCR-300 (set USB mode driver to ‘generic’, works with Boss PSA-120T power adaptor, and PSB1-U also. PSU rated at +9.6 VDC 200mA center-negative.)
EDIROL PCR-800 (set USB mode driver to ‘generic’)
EDIROL UA-1D (via USB hub, adds noticeable latency)
EDIROL UA-25EX (via USB hub, audio only)
EDIROL UM-1ex (set USB mode driver to ‘generic’)
EDIROL UM-1sx
EDIROL UM-2ex (NB: Roland UM-2 [not EDIROL] does not work)
Elektron TM-1
ESI KeyControl 25 XT
ESI M8U
ESI Midimate II
Evolution MK-361C (works without external power or hub needed)
Elektron TM-1
Focusrite VRM Box (via USB Hub, hardware only)
Fatar 88
Faderfox UC4
Faderfox Versus
Faderfox PC4
Faderfox SC4
Faderfox UC3
Faderfox DJ3
Genovation 900-MPC Midi Patch Changer
HDE USB to MIDI Cable ($5 on Amazon!)
ION Audio Discover DJ(Powered USB Hub needed)
ION Audio Discover Guitar USB
IK Multimedia iRig Pads
JamHub TourBus (via USB hub)
JamMate RockFrog
Kawai MP8II
Korg KP3 KAOSS PAD
Korg Kaossilator Pro (instruction manual [PDF] has useful info for settings)
Korg K25
Korg Kontrol 49 (with power adaptor)
Korg microSAMPLER & microKONTROL
Korg Taktile 25
Korg M3
Korg M50
Korg microKEY 37 (via USB hub)
Korg MicroX
Korg MS-20 (via hub)
Korg nanoKEY, nanoPAD & nanoControl
Korg nanoKONTROL Studio
Korg PadKONTROL
Korg Pandora PX5D
Korg R3 (using supplied power supply)
Korg RADIUS
Korg Triton TR Series
Korg X50
Kurzweil PC3
Keith McMillen QuNexus
Keith McMillen QuNeo
Livid Block (via powered USB hub)
Livid Block Ohm64 (via powered USB hub)
Livid Base 2
Livid DS1
Livid Alias 8
Livid Code v2
Livid CNTRL:R
Lexicon Omega
Line 6 Pocket POD (MIDI only)
LogiLink USB MIDI Cable
Logitech Premium Notebook USB Headset (audio only – boom works for audio input, headphones monitor iPad output)
Mackie XD-2
Mistar MidiLink (may need a few tries to be recognised)
M-Audio Axiom 49 (1st gen) (mixed reports – try a USB hub)
M-Audio Axiom Pro 61
M-Audio Evolution X-Session (with 9V DC center-positive adaptor)
M-Audio Keystudio (via USB hub or with external power)
M-Audio Keystation Mini 32
M-Audio Axiom AIR Mini 32
M-Audio Axiom AIR 25
M-Audio Axiom 25 Mk2
M-Audio O2 (when plugged in)
M-Audio Oxygen 8 (with batteries/adaptor, via USB hub)
M-Audio Oxygen 8 3rd Gen
M-Audio Oxygen 25 3rd Gen
M-Audio Oxygen 25 Mk3
M-Audio Oxygen 25 Mk4
M-Audio Oxygen 49 (via powered hub)
M-Audio Oxygen 61
M-Audio Prokeys Sono 61
M-Audio Prokeys 88 (May not work on iPad Air 2, but should be good up to iPad 4th gen)
M-Audio Prokeys 88SX (May not work on iPad Air 2, but should be good up to iPad 4th gen)
M-Audio Uno 1×1 (Note: older models when M-Audio was called Midiman do not work. M-Audio changed name in 2002, newer/current models work fine.)
M-Audio Keystation 49a (set USB Driver to ‘generic’)
M-Audio Keystation Pro-88
M-Audio KeyRig
M-Audio XSession Pro
M-Audio X-session (Evolution UC-17)
M-Audio Venom (USB audio works well, MIDI a little patchy)
M-Audio Trigger Finger Pro
Moog Little Phatty Stage II
Moog Multipedal (Moog’s MIDI In get’s routed into the iPad also)
Nektar Impact LX25
Nektar Panorama P1
Novation Remote 25 LE
Novation Remote SL series
Novation Remote Zero SL MK1 (via hub or battery)
Novation X-Station (with power adaptor)
Novation Xio 25 (audio & MIDI)
Novation Remote SL-37
Novation X-Station 25
Novation Launchkey 49
Novation Launchpad mk2 (powered usb hub required)
Novation Original Launchpad
Novation Original Launchpad S
Novation Launchpad Mini mk2
Novation Launchkey Mini mk2
Novation Launchpad Pro
Novation Launch Control XL
Novation Impulse 25
Novation Launchkey 25
Novation 25 SL Mk2
Novation ZeRO SL Mk2
Novation Nocturn
Numark DJ2GO
Numark Total Control(Powered USB Hub needed)
Numark Stealth Control(Powered USB Hub needed)
Numark MIXTRACK(Powered USB Hub needed)
Native Instruments Komplete Kontrol S25 Controller Keyboard (works as a stand-alone MIDI controller with Apple Camera Connector into an iPad Mini 2 running Korg Module and Gadget apps. Great cool minimalist live setup, only downside is DIN MIDI out on the Kontrol 61 does not appear to work without an attached PC or MAC. Thanks Den)
With Apple Camera Connector into an iPad Mini 2 running Korg Module and Gadget apps. Great Native Instruments Komplete Kontrol S49 Keyboard (works as a stand-alone MIDI controller cool minimalist live setup, only downside is DIN MIDI out on the Kontrol 61 does not appear to work without an attached PC or MAC. Thanks Den)
Native Instruments Komplete Kontrol S61 Keyboard (works as a stand-alone MIDI controller with Apple Camera Connector into an iPad Mini 2 running Korg Module and Gadget apps. Great cool minimalist live setup, only downside is DIN MIDI out on the Kontrol 61 does not appear to work without an attached PC or MAC. Thanks Den)
Native Instruments Komplete Kontrol S88 Keyboard, 88-Key (works as a stand-alone MIDI controller with Apple Camera Connector into an iPad Mini 2 running Korg Module and Gadget apps. Great cool minimalist live setup, only downside is DIN MIDI out on the Kontrol 61 does not appear to work without an attached PC or MAC. Thanks Den)
NI Traktor Kontrol X1 Mk2
NI Traktor Kontrol F1
NI Maschine Mk2
NI Maschine Mikro Mk2
Presonus Audiobox USB (audio & MIDI, via powered hub)
Prodipe Midi USB 1i1o
Roland A-300PRO (A-500PRO, A-800PRO, and equivalently named Cakewalk products should also work – TBC)
Roland Cakewalk A-500S Master Keyboard (with batteries, advanced driver off)
Roland FP-7F
Roland HP 305
Roland Lucina
Roland Octapad SPD-30
Reloop Keypad
Reloop Keyfadr
Sequentix Cirklon
Sonuus i2M Musicport
Studiologic VMK-161 (via powered hub)
Studiologic VMK-188
Swissonic MIID-USB 1×1
Samson Carbon 61
Samson Conspiracy
Samson Graphite 49
Steinberg CMC-FD
Steinberg CMC-QC
Steinberg CMC-PD
Terrasoniq MIDI ONE
Terratec Axon AX 50
Turtle Beach USB MIDI 1×1 (via powered hub, sometimes works without)
V-Machine VST Player
Waldorf Blofeld (desktop version)
Yamaha E430
Yamaha Ez250i
Yamaha KX-8
Yamaha PSR-S900
Yamaha S90ES
Yamaha Stage Piano 3P00 (external power needed, set local control off, MIDI on)
Yamaha UX-16
Yamaha WX-5 EWI (with adaptor, via USB hub)
Yamaha YDP-V240
Yamaha YPG-235
Yamaha YPG-625
Zoom A2.1u (audio only, via USB hub)
Zoom H4n (audio only)
Zoom R16 (audio only, via USB hub)
Zomm G2.1U – Working (only audio in)
