if file attachments or images are not being displayed you may need to register/login
some areas of the website will be changing to be members only access ; if you have trouble accessing pages the solution is to register for your own user account
Author Topic: notes re: work in progress  (Read 268 times)
« on: June 06, 2019, 10:15:50 PM »
http://mirror.informatimago.com/next/developer.apple.com/referencelibrary/LegacyTechnologies/idxMacOS9Earlier-date.html
http://web.archive.org/web/20020206231359/http://developer.apple.com/techpubs/hardware/DeviceManagers/pci_srvcs/pci_srvcs.html
http://web.archive.org/web/20020220115411/http://developer.apple.com/techpubs/hardware/DeviceManagers/pci_srvcs/pci_cards_drivers/index.html
http://web.archive.org/web/20010414035316/http://developer.apple.com/techpubs/hardware/DeviceManagers/nameregistry/nameregistry.html
http://mirror.informatimago.com/next/developer.apple.com/documentation/Hardware/DeviceManagers/pci_srvcs/pci_cards_drivers/Designing_PCI_Cards_Drivers.pdf
http://cdn.preterhuman.net/texts/computing/apple_hardware_devnotes/PowerMac%20G4%20Original.pdf
https://web.archive.org/web/19991115084350/https://developer.apple.com/techpubs/hardware/DeviceManagers/ata/ata_ref/frameset.html
http://www.firmworks.com/open_firmware/literature/ofpci.pdf
http://mirror.informatimago.com/next/developer.apple.com/hardware/pci/pdf/4th_OF_A.pdf
http://mirror.informatimago.com/next//developer.apple.com/
https://staticky.com/mirrors/ftp.apple.com/developer/
https://staticky.com/mirrors/ftp.apple.com/developer/Development_Kits/
https://web.archive.org/web/20031204232033/https://developer.apple.com/DOCUMENTATION/
http://hampa.ch/pub/software/MacOS/Doc/Inside%20Macintosh/
https://web.archive.org/web/20030419055355/http://developer.apple.com/tools/index.html
https://web.archive.org/web/20030202022643/http://developer.apple.com/tools/legacy.html
https://web.archive.org/web/20030413203552/http://developer.apple.com/macos/macos9.html
https://web.archive.org/web/20030604101734/http://developer.apple.com/tools/frameworks.html
https://web.archive.org/web/20030419092556/http://developer.apple.com/tools/compilers.html
https://web.archive.org/web/20030421022014/http://developer.apple.com/tools/editors.html
http://web.archive.org/web/20021017103007/http://developer.apple.com/techpubs/hardware/hardware.html
https://web.archive.org/web/20030419075713/http://developer.apple.com/techpubs/hardware/DeviceManagers/devicemgrs.html
https://web.archive.org/web/20030412162308/http://developer.apple.com/techpubs/hardware/DeviceManagers/ata/ata.html
https://web.archive.org/web/20030413183722/http://developer.apple.com/technotes/tn/tn1098.html
https://web.archive.org/web/20030420030051/http://developer.apple.com/techpubs/hardware/DeviceManagers/ata/ata_ref/frameset.html
https://web.archive.org/web/20040516051343/http://developer.apple.com/documentation/Hardware/Developer_Notes/System_Software/ATA_Device_Zero_One.pdf
http://mirror.informatimago.com/next/developer.apple.com/technotes/tn/tn1192.html
https://web.archive.org/web/20030820220922/http://developer.apple.com/documentation/hardware/DeviceManagers/ata/ata_ref/ATA.1.html
https://web.archive.org/web/20030804110451/http://developer.apple.com/documentation/hardware/DeviceManagers/pci_srvcs/pci_srvcs.html
https://web.archive.org/web/20030803175516/http://developer.apple.com/technotes/tn/tn1008.html
https://web.archive.org/web/20030801082259/http://developer.apple.com/technotes/tn/tn1061.html
https://web.archive.org/web/20030806053311/http://developer.apple.com/technotes/tn/tn1062.html
https://web.archive.org/web/20031001134450/http://developer.apple.com/technotes/tn/tn1044.html
https://www.ics.uci.edu/~harris/ics216/pci/PCI_22.pdf
http://www.cisl.columbia.edu/courses/spring-2004/ee4340/restricted_handouts/pci_23.pdf
"Writing FCode Programs for PCI"
http://docshare02.docshare.tips/files/8443/84436102.pdf
Standard for Boot(Initialization Configuration)Firmware
https://www.openfirmware.info/data/docs/bus.pci.pdf
https://www.openfirmware.info/data/docs/dpans94.pdf
https://www.openfirmware.info/data/docs/of1275.pdf
https://www.openfirmware.info/data/docs/rec.intmap.d09.pdf
https://web.archive.org/web/20030410013250/http://developer.apple.com/sdk/index.html
https://web.archive.org/web/20030806104420/http://developer.apple.com/samplecode/
https://web.archive.org/web/20030219130746/http://developer.apple.com/samplecode/Sample_Code/Devices_and_Hardware/ATA/ATADemo.htm
https://web.archive.org/web/20030306142549/http://developer.apple.com/samplecode/Sample_Code/Devices_and_Hardware/ATA/ATAErrorDetector.htm
https://web.archive.org/web/20021017103007/http://developer.apple.com/techpubs/macosx/Darwin/index.html
https://web.archive.org/web/20021220044746/http://developer.apple.com/techpubs/macosx/Darwin/General/WritingDeviceDriver/index.html
https://web.archive.org/web/20021212083654/http://developer.apple.com/techpubs/macosx/Darwin/General/KernelProgramming/index.html
https://web.archive.org/web/19991115034049/http://developer.apple.com/sdk/index.html
https://web.archive.org/web/20030410013250/ftp://ftp.apple.com/developer/Development_Kits/PowerManager_DDK_1.0.img.bin
http://web.archive.org/web/20040713003428/http://developer.apple.com:80/documentation/Hardware/DeviceManagers/usb/usb_ref/usb_api_ref_v26.pdf
« Last Edit: June 12, 2019, 08:11:52 AM by chrisNova777 »
Re: notes re: work in progress
« Reply #1 on: June 12, 2019, 08:53:19 AM »
http://mirror.informatimago.com/next/developer.apple.com/documentation/mac/Devices/Devices-2.html
mirror.informatimago.com/next/developer.apple.com/documentation/mac/Devices/Devices-10.html#HEADING10-0
http://mirror.informatimago.com/next/developer.apple.com/documentation/mac/Devices/Devices-14.html#MARKER-9-113
writing a device driver
https://web.archive.org/web/20030801125655/http://developer.apple.com/documentation/macos8/mac8.html
https://web.archive.org/web/19990508211845/http://www.apple.com/developer/
https://web.archive.org/web/19990418034253/http://developer.apple.com/macos/intro.html
https://web.archive.org/web/20020603160623/http://developer.apple.com/macosx/gettingstarted/
https://web.archive.org/web/20020416030849/developer.apple.com/index.html
https://web.archive.org/web/20011217002412/http://developer.apple.com/qa/index.html
development kits
http://web.archive.org/web/19990223215603/http://developer.apple.com/sdk/
https://web.archive.org/web/20031207054637/http://developer.apple.com/sdk/index.html
technotes
http://web.archive.org/web/19990508223428/http://developer.apple.com/technotes/
https://web.archive.org/web/19990422111902/http://developer.apple.com/technotes/hw/hw-1.html
https://web.archive.org/web/19990421082100/http://developer.apple.com/technotes/dv/dv-1.html
https://web.archive.org/web/20011216185433/http://developer.apple.com/technotes/index.html
techpubs
https://web.archive.org/web/20020205082843/http://developer.apple.com/techpubs/
http://web.archive.org/web/20001109133700/http://developer.apple.com/techpubs/
tools
https://web.archive.org/web/20020126113429/http://developer.apple.com/tools/
sample code
https://web.archive.org/web/20020603173300/http://developer.apple.com/samplecode/
hardware
https://web.archive.org/web/20031011063839/http://developer.apple.com/hardware/
https://web.archive.org/web/20001109135500/http://developer.apple.com/techpubs/hardware/hardware.html
https://web.archive.org/web/20011217114720/http://developer.apple.com/techpubs/hardware/hardware.html
https://web.archive.org/web/20011217003244/http://developer.apple.com/techpubs/hardware/hardware2.html
https://web.archive.org/web/20020127070715/http://developer.apple.com/techpubs/hardware/Updates/updates.html
https://web.archive.org/web/20020224080656/http://developer.apple.com/techpubs/hardware/reference_info/hardwarerefinfo.html
https://web.archive.org/web/20011202005239/http://developer.apple.com/techpubs/hardware/DeviceManagers/devicemgrs.html
http://web.archive.org/web/20001215132900/http://asu.info.apple.com/swupdates.nsf/artnum/n11543?OpenDocument
http://macintoshgarden.org/apps/apple-developer-connection-software-seed-cd-rom-november-2000
http://macintoshgarden.org/apps/apple-developer-connection-software-seed-cd-rom-december-2000
http://macintoshgarden.org/apps/apple-developer-connection-software-seed-cd-rom-april-2001
https://web.archive.org/web/20020603175712/http://developer.apple.com/seeding/
https://web.archive.org/web/20020407181340/http://developer.apple.com/faq/
https://web.archive.org/web/20020603154625/http://developer.apple.com/devnews/
https://web.archive.org/web/20020603154415/http://developer.apple.com/events/
https://web.archive.org/web/20011116010057/http://www.info.apple.com/support/downloads.html
https://web.archive.org/web/20011116001812/http://download.info.apple.com/Apple_Support_Area/Apple_Software_Updates/
https://web.archive.org/web/20011116003344/http://www.info.apple.com/support/oldersoftwarelist.html
https://web.archive.org/web/19991011021430/http://developer.apple.com/hardware/usb/
https://web.archive.org/web/20000303154250/http://developer.apple.com/hardware/usb/usbmacos.htm
https://web.archive.org/web/20011127060659/http://www1.fatbrain.com/documentation/apple/
https://web.archive.org/web/20010207002907/http://www.oreillynet.com/mac/
https://web.archive.org/web/20011205235440/http://www.oreillynet.com/mac/
http://www.macdevcenter.com/pub/a/mac/2003/06/24/wwdc_2003.html
https://web.archive.org/web/20141113152401/http://archive.oreilly.com/mac/
https://archive.org/details/apple-guide-macintosh-family-hardware
http://www.weihenstephan.org/~michaste/pagetable/mac/Inside_Macintosh.pdf
« Last Edit: June 12, 2019, 10:03:13 PM by chrisNova777 »
