Author Topic: M-Audio DMP3  (Read 2451 times)
M-Audio DMP3
« on: July 07, 2019, 06:51:21 PM »
DMP3
https://www.gearslutz.com/board/m-audio/dmp3-g1849/
The M-Audio DMP3 2-Channel Mic Pre/Direct Box gives you XLR microphone and 1/4" instrument inputs. Balanced TRS outputs deliver hum-free professional-quality audio. Low harmonic distortion for ultraclean sound. Exceptional dynamic range allows you to capture all the nuances of the music. High- and low-gain range controls offer up to 66dB of gain. Classic VU meters and clip LEDs help you avoid detrimental levels. Low-cut filters remove unwanted rumble. Features phantom power to accommodate all types of microphones. Phase reverse switch on each channel ensures optimal recordings.
FEATURES
Especially useful for optimizing signal levels, recording with soundcards, and direct recording of instruments
SPECIFICATIONS
Frequency Response: 20Hz - 80kHz, +/-0.5dB @ max gain
SNR: -120dB, A-weighted, 20Hz to 20kHz
THD+N: 0.00035% (-109dB), 20Hz to 20kHz, @ +13.6dBu input
Max Input: +14.6dBu
Max Output: +27.5dBu
Input Impedance: 3kÎ balanced
EIN: -128dBm @ 600&Ooega;, max gain
Gain Range: 13.5dB to 46.5dB, low gain range, 39.5dB to 72.5dB, high gain range
Low-Cut Filter: -3dB @ 72Hz (18dB/Octave)
https://www.musiciansfriend.com/pro-audio/m-audio-dmp3-2-channel-mic-pre-direct-box
https://www.zzounds.com/productreview--MDODMP3
https://tapeop.com/reviews/gear/30/dmp3-mic-pre/
https://reverb.com/ca/item/71080-m-audio-dmp3-dual-mic-pre-and-direct-box
https://www.guitarcenter.com/M-Audio/DMP3-2-Channel-Mic-Pre-Direct-Box.gc
