MIDI > Thru Boxes, Mergers, Patchbays & Sync Boxes
friendchip dmx-16
(1/1)
chrisNova777:
https://web.archive.org/web/20130723043001/https://www.friend-chip.de/dmx16dia.htm
Friend-chip Digi Max 16
https://www.musicstore.com/en_NO/NOK/Friend-Chip-Digimax-16-Digitalpatchbay-19-for-4x4-Module/art-REC0001711-000
--- Quote ---The mainframe contains the controller and MIDI interface and a pair of coax. and optical inputs and outputs on the front panel.
Four modules can be inserted (each with 4 inputs and 4 outputs) to build a matrix from 6 x 6, upto 16 x 16. Any combination of modules may be assembled, so that AES, SP-DIF, and ADAT format can share one matrix. Any physical conversion between optical, coaxial, balanced and unbalanced is done within the matrix. If data conversion (CONSUMER/PROFESSIONAL) is needed please refer to our MQ4 format converter module.
ADAT format can be switched and distributed with the MOP4 module. If conversion between AES SP-DIF and ADAT "lightpipe" or TDIF is needed please refer to our MQA or MQT module.
MATRIX 16 x 16 crosspoint matrix 1 into 16 signal distribution
INPUTS, OUTPUTS depending on installed modules
PRESETS 50 memory locations
REMOTE MIDI program changes MIDI sysex. remote software
--- End quote ---
https://www.friend-chip.de/more1.htm
Navigation
[0] Message Index
Go to full version
