« on: August 02, 2019, 03:53:25 AM »
https://web.archive.org/web/20040401161205/http://www.rgcaudio.com/sfz%2B.htmhttps://web.archive.org/web/20040328030111/https://www.rgcaudio.com/
Requirements:
800x600 minimum screen resolution.
800 MHz or faster processor, SSE-capable processor recommended, 128Mb of RAM or more recommended.
Feature Set
Main Engine
High Quality bandlimiting sample-playback engine.
9 quality settings to allow precise CPU usage optimization.
256 voices of polyphony, unlimited layers per voice.
Per-channel polyphony limiter.
Fully multitimbral operation, supports all 16 MIDI channels.
Allows loading one file per MIDI channel, or single-file multitimbral operation.
Supports any standard/custom samplerate, including 22, 32, 44.1, 48, 88.2, 96, 192 and 384 kHz.
Extensive SoundFont compatibility.
Reads SoundFont files (.sf2), 16/24/32-bit wave files (.wav), mono or stereo.
Several SoundFont loading modes: Whole SoundFont, Single Preset, Direct-from-Disk streaming.
Four stereo outputs, one stereo Effects output.
Sound Generator
A LPF, two LFOs and two Envelope Generators per layer.
Filter Cutoff, Filter Resonance, Keyboard Tracking, Velocity Tracking and Envelope Amount.
Vibrato LFO with Delay, Speed and Depth control.
Modulation LFO with Delay, Depth, Filter Depth, Pitch Depth and Amp Depth controls.
Modulation EG with Attack, Hold, Keyboard-To-Hold, Decay, Keyboard-To-Decay, Sustain, Release and Pitch Depth controls.
Amplifier EG with Delay, Attack, Hold, Keyboard-To-Hold, Decay, Keyboard-To-Decay, Sustain and Release controls.
Effects
Stereo Chorus with Mix, Speed and Depth controls.
Stereo Reverb with Mix, Size, Damp and High Frequency controls.
Effects on/off button.
Programs / Banks
128 internal programs (scenes).
Saves and Loads standard program (.fxp) files.
Drag and drop support for program files (.fxp), SoundFont files (.sf2) and Wave files (.wav).
All settings saved in the song.
Graphic User Interface
Total Layers and Voices played indicator.
Focus-capable controls, full PC-Keyboard support.
Full mouse wheel support.
Inertial sliders, menu-driven multi lists, fast page selectors.
Output level VU meter.
Sound Preview ribbon at bottom, MIDI transmit to host (VST).
MIDI implementation
Extensive MIDI implementation: Velocity, Pitch Bend, Modulation, Sustain Sw and a lot more.
ASIO microHost
Ultralight ASIO host for live performance and programming (90k)
Supports 44.1, 48, 88.2 and 96 kHz samplerates.
Virtual keyboard with PitchBend/ModulationProgram Change/Transpose controls using PC keyboard.
Simultaneous use of multiple MIDI ports.
Saves 16-bit and 32-bit WAV files direct-to-disk.
« Last Edit: August 02, 2019, 03:54:25 AM by chrisNova777 »
Logged
