Author Topic: Saffire Pro 14 (Oct 2010)  (Read 8208 times)
« on: January 28, 2020, 11:23:17 AM »
https://www.soundonsound.com/news/little-gem
https://www.musiciansfriend.com/pro-audio/focusrite-saffire-pro-14-audio-interface
https://www.emusician.com/gear/focusrite-saffire-pro-14
https://www.musicradar.com/news/tech/focusrite-announces-saffire-pro-14-270565
https://resource.focusrite.com/en/press-archive/press_releases
https://resource.focusrite.com/sites/default/files/download/SaffirePRO14_PressRelease.pdf
Two high-quality award-winning Focusrite preamps based on Focusrite's 25-year
legacy
High-quality 24-bit/96kHz FireWire interface: Features professional conversion and JetPLL jitter elimination technology, guaranteeing pristine audio quality and reliable synchronization.
Total I/O count of 8 inputs and 6 outputs: A host of I/O options are provided, including a unique Loopback facility for routing audio between software applications via Saffire MixControl.
Saffire MixControl ultra-low-latency: DSP mixer/router Provides an 18 x 6 DSP mixer with excellent routing flexibility, intuitive one-click configurations, and lower than 1.4ms latency (less than the time it takes sound to travel two feet through air).
Focusrite VST/AU Plug-in Suite, for use in the mix: Upgrade your standard sequencer effects and bring a touch of class to your session with Focusrite Compression, Reverb, Gating and EQ VST/AU plug-ins.
Xcite+ Software Bundle: Featuring a host of royalty-free loops and samples, a full-fledged soft-synth and Ableton Live Lite 8, providing an affordable upgrade path to Ableton Live.
Two Hi-Z instrument inputs: No need for a separate DI. The first two channels feature high-gain instrument inputs.
Bus-powered for a tidy mobile recording rig Saffire PRO 14 can be powered via FireWire, or via its own power supply.
Dedicated front-panel headphone bus Providing a fully customized monitor mix, with tactile level control available on the front panel.
Tactile Monitor dial: A front panel volume dial provides immediate control over the main stereo outputs.
Switchable phantom power: Across both mic pre inputs, globally switchable direct from the front fascia.
Software PFL: Allows the mix engineer to easily monitor a single mixer channel or complete mix.
