This barely made it to 2000 & to windows from DOS but much had not changed so I figure it as vintage still as far as classification here...
Once a commercial product but in the end made free...
Been giving this a look to be makin' a tune in as it sounds fine, synth portion actually pretty good...
Just didn't know about rendering to disc-
Testing WAV Render found that manual is useless as manual is updated version '2' & not applicable. The manual right there on the GUI is though...But the WAV Render did not work for me but the Disc Streaming did. Open the 'setup' button & choose the 'RenderToDisc' option, Open your tune AND open your C root directory, Now press 'play' & in a few seconds you should see 'test.wav' show up on C root dir. Let tune play & shut off right after it ends, rename WAV & take into editor & trim off fat...
Installed version 2 which won't run on XP but it did have some extra song files that work & an extra DrumKit...all Included...
Also-
Nice subtractive synth, alluring GUI, sounds pretty good (way better than early Fruity Loops), Uses MIDI Controllers & also Controller Knobs for automation (or onscreen use), Coded by Dutch Group...ReBirth Users ought to like this...
This has 'smart patterns' which Arguru incorporated into NoiseTrekker 2 and are STILL in present modern updated Protrekkr 2.6.2...
So we have a long lost relative here...
Rendered out some of the demo songs, other than trimming off excess or fading out ends Then converting to MP3 they are not processed in any other way...
