Recent | Who's Online | Vintage Software Modern Software | Gfx | Windows | Mac  MacOS9 | IBM/DOS | ATARI ST | AMIGA | Midi Interfaces | Sequencers |
Roland "MC" | E-mu | Ensoniq | MPCs | Samplers | Akai "S" | Roland "S" Samplers + WorkstationsSynths | soft-Samplers | soft-Synths (VSTi) | Roland "JV" | Modules | Drums | Tape | Mixers | hardware Effects | software Effects | software Timeline | HackintoshReason | Artists | Firewire interfaces | USB interfaces | iOS | android | "there's no future without a past"  ***Guests must register / log in to see + download files attached to a post left + right arrow keys move forward and backward through threads
Author Topic: New/old audio PC - Which OS?  (Read 1297 times)
Offline G40
« on: July 28, 2022, 05:39:06 AM »
Currently I have an almost up to date machine running Windows 10 which I use for general duties and running Reaper, plus multiple machines running Windows 98SE so I can run much older stuff (I'm using Cubase 2.8 lots - and I can't get it to work in XP or anything later - also various versions of Cakewalk and other bits and bobs).
I've found myself with a bunch of spare older machines, a couple of P4s and a Core Duo and am thinking about a midway point retro machine - maybe treat it to an older RME card and try running Reaper plus some older stuff like Sonar, Reason, Project 5 etc. It probably won't ever see a network or go online, so I'm not too bothered about security/updates. I like working offline as there are no distractions and Windows 10 is way too "connected" for my liking.
I'm torn between using XP and 7. I like some of the features in 7 but I'm also wondering whether older=leaner=better. I suspect any of the machines I have will run XP nicely, the later Core Duo was built for 7 so I know I'll have no issues with drivers.
Any thoughts?
Offline Project5er
  • Sr. Member
  • Older Code, Cleaner Code
Re: New/old audio PC - Which OS?
« Reply #1 on: July 28, 2022, 07:35:34 AM »
Plenty of thoughts....I run XP pretty much exclusive & don't much like anything else but tried it all...
I DO HAVE 2 windows 10 machines that are newer that a neighbor gave me for free for doing favors to their property whilst away...
Can't really stand that OS, It is truly spyware & I never let either 'hook-up' ever...I only have one machine hook-up to internet via CABLE (no wi-fi here, no cell towers near at all) which is an old Dell D820 with XP...10 of my 12 machines are XP...
Windows 7 is OK & is somewhat like XP but uses quite a bit more resources plus there are still the 'ADMIN' bullshitz, in XP none of that you are FREE to do anything unrestricted...
Using XP you can use low RAM amounts & be just fine, my machines anywhere from 1 GB to 4 GB RAM & mostly I try to find ones with nvidia graphics as I do 3D stuff too & like to run the rare Nichimen Mirai & others which work perfect in XP...
For audio work most old 'media center' editions are pretty choice...I recently bought an old Toshiba Satellite P25 as such off ebay that was in MINT condition with big 17 inch screen & original discs for 40 bucks plus ship...This laptop 10 lbs built real good with 3 fans...Just has a single core but is 2.8 GHZ so absolutely no problem for audio apps...Has nvidia card but only 32 MB RAM so not so good for some graphics apps...
You can really dress XP up & there are so many cool utilities for it that make it way more wonderful than it is...Once you do this sort of thing & really customize XP up the way you will never be able to in windows 7-10 you will be ruined for life as using newer windows you would rather eat your own vomit instead...
I can never understand why some just leave their XP machines basically stock...Opinions vary I guess...
Anyways if you decide to go XP I can help you with cool utilities...
Everything I post on here running fine on all my XP machines...
Offline G40
« Reply #2 on: July 30, 2022, 08:23:18 AM »
I'm thinking I'll install XP on the faster Dell P4 machine below - should be a pretty nice machine - maybe save the IBM/Lenovo P4 (specs also below) for a win98 setup... which should fly.
« Last Edit: July 30, 2022, 02:34:32 PM by G40 »
Offline foksadure
« Reply #3 on: July 30, 2022, 10:20:10 AM »
Any thoughts?
About running 16bit software without using virtualization, there's a new technique that's worth a shot, OTVDM :
http://www.columbia.edu/~em36/otvdm.html
https://techcommunity.microsoft.com/t5/windows-dev-appconsult/running-16-bit-applications-on-windows-10-64-bit/ba-p/1671418
https://github.com/otya128/winevdm
I had a peek at it last night, and our beloved Cubase 2.8 or 3.05 do start on my Win10x64 computers... until the dongle check (real or "emulated"). Seems it can't find the cubase.386 setting and vxd which seems okay to me in the OTVDM folder.
There's hope!
About your CPU of choice, remember Win9x does not support multicore CPU.
That means the best P-III, P-4 or AthlonXP you can find will be more than enough.
I've an old P-III 1000 (w/ISA slots) dual boot Win98SE/Win2K tower laying around, but I'm currently using a dual-boot Win98/XP NEC Versa M320 laptop with a P-4 2.0GHz CPU that has all the old peripherals (serial, parallel, integrated floppy, CDR). Works like a charm despite the unavoidable 9x BSOD now and then. Even class compliant USB audio device are working on both OS, which is a pleasant surprise. On XP, the network card allows access to LAN ressources (e.g. NAS) for backups or data transfert.
Internet access is blocked at the router level for this machine's IP, which is no big loss since it can't decently do any decent web browsing anyway given how websites or webapps have become overbloatted and sluggish.
« Last Edit: August 13, 2022, 03:39:31 PM by foksadure »
Offline G40
« Reply #4 on: July 30, 2022, 02:32:54 PM »
Yep, both machines I'm talking about for XP and 98 are P4s. I might put Linux on the Core duo and use it for general office stuff.
I had the same experience running Cubase 2.8 in XP - it boots up OK but can't find the dongle/crack.
Offline Project5er
  • Sr. Member
« Reply #5 on: July 30, 2022, 05:09:40 PM »
Interesting I find that much computerized equipment I see at veterinarian & doctors offices still use XP OS...If it works don't fix it!!
Offline G40
« Reply #6 on: August 06, 2022, 12:00:29 PM »
Currently installing 98SE on the slower of the two P4 machines. I've been using Cubase 2.8 a fair bit, but having installed it on old laptops the limitation of not having a full-sized keyboard (or PCI slots) is proving an irritation. I'm hoping to experiment with a few different sound cards... So, for now, XP can wait. ;)
I think it would be nice to have a section on this forum where users can post info about retro setups that are working well for them. I'd be glad to contribute.
Offline G40
« Reply #7 on: August 13, 2022, 03:21:42 PM »
Well the P4/98 machine is cruising nicely running an ancient version of Cubase. I'll have a go at an XP machine some other time... :)
Offline foksadure
« Reply #8 on: August 13, 2022, 03:47:37 PM »
Nice setup!  :D
Those early 2K's IBM Thinksomething were overengineered, built like tanks and a pleasure to maintain.
I should have saved one from work when I had a chance, since they had 98 and XP drivers.
Offline G40
« Reply #9 on: August 14, 2022, 12:03:24 PM »
Actually this one (it's a thinkcenter E50 8772 - 78G) was a pig to install 98 on - would only boot into safe mode until I followed advice here https://www.vogons.org/viewtopic.php?t=41065 - specifically "Disable all 32-bit protected-mode disk drivers".
I then managed to find the correct IDE driver and it now seems to be working OK, although there are a bunch of unknown devices in Device Manager. I didn't manage to find a full set of drivers for the machine anywhere, for any OS.
(edit: I take it back, XP drivers but not windows 98, are available here: https://download.lenovo.com/eol/index.html)
Only irritation it that although it now has USB disk support (I installed nusb36.exe) external drives oddly show up twice, with two drive letters assigned.
Oh, and sometimes it seems to momentarily hang before disk operations. Still, generally speaking it's a speedy and practical machine.
Offline foksadure
« Reply #10 on: August 15, 2022, 08:28:02 AM »
Ours were 8303 Thinkcentre M42 (i845G chipset) that were certified for a bunch of Operating Systems (much like the Thinkpad R42 laptops):
https://www.ibm.com/common/ssi/cgi-bin/ssialias?htmlfid=872/ENUSAG02-0406&infotype=AN&subtype=CA&appname=skmwww
SOFTWARE REQUIREMENTS:
Operating System Software:  NetVista M42 systems are tested for
compatibility with the following operating systems.
           Windows XP Professional
           Windows XP Home Edition
           Windows 2000
           Windows NT 4.0
           Windows 98 Second Edition
           OS/2 Warp 4.0 and higher (select models)
The drivers section at IBM/Lenovo support website was an inextricable mess with unfriendly filenames, but you could try with drivers for these M42, depending on the PCI device ID.
Offline smilesdavis
« Reply #11 on: August 15, 2022, 11:26:06 PM »
win 3.1 on a certified machine
win 95 on a certified machine
you can always upgrade mmx233 from there
Offline G40
« Reply #12 on: August 16, 2022, 04:11:56 PM »
           Windows 2000
           Windows NT 4.0
Thanks. This machine has an SIS 661 chipset, I may do a bit more digging for drivers but for now it seems to be working well enough for my purposes.
My G40 laptop is also P4/XP era but (if memory serves) that was a breeze to install 98SE on, and it runs very well indeed (dual boot XP/98SE). I can't remember the details but google tells me it has an Intel 82852GM chipset, and it seems lenovo/IBM provided 98SE drivers... Just a shame that a laptop keyboard is less than optimal for Cubase, and that I can't put any PCI cards in it... :-\
Offline smilesdavis
« Reply #13 on: August 16, 2022, 05:40:08 PM »
just go with certified for... desktops
love my win 3.1 and win 95
Offline foksadure
« Reply #14 on: February 26, 2023, 07:06:39 AM »
WinVDM at work under Windows 10 x64
Offline smilesdavis
« Reply #15 on: February 27, 2023, 06:23:50 AM »
Emulations sigh
Youre missing the best part about retro tech
The expensive and time consuming process to hunt down
Fix get to work vintage computers to run your original dongled software on
Emulations are like cheating.
« Reply #16 on: February 28, 2023, 07:59:22 AM »
Ive only ever run windows 10 on 2010 hardware and it was not a good experience.
i just had to drop back from win10 to win7 on this machine im typing on now.. it was BSODing 10+ times a day..
i dont think windows 10 really runs well on  any hardware from before 2016
Offline G40
« Reply #17 on: March 16, 2023, 02:13:57 PM »
Out of interest the P4 hasn't had a lot of use recently as I've been playing with Cubase VST 5.1 on a G4 mac (under OS 9.2.2). I'm considering putting a SCSI card in the P4 machine and using it as a sample editing machine - I like Sound Forge much more than any mac audio editing software I've played with and as it has a floppy drive I can also read TX16W typhoon floppies, akai floppies etc.
I failed to get a MOTU midi timepiece parallel interface to work on it, which was a shame because MIDI only Cubase and non-usb MIDI was my end goal... not sure whether the interface is toast or the issue is with the PC. I was never quite happy with the Win98 install given the unknown devices in device manager. Maybe I'll have another play with it, might try the MOTU on another machine first though.
The Core 2 machine is running Reaper etc. under 64 bit Windows 7 so nicely that I got rid of the i5 Windows 10 machine. IMO 7 is a sweet spot in terms of usability vs bloat, I can do without the internet and rubbish but it feels modern in a good way.
I think my current ideal would be windows 7 for a "modern" 64 bit audio recording/mixing workstation, Mac OS9.2.2 for VST equipped Cubase, and a dual boot Win98/XP machine for running old PC stuff... oh, and I'm quite attached to my Amiga - nothing else quite makes the same noise!
As usual I'm spending more time fiddling with old equipment and computers than I actually am making music.
« Reply #18 on: March 21, 2023, 08:01:36 PM »
hey thats the whole reason for this site to exist.. to help get that technical mumbo jumbo stuff done asap and get on with being creative
