Author Topic: Sekd Arc 88 pci (1998)  (Read 10884 times)
« on: December 28, 2014, 01:21:03 PM »
http://web.archive.org/web/19981202064129/http://www.sekd.com/archive.htm
http://web.archive.org/web/19981203113357/http://www.sekd.com/ARC88_Card.htm
drivers
http://web.archive.org/web/20000620022011/http://www.sekd.com/archive.htm
Windows 95/98 Version 1.20
(05/19/99 - 485 KB)    Updated driver for the ARC 88 sound card - Windows 95/98.
Note: Read the included README.TXT before installing the new driver!
English Version
German Version
Windows NT Version 2.03
(08/27/99 - 625 KB)    Final driver for the ARC 88 sound card - Windows NT 4.0.
Note: Read the included README.TXT before installing the new driver!    Download
New MacOS Version 1.02
(1/31/00)     Final Mac Driver (ASIO improved) Works with G-4 Macs!
Features:
    PCI Interface card with 8 analog I/O‘s in 16 Bit
    Analog connection via breakout cable (RCA connectors)
    Digital connectors: optical TOS-Link (S/PDIF)
    Digital interface: Stereo 16 and 24 Bit
    Multi card support (Synchronization between cards via internal patch cable)
    Full Duplex Mode, Record while Playback with all I/O’s(Analog and digital using multiple cards)
    The ARC88 can be used with any available audio program that supports the Windows stereo driver standard
    Drivers for Windows 95
    Cubase VST support and drivers for Windows NT in development
    Max. Input Signal Level: 2V RMS
    Min. Input Signal Level: 150 mV RMS Line, 15mV RMS Mic
    Full scale range of the AD inputs: 1V RMS Line, 0.1V RMS Mic
    Input Impedance: 6,3 kOhms
    Input Signal bandwitdth: 20-20000 Hz
System Requirements:
    IBM compatible PC Pentium 166 or higher
    Windows™95
    free PCI slot
    min. 16 MB RAM
    1 GB hardisk space recomended
