Software > Modern Software (2000 + higher)
Studio One v5 & v6 require Windows 10
(1/1)
chrisNova777:
just got this error trying to install on win7 64
"this Application requires Windows 10 20H1 or later "
also.. trying to install the studio one v5 installer i got this error:
"this Application requires Windows 10 1703 or later"
i cant even install v3 on win7 without installing this "platform update" http://www.oldschooldaw.com/forums/index.php/topic,7619
i was finally able to install v3(64bit) after installin this update
--- Quote ---Studio One v4 Requirements (64bit)
Computer System Requirements
Studio One® is a modern, cross-platform DAW that is capable of operating as 64-bit application. While we make every effort to ensure Studio One will run well on the widest variety of computers possible, please read these specifications carefully to determine compatibility with your system.
Mac®
macOS® 10.11 or higher (64-bit only)
Intel® Core™ 2 Duo processor
(Intel Core i3 or better recommended)
Windows®
Windows 7 (SP1 + platform update), Windows 8.1 or Windows 10 (64-bit only)
Intel Core Duo or AMD® Athlon™ X2 processor (Intel Core 2 Duo or AMD Athlon X4 or better recommended) Intel Core 2 Duo or AMD® Athlon™ X2 processor
(Intel Core i3 or AMD Athlon X4 or better recommended)
Mac and Windows systems
4 GB RAM (8 GB or more recommended)
Internet connection (needed for installation and activation)
Monitor with 1366 x 768 resolution (high-dpi monitor recommended)
A multi-touch-enabled monitor with TUIO support is required for touch operation
40 GB hard-drive space
Studio One Remote for iPad®
iPad Pro®, iPad 2, iPad mini®, and newer models
iOS 8 or later
Studio One Remote for Windows
Compatible with Microsoft Surface 3 (and higher) and Surface Pro 2 (and higher)
Windows 8.1, Windows 10, or later (Windows RT not supported)
2 GB RAM minimum (4 GB RAM or more recommended). Tablet must be x86-compatible (not ARM-based).
--- End quote ---
--- Quote ---Studio One v3 Requirements
Studio One® is a modern, cross-platform DAW that is capable of operating as a 32-bit or 64-bit application. While we make every effort to ensure Studio One will run well on the widest variety of computers possible, please read these specifications carefully to determine compatibility with your system.
Mac®
Mac OS X 10.8.5 or higher
Windows®
Windows 7 x64/x86 SP1 + platform update, Windows 8.1 x64/x86, Windows 10 x64/x86
4 GB RAM
30 GB hard-drive space
A multi-touch enabled monitor is required for touch operation
iOS 8 or later
Compatible with Surface 3 (and higher) and Surface Pro 2 (and higher)
Windows 8.1, Windows 10 or later (Windows RT not supported)
2GB RAM Minimum (4GB RAM or more recommended)Tablet must be x86-compatible (not ARM-based)
--- End quote ---
http://web.archive.org/web/20131001195235/https://www.presonus.com/products/Studio-One/tech-specs
--- Quote ---Studio One v2? Requirements
Computer system requirements:
Below are the minimum computer-system requirements for Studio One.
Mac
Mac® OS X 10.7.2 or later
Intel® Core™ Duo processor (Intel Core 2 Duo or Core i3 or better recommended)
​2 GB RAM (4 GB or more recommended)
Windows
Windows® 7 x64/x86 SP1, Windows 8 x64/x86
Intel Core Duo or AMD Athlon™ X2 processor (Intel Core 2 Duo or AMD Athlon X4 or better recommended)
Internet connection (not required on machine where Studio One is installed but needed for activation)
DVD-ROM drive
Monitor with 1280x768 resolution
20 GB hard-drive space
--- End quote ---
chrisNova777:
omg i cant even run v3 x64 ? lol
"this application requires windows 7 sp1 with platform update or later"
i was finally able to install v3 after doing the "windows 7 platform update"
Navigation
[0] Message Index
Go to full version
