Author Topic: Akai S2000 (1995) MIDI Stereo Digital Sampler  (Read 24956 times)
« on: March 22, 2015, 06:58:46 PM »
http://akai.mnx2010.nl
default config (non-expanded)
Creating OS disks:
http://akai.mnx2010.nl/
editable with:
EXPANSION OPTIONS
• IB304F FILTER BANK
• MORE MEMORY
• EXTRA STORAGE
some suggestions for cdroms:
hp cd-writer 9600 series
yamaha crw3200sx
Re: Akai S2000 (1995) with external SCSI hd
« Reply #1 on: December 30, 2015, 01:29:51 PM »
Re: Akai S2000 (1995) sampler with powermac for editing
« Reply #2 on: December 31, 2015, 03:13:06 PM »
Features:
akai ib304f profilter filter board
« Reply #3 on: August 24, 2016, 03:09:47 AM »
Re: Akai S2000 (1995) MIDI Stereo Digital Sampler
« Reply #5 on: June 12, 2017, 05:09:49 PM »
mutec-net.com
« Reply #6 on: April 06, 2018, 07:06:38 PM »
AKAI IB208P output expansion for Akai S2000 (1995)
« Reply #7 on: January 14, 2019, 05:50:45 AM »
« Reply #8 on: May 27, 2019, 12:46:41 AM »
