Author Topic: Allen & Heath Zed-436 (2007) 32 channel 4 bus  (Read 2645 times)
« on: March 26, 2015, 01:04:46 AM »
http://www.allen-heath.com/ahproducts/zed-436/
https://www.images2.co.uk/extended/SC026/ZED436_front_on_WhiteBG.jpg
32 direct outs and inserts on every channel!!!! direct out is tapped post mute pre fader, able to be modified to post fade
32 mono channels
2 dual stereo inputs with 4-band EQ
Neutrik mic XLR
Neutrik 1/4 inch jacks
Channel insert
Super wide gain ‘DuoPre’ mic line input
4-band EQ with 2 swept mids and in/out switch
Illuminated mute
Sound image pan
Illuminated PFL & peak warning indicator
ALPS 100mm faders
6 auxiliary sends (2 pre, 2 post, 2 pre/post)
4 sub groups fed from each channel
All inputs with level control
12 bar meters
L, R and M main mix outputs
2 matrix sections available; can send output to USB
Individual channel 48V phantom power
Direct output on every mono channel
Peak and signal indication on every channel
Configurable USB stereo audio in/out
Master level controls on all outputs
Easy to use layout – all connections and controls on top surface
