Recent | Who | Artists | Firewire | USB | Gfx | Windows | Mac | MacOS9 | IBM/DOS | ATARI ST | Midi Interfaces | Sequencers | MPCs | Roland "MC" | Roland "S" | E-mu | Ensoniq | Akai "S" | Samplers | soft-Samplers | Synths | soft-Synths (VSTi) | Roland "JV" | Modules | Drums | Tape | Mixers | hardware Effects | soft Effects | iOS | android | sw Timeline | HackintoshReason
Oct 24th :: fixed some minor permission problems with some of the areas of the site that were not accessible by guests; login with an account for best results
Author Topic: Soundcraft MFXi 20 (2010)  (Read 3421 times)
« on: March 27, 2015, 06:38:49 PM »
Soundcraft MFXi 20
20-channel Mixer with 24-bit Lexicon Effects and GB30 Mic Preamps
!! no direct outputs !!
http://www.ac-et.com/downloads/manuals/Soundcraft_MFXi_UserManual.pdf
The Soundcraft MFXi 20 20-channel analog mixer gives you the channel count you need and the portability and great sound you want — plus digital effects! This compact mixer includes premium Lexicon effects, allowing you to get the most out of your mix without having to depend on racks of outboard gear. The MFXi 20 boasts 20 of Soundcraft's highly-transparent GB30 mic preamps — the same pres used on the larger LX7ii and GB series consoles. With two aux sends, two groups, a 3-band EQ, a handy, secure Kensington lock, and much more, the MFXi 20 puts Soundcraft quality within your budget.
Soundcraft MFXi 20 at a Glance:
    High-quality mic preamps
    Must-have routing and I/O
    Premium Lexicon effects section
When designing the MFXi 20, Soundcraft brought excellent components to a truly appealing price. It features the the GB30 mic preamp that Graham Blyth designed expressly for the company's 30th anniversary — the GB30 is the same highly transparent mic preamp used on Soundcraft's larger LX7ii and GB series consoles.
When choosing a mixer, the amount of routing possibilities and I/O configurations are essential deciding factors and the MFXi 20 asserts an impressive outfit for its price. it includes two configurable aux sends, two groups, XLR and 1/4" metal jack connector sockets, RCA phono stereo playback inputs and record outputs, 3-band EQ on the two stereo inputs, TRS insert sockets, inserts on all mono outputs, ten-segment LED output metering, and a convenient headphone input. Inside, vertically mounted circuit boards and nutted pots give you premium performance and reliability. This mixer also includes a Kensington lock to keep it secure.
The MFXi 20's set of 24-bit digital effects sets it apart from many mixers in its class. You get two stereo channels and an effects send on each channel — and a whopping 32 effects to choose from. The MFXi 20 uses the same AudioDNA processor featured in many of the Digitech and Lexicon outboard equipment including the highly respected Lexicon MX400. Enjoy reverb, chorus and delay — complete with tap tempo — for a sound that's unmistakably Lexicon.
Soundcraft MFXi 20 Features:
    20 inputs with two stereo inputs
    Built-in 24-bit Lexicon digital effects processor
    32 effects settings
    Tap Tempo and effects setting store function
    One effects send on each channel
    Two configurable Aux busses
    Two Stereo Inputs
    Two Group busses
    Stereo Mix Output
    Aux 2 switchable Pre/Post
    2-track record output
    2-track replay input with level control
    Globally switched +48V Phantom Power
    GB30 mic preamps
    Nutted pots
    Peak LED
    100Hz HPF
    Insert point (mono channels)
    3-band EQ with swept Mid band on mono inputs
    3-band EQ on stereo inputs
    PFL switch
    Mix and group routing
    Signal Present LED
    60mm faders
    Headphone and Control Room outputs with level control
    Integral universal power supply
    Kensington lock
The Soundcraft MFXi 20 adds premium Lexicon effects to an outstanding compact mixer!
Tech Specs
Type    Analog
Channels    24 (20 Mono, 4 Stereo)
Inputs - Mic Preamps    20 x XLR
Inputs - Line    20 x 1/4" (CH 1-20), 4 x 1/4" (Stereo Channels), 2 x RCA (2 TRK)
Outputs - Main    2 x XLR, 1 x 1/4" (Mono)
Outputs - Other    2 x RCA (REC), 2 x 1/4" (Mon), 2 x 1/4" (Sub)
Headphones    1 x 1/4"
Send/Return I/O    2 x 1/4" (Aux), 1 x 1/4" (FX), 2 x 1/4 (Return)
Phantom Power    Yes (CH 1-20)
EQ Bands    3-band, Sweepable Mid
Aux Sends    1 x Post, 1 x Pre/Post, 1 x FX
Busses/Groups    2 x Stereo Sub
Faders    26 x 60mm
Channel Inserts    Yes (CH 1-20)
Effects    Yes
Height    3.68"
Width    27"
Depth    15.93"
Weight    20.4 lbs.
