Author Topic: Soundcraft GB2R 16 (2007)  (Read 1745 times)
« on: March 27, 2015, 07:27:16 PM »
The DIRECT OUTPUT is normally post fader. Pressing the PRE button switches it to pre-insert-point
http://soundcraft.com.s3.amazonaws.com/downloads/user-guides/Soundcraft-GB2RUG-EN.pdf
http://www.soundcraft.com/products/gb2r
The Soundcraft GB2R16 is a new member of Soundcraft's successful rackmountable mixer series! Ideal as part of a portable PA system, or for smaller installations in churches and performance venues, the GB2R16 is also an excellent mixer for broadcast applications. With the Soundcraft GB2R16, you get 16 mono inputs to a stereo mix output, with six auxiliary sends, and eight busses. You'll enjoy Soundcraft's emphasis on operational simplicity with the GB2R16 - not only is its layout clear and intuitive, but it has a conveniently rotating cable connector section so you can reach your connections whether your Soundcraft GB2R16 is on a table or rack-mounted!
Soundcraft GB2R16 at a Glance:
    Versatile, professional mixer
    Well-designed cable connector section
    Built to last
The GB2R16 delivers professional sound with its GB30 mic pres and GB30 equalizer design - the very same EQs and pres featured on Soundcraft's acclaimed GB4 and GB8 mixers. You get 16 mono inputs to a stereo mix output with six convenient auxiliary sends, and eight busses that are excellent for smaller installations in your performance venue or church, but equally as ideal for portable PA and broadcast applications. You'll also enjoy pre/post switchable direct output on every input for recording or effects sends. Plus, the GB2R16 has an internal universal voltage PSU, so you don't need to worry about any bulky external power supply.
You can use your GB2R16 on a table top, or rack-mounted in a 19" rack, but either way, Soundcraft has you covered for convenient cable access. The entire connector section is contained on a rotatable pod, allowing cable access from the top of the mixer if you have it on a table, or from the rear when it's rack-mounted!
Built to last
Soundcraft built their reputation on reliable consoles, and that's what you can expect with the GB2R16. Careful attention has been given to the GB2R16's mechanical construction: all input modules were constructed with individual vertically-mounted pcbs that were fitted to the steel chassis front panel with individually-nutted pentiometers for overall stronger, more rugged mixer design.
Soundcraft GB2R16 Features:
    19" rackmountable mixer
    16 mono inputs
    Stereo mix and mono sum outputs
    6 aux outputs
    Rotatable connector pod for top or rear cable entry
    8 busses
    GB30 mic preamp and precision EQ
    Switchable 48v phantom power on every mic input
    100Hz Hi-pass filter
    Direct outs on every channel
    100mm faders
    Stereo mix output and separate mono sum output
    Record output
    Internal Universal switched mode PSU
The Soundcraft GB2R16 is a well-designed, rugged live mixer!
Tech Specs
Type    Analog
Channels    16
Inputs - Mic Preamps    16 x XLR (CH 1-16)
Inputs - Line    16 x 1/4" (CH 1-16), 2 x RCA (2 TRK)
Outputs - Main    2 x XLR, 2 x 1/4", 1 x XLR (Mono)
Outputs - Direct    Yes (CH 1-16)
Outputs - Other    2 x 1/4" (Monitor), 2 x RCA (REC)
Headphones    1 x 1/4"
Send/Return I/O    4 x XLR (AUX), 2 x 1/4" (AUX), 4 x 1/4" (Return)
Phantom Power    Yes (CH 1-16)
EQ Bands    4-band, Sweepable Hi-Mid/Lo-Mid
Aux Sends    2 x Pre, 2 x Pre/Post, 2 x Post
Faders    18 x 100mm
Channel Inserts    Yes (CH 1-16)
Rackmountable    Yes
