Author Topic: Mackie Onyx 1220 (2004)  (Read 1946 times)
« on: March 28, 2015, 03:23:19 AM »
http://www.mackie.com/pdf/onyx1220_om.pdf
https://www.sweetwater.com/forums/showthread.php?9910-need-small-mixer-with-direct-outs
direct/recording outs from db25 connectors are tapped immediately after trim and before the HPF however it is possible to modify these mixers to allow for the recording outs on both the db25 + firewire connections to be tapped post eq -- and either pre-fader or post fader - see : http://www.frontendaudio.com/Mackie-Onyx-1220-EQ-Modification-p/7278.htm - the onyx-i revision version of the 1220, is eq switchable via buttons on the fly, however it does not include the recording outs db25 connection and direct out is via FIREWIRE ONLY
