« on: July 09, 2020, 08:28:51 PM »Posted by: chrisNova777
« on: March 03, 2019, 07:23:31 AM »Posted by: chrisNova777
« on: January 30, 2019, 04:41:26 PM »http://www.muzines.co.uk/articles/akai-s612/5466
« on: January 20, 2019, 07:04:56 AM »Posted by: chrisNova777
« on: January 18, 2019, 08:17:59 AM »akai s612 sampler
The S612 captures sound.
FITTING IN
FRONT
THE SLIDER
BACK
CONCLUSION
« on: January 07, 2019, 11:08:13 PM »Posted by: chrisNova777
« on: June 20, 2017, 12:02:09 AM »http://www.muzines.co.uk/articles/sampling-the-japanese-way/1271
THE NEED
THE SET-UP
EASY DOES IT
LOOPY TUNES
« on: January 12, 2016, 10:31:48 AM »http://web.archive.org/web/20001109145800/http://www.cyberden.com/cyberden/MIDI_Hell/Samp_Pgms/
i found this editor/librarian program for the S612 sampler
http://www.synthmuseum.com/akai/akas61201.html
http://tomellard.com/cave/akai-s612.html
https://jimatwood.wordpress.com/tag/akai-s612-sample-editor/
http://www.wiseguysynth.com/larry/s-612/s-612.htm
http://fa.utfs.org/diy/akai_s612/
editor for the ATARI TOS - ive read it works on pc using STEEM engine http://tamw.atari-users.net/steem.htm
http://www.verycomputer.com/10_f70f774781c7c3af_1.htm
