« on: September 21, 2014, 02:04:53 PM »http://web.archive.org/web/19991127225904/http://www.motu.com/english/motuaudio/1224/features.html
http://web.archive.org/web/19991129051433/http://www.motu.com/english/other/press/pr.html
http://www.motu.com/other/press/97-99.html
http://www.motu.com/other/press/1224/1224.pdf
download MAS motu audio system
http://www.motu.com/download/download_matching_downloads.html?platform_id=1&product_id=12
Exclusive Audio Wire™ connectivity - connects to the computer via a single Audio Wire cable that carries all 10 input channels and 12 output channels simultaneously in pristine 24-bit digital audio.
Outstanding audio quality - the 1224's latest generation 24-bit analog converters deliver an incredible 116 dB dynamic range.
Expandable - connect up to three 1224 rack I/Os to a PCI-324 audio card for a total of 30 inputs and 36 outputs. Use as many simultaneous channels as host software & computer allow.
100% compatible with the 2408 - Add 1224 rack I/Os to a core 2408 system, or add 2408 rack I/Os to a core 1224 system. Mix and match 1224 and 2408 I/Os (up to three at once) to meet your exact I/O needs.
ASIO drivers for Mac OS and Windows 95/98 - provides multi-channel 24-bit I/O for all leading ASIO-compliant audio software on both computer platforms.
Multichannel Wave driver for Windows 95/98 - provides simultaneous inputs/outputs for all Windows audio applications that support standard multi-channel Wave drivers.
100% compatible with VST, MAS, Premiere, DirectX, and all other host-based native plug-in formats supported by today's popular audio programs. Does not require proprietary plug-ins.
Low latency - The 1224's software driver provides adjustable buffers and our exclusive Cue Mix feature, which provide the lowest host-based latency available with any software you use.
1224 core system includes AudioDesk - full-featured sample-accurate workstation software for MacOS with recording, editing, mixing, real-time 32-bit effects processing & sample-accurate sync.
Stereo 24-bit AES/EBU in/out.
Word clock in/out - resolves to time code or any other external time base via MOTU's Digital Timepiece synchronizer or any other standard digital audio synchronization device.
