Oldschooldaw.com => General / Miscellaneous => Topic started by: chrisNova777 on December 24, 2014, 01:58:26 PM
http://web.archive.org/web/19980519182229/http://edirol.com/multiclient.html
(http://web.archive.org/web/19980704002130/http://www2.edirol.com/images/multidriver.gif)
dead link though: ftp://ftp.edirol.com/pub/multiserial.zip
This file is a zipped archive with the NEW Roland Multi-Client Serial Windows driver. This much requested driver allows you to use two MIDI applications simultaneously and is compatible with the Roland SC-88 Pro, SC-88/VL, SC-55/ST, SK-50, and SC-88/ST. This serial driver supports the 32 MIDI channels in the 88 series Sound Canvas. Includes all documentation within the archive. Each of these units require the PC Serial port cable. This item is available through our order line. (See below).
Roland Serial MIDI Driver Ver. 2.1
for Windows 95/98
This driver is compatible with both Windows 95 and Windows 98.When you connect Roland's Sound Modules/Keyboards such as SOUND CANVAS Series built-in "Computer Port" to PC with D-sub 9-pin (or 25-pin) serial port, this driver can be used with SERIAL CABLE such as DB9F-3 (distributed by Roland U.S.), RSC-15AT (distributed by Edirol N.A. and Roland Corporation Japan), RS-232C-9, RS-232C-25, RSC-232C(C) (distributed by Roland worldwide distributors), or compatible cables.
Roland's 16 parts multitimbral sound modules built-in "Computer Port" are known as follows:
SC-7, SC-50, SC-55mkII, XP-10, PMA-5
SC-55ST, SK-50, SK-50IV
HP-G Series Digital Pianos, KR Series Digital Pianos built-in "Computer Port"
E Series Arranger Keyboards built-in "Computer Port"
16-parts multitimbral sound modules built-in "Computer Port"
Also, with one single SERIAL CABLE, this driver supports 32 MIDI channels sound modules/keyboards.Roland's 32-parts multitimbral sound modules built-in "Computer Port" are known as follows:
SC-88, SC-88VL, SC-88ST, SC-88Pro, SC-88STPro, SK-88Pro
ftp://ftp.phelpsgroup.com/pub/roland/libdata/WDRIVERS/RSDRV21.ZIP 718KB
Roland Serial MIDI Driver Ver. 1.1
for Windows 95/98
This driver places a comparatively smaller load on the computer than the multi-client version.Use this version if the tempo is unsteady during performance or if you experience other problems while using "Roland Serial MIDI Driver Ver. 2.1."If you want to know detail about the installation and so on, please read the "README.TXT" in this archive.
ftp://ftp.phelpsgroup.com/pub/roland/libdata/WDRIVERS/RSDRV11.ZIP 716KB
for Windows 3.1
This file contains a self extracting archive with the Roland Serial Windows 3.1 driver.This driver is compatible with the Roland SC-88Pro, SC-88/88VL, SC-55/55ST, SK-50, and SC-88/88ST or the other sound modules built-in "Computer Port."This serial driver supports the 32 MIDI channels in the 88 series Sound Canvas.Each of these units require the PC Serial port cable.
ftp://ftp.phelpsgroup.com/pub/roland/libdata/WDRIVERS/SERIAL31.EXE 40KB
http://web.archive.org/web/19990427153121/http://www.rolandcorp.com/downloads/driver-for-win.html
